I want to get rid of my vendor hubs like phillips hue and got myself a SkyConnect stick. I am running HA in a VM on Proxmox on a NUC. I added skyconnect to my NUC and passed it through to the HA VM. In HA I can see the stick in hardware as “Home Assistant SkyConnect” and can configure it.
If I now try to install ZHA I get an “Unkown error occurred” and looking in the logs I see this:
Logger: aiohttp.server
Source: /usr/local/lib/python3.12/site-packages/aiohttp/web_protocol.py:421
First occurred: 10:14:03 (1 occurrences)
Last logged: 10:14:03
Error handling request
File "/usr/local/lib/python3.12/site-packages/aiohttp/web_protocol.py", line 452, in _handle_request
resp = await request_handler(request)
File "/usr/local/lib/python3.12/site-packages/aiohttp/web_app.py", line 543, in _handle
resp = await handler(request)
File "/usr/local/lib/python3.12/site-packages/aiohttp/web_middlewares.py", line 114, in impl
return await handler(request)
File "/usr/src/homeassistant/homeassistant/components/http/security_filter.py", line 91, in security_filter_middleware
File "/usr/src/homeassistant/homeassistant/components/http/forwarded.py", line 100, in forwarded_middleware
File "/usr/src/homeassistant/homeassistant/components/http/request_context.py", line 28, in request_context_middleware
File "/usr/src/homeassistant/homeassistant/components/http/ban.py", line 80, in ban_middleware
File "/usr/src/homeassistant/homeassistant/components/http/auth.py", line 235, in auth_middleware
File "/usr/src/homeassistant/homeassistant/components/http/headers.py", line 31, in headers_middleware
response = await handler(request)
File "/usr/src/homeassistant/homeassistant/components/http/view.py", line 149, in handle
result = await handler(request, **request.match_info)
File "/usr/src/homeassistant/homeassistant/components/http/decorators.py", line 72, in with_admin
return await func(self, request, *args, **kwargs)
File "/usr/src/homeassistant/homeassistant/components/config/config_entries.py", line 185, in post
return await super().post(request, flow_id)
File "/usr/src/homeassistant/homeassistant/components/http/data_validator.py", line 72, in wrapper
result = await method(view, request, data, *args, **kwargs)
File "/usr/src/homeassistant/homeassistant/helpers/data_entry_flow.py", line 110, in post
result = await self._flow_mgr.async_configure(flow_id, data)
File "/usr/src/homeassistant/homeassistant/data_entry_flow.py", line 358, in async_configure
result = await self._async_configure(flow_id, user_input)
File "/usr/src/homeassistant/homeassistant/data_entry_flow.py", line 404, in _async_configure
result = await self._async_handle_step(
File "/usr/src/homeassistant/homeassistant/data_entry_flow.py", line 501, in _async_handle_step
result: FlowResult = await getattr(flow, method)(user_input)
File "/usr/src/homeassistant/homeassistant/components/zha/config_flow.py", line 194, in async_step_choose_serial_port
probe_result = await self._radio_mgr.detect_radio_type()
File "/usr/src/homeassistant/homeassistant/components/zha/radio_manager.py", line 220, in detect_radio_type
probe_result = await radio.controller.probe(dev_config)
File "/usr/local/lib/python3.12/site-packages/zigpy_zigate/api.py", line 576, in probe
await asyncio.wait_for(api._probe(), timeout=PROBE_TIMEOUT)
File "/usr/local/lib/python3.12/asyncio/tasks.py", line 520, in wait_for
return await fut
File "/usr/local/lib/python3.12/site-packages/zigpy_zigate/api.py", line 605, in _probe
await self.connect()
File "/usr/local/lib/python3.12/site-packages/zigpy_zigate/api.py", line 236, in connect
self._uart = await zigpy_zigate.uart.connect(self._config, self)
File "/usr/local/lib/python3.12/site-packages/zigpy_zigate/uart.py", line 158, in connect
_, protocol = await zigpy.serial.create_serial_connection(
File "/usr/local/lib/python3.12/site-packages/zigpy/serial.py", line 42, in create_serial_connection
transport, protocol = await loop.create_connection(
File "/usr/local/lib/python3.12/asyncio/base_events.py", line 1077, in create_connection
infos = await self._ensure_resolved(
File "/usr/local/lib/python3.12/asyncio/base_events.py", line 1453, in _ensure_resolved
return await loop.getaddrinfo(host, port, family=family, type=type,
File "/usr/local/lib/python3.12/asyncio/base_events.py", line 898, in getaddrinfo
return await self.run_in_executor(
File "/usr/local/lib/python3.12/concurrent/futures/thread.py", line 58, in run
File "/usr/local/lib/python3.12/socket.py", line 963, in getaddrinfo
for res in _socket.getaddrinfo(host, port, family, type, proto, flags):
socket.gaierror: [Errno -5] Name has no usable address
I tried with and without multiprotocol (using the configuration option from SkyConnect under hardware) without success and now I am kinda stuck.
I don’t think I have a thread device yet so having zigbee protocol for now would be sufficiant.
Any hints what to try to get ZHA running would be great!
NoTechi
