ZHA integration crashing?
I’m not sure on the culprit, but it’s either HA or the ZHA integration and I suspect the latter.
I have a Sonoff Zigbee bridge which has been flashed with Tasmota and configured for ZHA.
I have two Sonoff snzb-02 temp/humidity sensors added to the bridge.
They can work fine for a day or so, but then one or both will show offline in HA, even though the Zigbee bridge is fine on the Tasmota console. Checking the network map will show the bridge and sensors as last seen X hours ago (same time).
Reloading the ZHA integration does nothing, but restarting HA always solves the issue.
Has anyone seen the same and have a better solution?
I have the same problem.
I have an issue with the door sensor from Sonoff, one just stops reporting open/closed. The Sonoff bridge is not a recommended controller due to Wifi stability issues. I have one running tasmota but I found it was the same when using a Conbee II stick in ZHA. It could be the controller, it could be the Sonoff devices. I know my Aqara ones have been reliable and am planning to switch the Sonoff ones for Aqara ones.
