ZHA issue after WiFi change
Several weeks ago I followed this tutorial: https://www.digiblur.com/2020/07/how-to-use-sonoff-zigbee-bridge-with.html?m=1 and everything was fine.
A few days back I’ve changed my Wifi (and my subnetwork), and I can’t configure ZHA anymore.
I deleted the integration, restarted the raspberry several times, I can’t configure it back.
Even though I’m trying to add my bridge new IP (192.168.86.38), I have the following error: Impossible de se connecter au périphérique ZHA..
In my tasmota console I don’t see any attempt to connect from HA:
19:04:45 NTP: UTC 2020-10-19T18:04:44, DST 2020-03-29T02:00:00, STD 2020-10-25T03:00:00
19:04:45 HTP: Web server active on tasmota_D7F6B5-5813 with IP address 192.168.86.38
19:04:46 RSL: tele/tasmota_D7F6B5/INFO1 = {"Module":"Sonoff ZHABridge","Version":"8.5.1(tasmota)","FallbackTopic":"cmnd/DVES_D7F6B5_fb/","GroupTopic":"cmnd/tasmotas/"}
19:04:46 RSL: tele/tasmota_D7F6B5/INFO2 = {"WebServerMode":"Admin","Hostname":"tasmota_D7F6B5-5813","IPAddress":"192.168.86.38"}
19:04:46 RSL: tele/tasmota_D7F6B5/INFO3 = {"RestartReason":"Software/System restart"}
19:04:46 RUL: SYSTEM#BOOT performs "TCPStart 8888"
19:04:46 SRC: Rule
19:04:46 CMD: Group 0, Index 1, Command "TCPSTART", Data "8888"
19:04:46 RSL: stat/tasmota_D7F6B5/RESULT = {"Command":"Unknown"}
19:04:48 HTP: Main Menu
19:04:49 APP: Boot Count 16
19:04:49 CFG: Saved to flash at F4, Count 45, Bytes 4096
19:04:50 RSL: tele/tasmota_D7F6B5/STATE = {"Time":"2020-10-19T19:04:50","Uptime":"0T00:00:11","UptimeSec":11,"Heap":27,"SleepMode":"Dynamic","Sleep":50,"LoadAvg":30,"MqttCount":0,"Wifi":{"AP":1,"SSId":"LaNationale","BSSId":"CC:2D:21:1C:47:69","Channel":6,"RSSI":100,"Signal":-18,"LinkCount":1,"Downtime":"0T00:00:05"}}
19:06:43 HTP: Console
I’m using HassOS 4.14 and Home Assistant 0.116.4.
Anyone knows how I can fix that please?
Thanks in advance
I flashed again my ZB bridge from start, was able to connect to it again!
