Using son off bridge flashed with tasiota and using it via ZHA.
After a power cut, or what ever reason the bridge is un power for a period of time, the sensors from aqara for the temperature won’t re connect if they have tried to send info during this power outage.
I have to go back to all of them and press the button, and some of them require even to re sync them.
Sonoff door sensor doesn’t have any trouble to reconnect as the temp sensors do.
How Can avoid this? I have 8 temp sensors, so changing to son off temp sensors, is an option, but not the first one.
Try repairing them, that is, next time it happens: Remove all troublesome sensors from ZHA. Restart HA and make use they’ve been removed. If not, remove them again and restart HA until so. Repair them again. I can’t assure it will work but it may
