ZHA - LoraTap Tuya (TS0043) US 3 Gang Remote
This is a Blueprint for the LoraTap US 3 Gang Remote TS0043 with the manufacturer code _TZ3000_famkxci2.
The other blueprints for TS0043 button remotes didn’t work for me (because of different manufacturer codes) so I decided to upload this one that is working for me. It is based off of @vigonotion blueprint. All I did was change the manufacturer to _TZ3000_famkxci2 and it worked so I figured I’d post this so that it helps anyone that might have this particular zigbee button (and you won’t need to add a quirk like has been suggested on other posts).
blueprint:
  name: ZHA - Tuya TS0043 3 button remote
  description: Automate your Tuya TS0043 3 button remote using
    ZHA events.
  domain: automation
  input:
    tuya_ts0043:
      name: Tuya TS0043 3 button remote
      description: Tuya TS0043 3 button remote to use
      selector:
        device:
          integration: zha
          manufacturer: _TZ3000_famkxci2
          model: TS0043
    button_one_single_press:
      name: Button 1 (single press)
      description: Action to run on button 1 single press
      default: []
      selector:
        action: {}
    button_one_double_press:
      name: Button 1 (double press)
      description: Action to run on button 1 double press
      default: []
      selector:
        action: {}
    button_two_single_press:
      name: Button 2 (single press)
      description: Action to run on button 2 single press
      default: []
      selector:
        action: {}
    button_two_double_press:
      name: Button 2 (double press)
      description: Action to run on button 2 double press
      default: []
      selector:
        action: {}
    button_three_single_press:
      name: Button 3 (single press)
      description: Action to run on button 3 single press
      default: []
      selector:
        action: {}
    button_three_double_press:
      name: Button 3 (double press)
      description: Action to run on button 3 double press
      default: []
      selector:
        action: {}
mode: restart
max_exceeded: silent
- platform: event
  event_type: zha_event
  event_data:
    device_id: !input 'tuya_ts0043'
  - variables:
      command: '{{ trigger.event.data.command }}'
      endpoint_id: '{{ trigger.event.data.endpoint_id }}'
  - choose:
    - conditions:
        - '{{ command == ''remote_button_short_press'' and endpoint_id == 1 }}'
      sequence: !input 'button_one_single_press'
    - conditions:
        - '{{ command == ''remote_button_double_press'' and endpoint_id == 1 }}'
      sequence: !input 'button_one_double_press'
    - conditions:
        - '{{ command == ''remote_button_short_press'' and endpoint_id == 2 }}'
      sequence: !input 'button_two_single_press'
    - conditions:
        - '{{ command == ''remote_button_double_press'' and endpoint_id == 2 }}'
      sequence: !input 'button_two_double_press'
    - conditions:
        - '{{ command == ''remote_button_short_press'' and endpoint_id == 3 }}'
      sequence: !input 'button_three_single_press'
    - conditions:
        - '{{ command == ''remote_button_double_press'' and endpoint_id == 3 }}'
      sequence: !input 'button_three_double_press'
the buttons go up in action but there are systematically 2 actions which go up at the same time.
One empty and another for example 1_single.
Except that the automation sees only one, either the empty one or the other (1_single) when it sees the empty one then nothing happens.
so you can press the button and see nothing happen. it’s quite random.
I couldn’t find a way to resolve this.
Goodmorning, for zigbee remotes or buttons, I created this project/automation that can be imported in Home Assistant: you can pair the remote with zigbee2mqtt and than map its button(s) to an action or a sequence of action with this automation.
You can try this with your remote.
