Hey NightHawk. After the middle button problems with ZHA were corrected in 2022.7.5 updates, I had the same problem you saw. I was able to correct the problem with the ‘selector’ section of the blueprint by editing it as follows:
Original Blueprint Selector:
Remove or comment out the ‘integration’ line as follows.
The ‘manufacturer’ isn’t really needed, but I wanted to find out why it wasn’t working. Turns out that adding a space before “_Lutron” is needed. Adding quotes fixed that. But, the ‘selector’ will work with just the ‘model’. I went ahead and added quotes there to assure any unseen spaces didn’t mess things up.
Thanks so much! I know it has been some time since my input but wanted to let you know that I added your “fix” from this post and I now have the devices shown again to choose from. I had completely removed everything and I am just now getting back around to adding it all back in because I wanted to start fresh.
Trying to use the blueprint but under Device nothing is showing up, I made the changes suggested by @jdggit and my device looks fully paired, any suggestions?
The problem with Lutron devices not showing up in Blueprints is mentioned here:
and further documented here:
I’ve been able to work around the problem by selecting the Device from it’s Integration and then Enabling an available Control or Diagnostic element. Wait a minute for the device to come alive, then go back to the Blueprint and it’s available in the drop down. It’s hit-and-miss and sometimes requires a few tries, but eventually it has shown up long enough to get the blueprint written.
