Blueprint to support the Mijia Wireless Switch and allow it to perform up to five actions.
The Mijia Wireless Switch supports:
- Single press
- Double press
- Triple press
- Quadruple press
- Furious press (5 or more)
Blueprint screen:
Blueprint to import:
blueprint:
name: ZHA - Mijia Wireless Switch
description: 'Perform actions with the Mijia Wireless Switch.
You can set functions for single press, double press, triple press, quadruple press and furious (5 or more presses). This allows you to assign,
e.g., a scene or anything else.'
domain: automation
input:
remote:
description: LUMI Button to use
selector:
device:
integration: zha
manufacturer: LUMI
model: lumi.sensor_switch
single_press:
description: Action to run on single press
default: []
selector:
action: {}
double_press:
description: Action to run on double press
default: []
selector:
action: {}
triple_press:
description: Action to run on triple press
default: []
selector:
action: {}
quadruple_press:
description: Action to run on quadruple press
default: []
selector:
action: {}
furious_press:
description: Action to run on furious press
default: []
selector:
action: {}
source_url: https://gist.github.com/seamus65/c35766e14c54594db8a7fd5b1fc0d971
mode: restart
max_exceeded: silent
- platform: event
event_type: zha_event
event_data:
device_id: !input 'remote'
- variables:
command: '{{ trigger.event.data.command }}'
cluster_id: '{{ trigger.event.data.cluster_id }}'
endpoint_id: '{{ trigger.event.data.endpoint_id }}'
args: '{{ trigger.event.data.args.click_type }}'
- choose:
- conditions:
- '{{ command == "click" }}'
- '{{ cluster_id == 6 }}'
- '{{ endpoint_id == 1 }}'
- '{{ args == "single" }}'
sequence: !input 'single_press'
- conditions:
- '{{ args == "double" }}'
sequence: !input 'double_press'
- conditions:
- '{{ args == "triple" }}'
sequence: !input 'triple_press'
- conditions:
- '{{ args == "quadruple" }}'
sequence: !input 'quadruple_press'
- conditions:
- '{{ args == "furious" }}'
sequence: !input 'furious_press'
