ZHA: modify entity “light” to "valve” (not working)
based on this thread Turning a "Light" entity to "Switch" entity - #9 by neilv
and the ZHA docs ZHA: modifying-the-device-type
I tried to change some light entities to valve (not switch)
in configuration.yaml:
 zha:
  device_config:
    a4:c1:38:58:51:40:33:c2-1:    # format: {ieee}-{endpoint_id}
      type: "valve"              # corrected device type
it “somehow” works, but the type changed to switch and not valve
Is this something that should work?
Or is type: "switch" the only allowed option here?
(And I’m supposed to change the switch to a valve with a helper later? Helper switch as x )
Based on the same ZHA docs you linked to (at the top) valve is not listed as a supported device type. Probably because the valve type was added to HA not that long ago. So you might want to search the forum if there already is an FR for it and vote for it, or add one if there isn’t.
Thank you - for the answer - I didn’t realise that
Seems there is no feature request for this (at least I didn’t found one). Anyway I’m planning to move to z2m …
It may be of interest to you that after I changed mine from “light” to “switch” via zha:device_config, I can change it to show as “valve” vrom GUI:
