gmlupatelli
(Gus Lupatelli)
October 27, 2021, 12:46am
1
Blueprint to support the MOES Wireless Remote Switch (Double Rocker) using ZHA.
As far as I could find MOES is another generic Zigbee Tuya smart home “company” from China. Its Zigbee manufacture information is _TZ3000_5e235jpa, and at the time that I bought it at Aliexpress, it was the cheapest alternative.
Here is a link* to the product page that I bought: 1/2/3 Gang Tuya ZigBee Wireless Scene Smart Light Switch Push Button Controller Automation Scenario Smart Life Alexa Google Home|Smart Remote Control| - AliExpress
*it is an affiliated link
Supported actions:
Single Press
Double Press
Git link: blueprints_repo/moes_double_rocker.yaml at cab231edbd05820c070de5c6a38f140868cbbbcb · gmlupatelli/blueprints_repo · GitHub
Do you now a blueprint for the single rocker model?
blackbeard
(blackbeard)
February 10, 2023, 8:00am
3
Hi, I adapted your Blueprint for model _TZ3000_dfgbtub0 (TS0042 - 2 button model) and added support for long press on both buttons
blueprint:
name: ZHA - MOES Wireless Remote Switch (Double Rocker)
description: Automate your MOES Wireless Remote Switch (Double Rocker) using ZHA
events.
domain: automation
source_url: https://github.com/gmlupatelli/blueprints_repo/blob/ff26cebe9ed8a3f99298fa34d4725341ed92bd60/moes_controler/moes_double_rocker.yaml
input:
remote_switch:
name: Select the MOES Wireless Remote Switch (Double Rocker)
description: MOES Wireless Remote Switch (Double Rocker)
selector:
device:
integration: zha
manufacturer: _TZ3000_dfgbtub0
entity:
domain: sensor
device_class: battery
multiple: false
button_single_press_left:
name: Single Press Left
description: Action to run on single press
default: []
selector:
action: {}
button_double_press_left:
name: Double Press Left
description: Action to run on double press
default: []
selector:
action: {}
button_long_press_left:
name: Long Press Left
description: Action to run on long press
default: []
selector:
action: {}
button_single_press_right:
name: Single Press Right
default: []
selector:
action: {}
button_double_press_right:
name: Double Press Right
default: []
selector:
action: {}
button_long_press_right:
name: Long Press Right
default: []
selector:
action: {}
- platform: event
event_type: zha_event
event_data:
device_id: !input remote_switch
- variables:
endpoint_id: '{{ trigger.event.data.endpoint_id | int }}'
command: '{{ trigger.event.data.command }}'
- choose:
- conditions:
- '{{ command == ''remote_button_short_press'' and endpoint_id == 1}}'
sequence: !input button_single_press_left
- conditions:
- '{{ command == ''remote_button_double_press'' and endpoint_id == 1}}'
sequence: !input button_double_press_left
- conditions:
- '{{ command == ''remote_button_long_press'' and endpoint_id == 1}}'
sequence: !input button_long_press_left
- conditions:
- '{{ command == ''remote_button_short_press'' and endpoint_id == 2}}'
sequence: !input button_single_press_right
- conditions:
- '{{ command == ''remote_button_double_press'' and endpoint_id == 2}}'
sequence: !input button_double_press_right
- conditions:
- '{{ command == ''remote_button_long_press'' and endpoint_id == 2}}'
sequence: !input button_long_press_right
mode: restart
max_exceeded: silent
Thank you for your Blueprint !!!
gmlupatelli
(Gus Lupatelli)
February 10, 2023, 2:24pm
4
Cool that you have a version of it with long press support. Mine goes into pairing mode if I long press any button…lol…Chinese engineering and construction at its best.
