ZHA - Multiple Gateway
I’m planned to switch from Domoticz to Hass.
My Domoticz run 2 * PiZigate on lan (PIZigate or on a rpi who just act like a socat server)
(near 75 zigbee devices : bulb, switch, trv)
Before a final switching, i made some test :
I have a Wifi Zigate to test ZHA, connection is fine all looks ok on my test device (bulb, switch).
On big probleme is the none ability to add a second controller, does it planned ?
Why do you have 2 separate zigbee meshes? One for ZHA devices and one for ZLL devices?
Also vote for your own request :wink:
Multi Zigbee :
  • Zigate * 2 = zigate have a max of 40 devices
  • Xiaomigateway * 2 = xiaomi battery devices works a lot better on xiaomi gateway)
  • Raspbee * 1 = deconz have very user friendly scene interface, so much easy to set, scene, event, and a lot faster : now way to know that a xiaomi switch trigger an ikea bulb when using conbee).
Using zigbee since 3 years know, i learn that sperate zigbee network main more stable, more fast answer, more easy for WAF.
So you have 5 zigbee mesh networks? That’s a bit too much in my opinion. The mpre devices in the mesh, the better is the mesh. The only thing that makes sense for me to split zigbee meshes is to have one for ZLL and one for ZHA devices as the communication between these is not the best.
I use a ConBee stick with deCONZ for 3+ years now with 60+ devices mixing Xiaomi, Philips and IKEA devices and I never had any issues with this at all.
https://github.com/zigpy/zigpy/discussions/673
https://community.home-assistant.io/t/zha-support-for-more-than-one-zigbee-coordinator-in-zha/258248
https://community.home-assistant.io/t/zha-multiple-co-ordinators/255101
