I have same issues.
2018-06-18 23:36:02 INFO (MainThread) [zigpy.application] Device 0xf82a (00:15:8d:00:02:04:29:ca) joined the network
2018-06-18 23:36:02 ERROR (MainThread) [bellows.ezsp] Exception running handler
File “/srv/homeassistant/lib/python3.5/site-packages/bellows/ezsp.py”, line 194, in handle_callback
handler(*args)
File “/srv/homeassistant/lib/python3.5/site-packages/bellows/zigbee/application.py”, line 139, in ezsp_callback_handler
self._handle_frame(*args)
File “/srv/homeassistant/lib/python3.5/site-packages/bellows/zigbee/application.py”, line 160, in _handle_frame
tsn, command_id, is_reply, args = self.deserialize(device, aps_frame.sourceEndpoint, aps_frame.clusterId, message)
File “/srv/homeassistant/lib/python3.5/site-packages/zigpy/application.py”, line 73, in deserialize
return sender.deserialize(endpoint_id, cluster_id, data)
File “/srv/homeassistant/lib/python3.5/site-packages/zigpy/device.py”, line 97, in deserialize
return self.endpoints[endpoint_id].deserialize(cluster_id, data)
KeyError: 1
2018-06-18 23:36:47 ERROR (MainThread) [zigpy.device] Failed ZDO request during device initialization: Message send failure: EmberStatus.DELIVERY_FAILED
File “/srv/homeassistant/lib/python3.5/site-packages/zigpy/device.py”, line 51, in _initialize
epr = await self.zdo.request(0x0005, self.nwk, tries=3, delay=2)
File “/srv/homeassistant/lib/python3.5/site-packages/zigpy/util.py”, line 52, in retry
r = await func()
File “/srv/homeassistant/lib/python3.5/site-packages/zigpy/device.py”, line 89, in request
expect_reply=expect_reply,
File “/srv/homeassistant/lib/python3.5/site-packages/bellows/zigbee/application.py”, line 241, in request
v = await send_fut
File “/usr/lib/python3.5/asyncio/futures.py”, line 380, in iter
yield self # This tells Task to wait for completion.
File “/usr/lib/python3.5/asyncio/tasks.py”, line 304, in _wakeup
future.result()
File “/usr/lib/python3.5/asyncio/futures.py”, line 293, in result
raise self._exception
zigpy.exceptions.DeliveryError: Message send failure: EmberStatus.DELIVERY_FAILED
