ZHA + NodeRed - Philips Hue Tap Dial
Hey
I have moved over from running Zigbee2MQTT + a Zigbee Sonoff stick to a Homeassistant SkyConnect + ZHA - I’ve spent most of the day renaming devices as they (eventually) repair!
I’ve now turned to my node red automations - they are fairly simple mostly controlling lights at this point.
I have a Philips Hue Tap Dial, now when I was all setup in Zigbee2Mqtt I would see a whole bunch of triggers in Nodered for the device (different button pushes / rotating the dial / long press etc) - Now when I try to reconfigure I don’t see any of these options - I have an action press button but that’s all - am I missing something here I need to do different using ZHA ? When I go into the device in ZHA I can see all the button presses / dial twists I do in the logbook so it seems to be working - just not seeing this options in node red anymore - any help appreciated!
I have the same problem. Intel NUC, clean installation, SkyConnect and ZHA loaded. I pair an Aqara Mini Button and if you look at the device entities they all there apart from action. Same in Node-Red.
