I’m getting the above error when trying to add the zha integration via configuration.yaml:
zha:
usb_path: /dev/NortekHUSBZB-1
database_path: /home/me/.homeassistant/zigbee.db
where /dev/NortekHUSBZB-1 is a symlink to the Nortek HUSBZB-1 device created by a udev rule, although I get the same error when I reference the direct path (/dev/bus/usb/001/007) in configuration.yaml.
I’m also not sure if I’m linking to the right device. The manual says it should appear as two devices, but I’m not sure how to access each individually.
dmesg | grep USB:
[292801.415493] usb 1-10: new full-speed USB device number 7 using xhci_hcd
[292801.557402] usb 1-10: New USB device found, idVendor=10c4, idProduct=8a2a, bcdDevice= 1.00
[292801.557409] usb 1-10: New USB device strings: Mfr=1, Product=2, SerialNumber=5
lsusb:
Bus 001 Device 007: ID 10c4:8a2a Cygnal Integrated Products, Inc. HubZ Smart Home Controller
ls /dev/bus/usb/001/
001 007
Looks like it’s getting found, but I only see one device but it doesn’t seem to work with the zha or with Z-Wave integrations. What am I missing?
traceback from log:
File "/home/me/homeassistant/lib/python3.7/site-packages/serial/serialposix.py", line 323, in _reconfigure_port
orig_attr = termios.tcgetattr(self.fd)
termios.error: (25, 'Inappropriate ioctl for device')
Install Info:
arch | x86_64 |
dev | false |
docker | false |
hassio | false |
os_name | Linux |
python_version | 3.7.4 |
version | 0.99.2 |
virtualenv | true |
Lovelace
mode auto-gen
