ZHA not finding new devices
Last week I attempted to swap out a light switch to one of my inovelli switches and once it was wired when I went to add the switch ZHA just spun in circles and eventually couldn’t find it. I tried another inovelli switch and same problem, both were in pairing mode and I reset them mulitple times and still couldn’t find any new devicess adding them through ZHA. I recently decided to switch to zigbee bulbs and I went with the Sengled bulbs and when I went to add those I had the same problem. However, two of the bulbs did some how connect to my ZHA network but not through the traditional means of adding a device, when I went to the vizualization of my network I randomly found the bulbs connected even though when I went to add the device nothing was found. Those bulbs are working correctly so I decided to add another in a different spot and I’m unable to add that one at all. I did a test this morning with one of the inovelli switches and atempted to add it in a different spot in the house and it won’t find the device. All of my zigbee devices that were previously connected still work just fine it’s just adding new ones I’m not able to do. Any idea or fix as to why this is happening? I’m using the sonoff zigbee 3.0 plus dongle.
