Dears,
I have an issue with zha (that controls my entire house) that Is absolutely not stable afer update 2023.6.
After few minutes, The zigbee controller (sonoff dongle ZBDongle-E) Is totally Lost and obviously everything stops working.
In the zha configuration it looks like disconnected. Id I remove It, restart and reattach it’s recognized but After few minutes everything stops again.
Please, help meee!
I Just replace the controller with another One and changed the Raspberry with a minipc but nothing changeas…I am desperate!
Here the logs:
Logger: homeassistant.config_entries
Source: components/zha/core/gateway.py:205
First occurred: 16:55:13 (2 occurrences)
Last logged: 16:56:19
Error setting up entry SONOFF Zigbee 3.0 USB Dongle Plus V2 for zha
File “/usr/local/lib/python3.11/site-packages/serial/serialposix.py”, line 322, in open
self.fd = os.open(self.portstr, os.O_RDWR | os.O_NOCTTY | os.O_NONBLOCK)
FileNotFoundError: [Errno 2] No such file or directory: ‘/dev/serial/by-id/usb-ITEAD_SONOFF_Zigbee_3.0_USB_Dongle_Plus_V2_20220816145503-if00’
File “/usr/src/homeassistant/homeassistant/config_entries.py”, line 387, in async_setup
result = await component.async_setup_entry(hass, self)
File “/usr/src/homeassistant/homeassistant/components/zha/init.py”, line 122, in async_setup_entry
await zha_gateway.async_initialize()
File “/usr/src/homeassistant/homeassistant/components/zha/core/gateway.py”, line 220, in async_initialize
raise exc
File “/usr/src/homeassistant/homeassistant/components/zha/core/gateway.py”, line 205, in async_initialize
self.application_controller = await app_controller_cls.new(
File “/usr/local/lib/python3.11/site-packages/zigpy/application.py”, line 219, in new
await app.startup(auto_form=auto_form)
File “/usr/local/lib/python3.11/site-packages/zigpy/application.py”, line 193, in startup
await self.connect()
File “/usr/local/lib/python3.11/site-packages/bellows/zigbee/application.py”, line 131, in connect
self._ezsp = await bellows.ezsp.EZSP.initialize(self.config)
File “/usr/local/lib/python3.11/site-packages/bellows/ezsp/init.py”, line 147, in initialize
await ezsp.connect(use_thread=zigpy_config[conf.CONF_USE_THREAD])
File “/usr/local/lib/python3.11/site-packages/bellows/ezsp/init.py”, line 164, in connect
self._gw = await bellows.uart.connect(self._config, self, use_thread=use_thread)
File “/usr/local/lib/python3.11/site-packages/bellows/uart.py”, line 406, in connect
protocol, connection_done = await thread.run_coroutine_threadsafe(
File “/usr/local/lib/python3.11/site-packages/bellows/uart.py”, line 385, in _connect
transport, protocol = await zigpy.serial.create_serial_connection(
File “/usr/local/lib/python3.11/site-packages/zigpy/serial.py”, line 37, in create_serial_connection
transport, protocol = await pyserial_asyncio.create_serial_connection(
File “/usr/local/lib/python3.11/site-packages/serial_asyncio/init.py”, line 448, in create_serial_connection
serial_instance = serial.serial_for_url(*args, **kwargs)
File “/usr/local/lib/python3.11/site-packages/serial/init.py”, line 90, in serial_for_url
instance.open()
File “/usr/local/lib/python3.11/site-packages/serial/serialposix.py”, line 325, in open
raise SerialException(msg.errno, “could not open port {}: {}”.format(self._port, msg))
serial.serialutil.SerialException: [Errno 2] could not open port /dev/serial/by-id/usb-ITEAD_SONOFF_Zigbee_3.0_USB_Dongle_Plus_V2_20220816145503-if00: [Errno 2] No such file or directory: ‘/dev/serial/by-id/usb-ITEAD_SONOFF_Zigbee_3.0_USB_Dongle_Plus_V2_20220816145503-if00’
Thanks a lot in Advance!
