ZHA not working on VM after Proxmox Update
  • Core2024.2.1
  • Supervisor2024.02.0
  • Operating System11.5
  • Frontend20240207.1
    Proxmox VE 8.1.4
    w/Sky Connect in multi-protocol mode
when I issue a command to a zigbee device i get the following error:
Logger: homeassistant.components.websocket_api.http.connection
Source: components/websocket_api/commands.py:240
Integration: Home Assistant WebSocket API (documentation, issues)
First occurred: 2:57:38 AM (2 occurrences)
Last logged: 3:03:11 AM
[139908157089472] Failed to send request: Failed to deliver message: <EmberStatus.DELIVERY_FAILED: 102>
  File "/usr/src/homeassistant/homeassistant/components/zha/core/cluster_handlers/__init__.py", line 64, in wrap_zigpy_exceptions
    yield
  File "/usr/src/homeassistant/homeassistant/components/zha/core/cluster_handlers/__init__.py", line 84, in wrapper
    return await RETRYABLE_REQUEST_DECORATOR(func)(*args, **kwargs)
  File "/usr/local/lib/python3.12/site-packages/zigpy/util.py", line 131, in retry
    return await func()
  File "/usr/local/lib/python3.12/site-packages/zigpy/zcl/__init__.py", line 377, in request
    return await self._endpoint.request(
  File "/usr/local/lib/python3.12/site-packages/zigpy/endpoint.py", line 253, in request
    return await self.device.request(
  File "/usr/local/lib/python3.12/site-packages/zigpy/device.py", line 327, in request
    await send_request()
  File "/usr/local/lib/python3.12/site-packages/zigpy/application.py", line 833, in request
    await self.send_packet(
  File "/usr/local/lib/python3.12/site-packages/bellows/zigbee/application.py", line 931, in send_packet
    raise zigpy.exceptions.DeliveryError(
zigpy.exceptions.DeliveryError: Failed to deliver message: <EmberStatus.DELIVERY_FAILED: 102>
  File "/usr/src/homeassistant/homeassistant/components/websocket_api/commands.py", line 240, in handle_call_service
    response = await hass.services.async_call(
  File "/usr/src/homeassistant/homeassistant/core.py", line 2279, in async_call
    response_data = await coro
  File "/usr/src/homeassistant/homeassistant/core.py", line 2316, in _execute_service
    return await target(service_call)
  File "/usr/src/homeassistant/homeassistant/helpers/service.py", line 892, in entity_service_call
    single_response = await _handle_entity_call(
  File "/usr/src/homeassistant/homeassistant/helpers/service.py", line 962, in _handle_entity_call
    result = await task
  File "/usr/src/homeassistant/homeassistant/components/zha/cover.py", line 272, in async_open_cover
    res = await self._cover_cluster_handler.up_open()
  File "/usr/src/homeassistant/homeassistant/components/zha/core/cluster_handlers/__init__.py", line 83, in wrapper
    with wrap_zigpy_exceptions():
  File "/usr/local/lib/python3.12/contextlib.py", line 158, in __exit__
    self.gen.throw(value)
  File "/usr/src/homeassistant/homeassistant/components/zha/core/cluster_handlers/__init__.py", line 75, in wrap_zigpy_exceptions
    raise HomeAssistantError(message) from exc
homeassistant.exceptions.HomeAssistantError: Failed to send request: Failed to deliver message: <EmberStatus.DELIVERY_FAILED: 102>
Any help is greatly appreciated
What I coincidence! I bit the bullet and upgraded proxmox to v8 yesterday and had a similar issue with z2mqtt addon. Even after restarting both HA and z2mqtt, The addon kept crashing.
In my case, I simply had to unplug the zigbee coordinator for a minute & plug it back in, before restarting z2mqtt. That fixed all issues for me - hopefully it’ll also work for you.
Thanks,
I tried a lot of things but that wasn’t one of them. Didn’t help unfortunately.
Par for the course after rolling the VM back to a snapshot first then a full backup.
Built a new VM and restored home assistant form a backup TAR.
Issue persists.
You don’t mention how your coordinator’s path is defined in ZHA. If you’re not using serial by id and using something like ACM0, in all probability the path has changed after the update.
ZHA is probably still trying to speak to the coordinator on the old path. Look up the ZHA docs on how to set serial by id instead
