ZHA on windows works first time only
Hi folks!
I’m using ZHA with a ConBeeII (firmware updated) on Windows. With a clean installation of HA I can setup ZHA and pair devices. The first strange things is that I cannot select the COM to use directly but I have to select “enter manually” and type the com name during the latest step.
The problem is that if I stop HA and start it again, ZHA doesn’t work anymore and I get the error [zigpy_deconz.api] No response to 'Command.read_parameter' command with seq id '0x02'.
HA doesn’t start therefore it tries again to run ZHA, but since something is not disposedand port is already busy, I get another error serial.serialutil.SerialException: could not open port 'COM3': PermissionError(13, 'Access is denied.', None, 5).
Another problem is that nothing can fix the issue, neither removing the integration or cleaning manual from config files. I have to clean all database, config folder and deps folders.
Any idea? Thank you!
