With the addition of a couple of zigbee lights, ZHA has started to crash on boot, and prevents HA from starting properly - a few minutes after it reaches the message that it is waiting for zha to start, the web interface become unresponsive. If I reload the page, it shows loading data and repeatedly fails to connect. At this point I have to SSH in and use ha host reboot to get HA starting again, but then the issue happens again. In the period before the crash, I managed to disable the ZHA integration and shutdown. I disconnected the CC2531, and started HA again and this enabled me to use the other functions aside from Zigbee.
I expect that the issue is the old TI CC2531 Zigbee USB dongle I am using. I am waiting a new CC2652 to arrive in the next week. When I get that I want to migrate from the CC2531 - however, I am not sure I can do this if ZHA crashes HA with the CC2531 plugged in.
Luckily I do have a backup file I took from ZHA a couple of days ago. Can I use this to do the migration without the CC2531 attached, or without ZHA integration running?
Identified the device in /dev/ - in my case it is called /dev/tty.usbmodemXX where the XX changes each time I connect the CC2531
Installed zigpy_znp (pip3 install zigpy_znp)
I could then use the zigpy_znp commands to get a network backup from the CC2531. According to the doc linked to above, I can then restore this to the CC2652 as it is in Open Coordinator Backup Format.
Yes - my problem was that ZHA would crash when I had the CC2351 attached, so I couldn’t see a pathway to use ZHA to do the migration. Manually backing up and restoring was the solution for me in the end.
The backup/restore process linked to in the post above worked great!
After restoring the network backup to the new stick, I then deleted the existing ZHA integration in HA, connected the new zzh stick to HA, and added ZHA integration again. All my Zigbee devices were there, although I did need to rename them again, and update my dashboards, scenes and automations. All done now, and seeing a much smoother zigbee experience, and HA booting much faster!
