hi there.
I am using ha in vmware vm and i am running the skyconnect stick. zigbee network just setup, was runnig well. HAOS is up to date.
I did connect a power nous power plug switch with powermeter:
Quirk: zhaquirks.tuya.ts011f_plug.Plug
I did connect a Lightify Switch Mini:
Quirk: zhaquirks.osram.switchmini.OsramSwitchMini
In fact its actually a ledvance device, but only rebranded i believe
(I plan to set it up using a blueprint: zha-deconz-zigbee2mqtt-osram-smart-switch-mini-universal-blueprint-all-actions-double-click-events-control-lights-media-players-and-more-with-hooks)
But now I encounter strange behaviour:
If I press the down button on the osram device, it turns off the nous power plug (Does not turn on with second press).
In zha it just states:
OSRAM Lightify Switch Mini Remote Button Short Press - Button 3 event was fired
The other buttons seem to have no effect so far. They use a rather special command, although (for a new, unconfigured device)
“OSRAM Lightify Switch Mini Move To Color Temp event was fired with parameters: {‘color_temp_mireds’: 370, ‘transition_time’: 10, ‘options_mask’: None, ‘options_override’: None}”
“OSRAM Lightify Switch Mini Remote Button Short Press - Button 2 event was fired with parameters: {‘level’: 254, ‘transition_time’: 10}”
I just do not know why/how, because both devices are right out of the box…I did absolutely no configuration to both devices. It seems to me that zha interprets/initialises the Osram in a strange way?
What should i do? I have got more devices of the same types, too… Is this just random cooincidence? Can I kind of reset the actions/link
Assistance is very much appreciated…
