ZHA OTA Firmware Update / Upgrade
Yes there will be the option to enable file updates again ( an addition flag that is default false because it is not fully safe: potentially devices can load firmware that is not for them).
But there will be a new option as well: load OTA files from the Z2M community archive. This one is safe to use.
anyone knows in the meantime how to do the upgrade again? still have 2 devices where did not have time to do the upgrade, any command? not sure what was run on background. thx
Hey all,
quick question as Iā€™m trying to update my IKEA 4 button remote (IKEA of Sweden Remote Control N2). The update starts and then fails at different progress levels. Since its a battery device, Iā€™m pressing a button every now and then to make sure, it remains alive and connected.
Heres the debug log. Possibly one can point me in a direction.
2024-03-01 09:18:03.967 DEBUG (MainThread) [zigpy.zcl] [0x7EEA:1:0x0019] Sending reply: ImageBlockResponseCommand(status=<Status.SUCCESS: 0>, manufacturer_code=4476, image_type=4555, file_version=33816581, file_offset=3780, image_data=b'(\x90\x07F\
2024-03-01 09:18:03.967 DEBUG (MainThread) [zigpy.zcl] [0x7EEA:1:0x0019] no 'image_block' OTA command handler for 'IKEA of Sweden Remote Control N2': ImageBlockCommand(field_control=<FieldControl: 0>, manufacturer_code=4476, image_type=4555, file_v
2024-03-01 09:18:04.034 INFO (MainThread) [zigpy.device] [0x7eea] OTA upgrade progress: (3780 / 218698): 1.7284%
2024-03-01 09:18:05.705 DEBUG (MainThread) [zigpy.util] Tries remaining: 2
2024-03-01 09:18:05.706 DEBUG (MainThread) [zigpy.zcl] [0x526D:11:0x0006] Sending request header: ZCLHeader(frame_control=FrameControl<0x01>(frame_type=<FrameType.CLUSTER_COMMAND: 1>, is_manufacturer_specific=False, direction=<Direction.Client_to_S
2024-03-01 09:18:05.706 DEBUG (MainThread) [zigpy.zcl] [0x526D:11:0x0006] Sending request: off()
2024-03-01 09:18:05.926 INFO (MainThread) [zigpy.device] [0x7eea] OTA upgrade progress: (3780 / 218698): 1.7284%
2024-03-01 09:18:06.043 DEBUG (MainThread) [zigpy.application] Received a packet: ZigbeePacket(timestamp=datetime.datetime(2024, 3, 1, 8, 18, 6, 43071, tzinfo=datetime.timezone.utc), src=AddrModeAddress(addr_mode=<AddrMode.NWK: 2>, address=0x7EEA),
2024-03-01 09:18:06.043 DEBUG (MainThread) [zigpy.zcl] [0x7EEA:1:0x0019] Received ZCL frame: b'\x010\x03\x00|\x11\xcb\x11\x05\x00\x04\x02\xc4\x0e\x00\x00?'
2024-03-01 09:18:06.043 DEBUG (MainThread) [zigpy.zcl] [0x7EEA:1:0x0019] Decoded ZCL frame header: ZCLHeader(frame_control=FrameControl<0x01>(frame_type=<FrameType.CLUSTER_COMMAND: 1>, is_manufacturer_specific=0, direction=<Direction.Client_to_Serv
2024-03-01 09:18:06.044 DEBUG (MainThread) [zigpy.zcl] [0x7EEA:1:0x0019] Decoded ZCL frame: Ota:ImageBlockCommand(field_control=<FieldControl: 0>, manufacturer_code=4476, image_type=4555, file_version=33816581, file_offset=3780, maximum_data_size=6
2024-03-01 09:18:06.044 DEBUG (MainThread) [zigpy.zcl] [0x7EEA:1:0x0019] Received command 0x03 (TSN 48): ImageBlockCommand(field_control=<FieldControl: 0>, manufacturer_code=4476, image_type=4555, file_version=33816581, file_offset=3780, maximum_da
2024-03-01 09:18:06.044 DEBUG (MainThread) [zigpy.device] [0x7eea] OTA image_block handler for 'IKEA of Sweden Remote Control N2': field_control=0, manufacturer_id=4476, image_type=4555, file_version=33816581, file_offset=3780, max_data_size=63, re
2024-03-01 09:18:06.044 DEBUG (MainThread) [zigpy.zcl] [0x7EEA:1:0x0019] Sending reply header: ZCLHeader(frame_control=FrameControl<0x19>(frame_type=<FrameType.CLUSTER_COMMAND: 1>, is_manufacturer_specific=False, direction=<Direction.Server_to_Clie
2024-03-01 09:18:06.045 DEBUG (MainThread) [zigpy.zcl] [0x7EEA:1:0x0019] Sending reply: ImageBlockResponseCommand(status=<Status.SUCCESS: 0>, manufacturer_code=4476, image_type=4555, file_version=33816581, file_offset=3780, image_data=b'(\x90\x07F\
2024-03-01 09:18:06.045 DEBUG (MainThread) [zigpy.zcl] [0x7EEA:1:0x0019] no 'image_block' OTA command handler for 'IKEA of Sweden Remote Control N2': ImageBlockCommand(field_control=<FieldControl: 0>, manufacturer_code=4476, image_type=4555, file_v
2024-03-01 09:18:06.943 DEBUG (MainThread) [zigpy.application] Received a packet: ZigbeePacket(timestamp=datetime.datetime(2024, 3, 1, 8, 18, 6, 943646, tzinfo=datetime.timezone.utc), src=AddrModeAddress(addr_mode=<AddrMode.NWK: 2>, address=0x7EEA)
2024-03-01 09:18:06.944 DEBUG (MainThread) [zigpy.zcl] [0x7EEA:1:0x0019] Received ZCL frame: b'\x011\x03\x00|\x11\xcb\x11\x05\x00\x04\x02\xc4\x0e\x00\x00?'
2024-03-01 09:18:06.944 DEBUG (MainThread) [zigpy.zcl] [0x7EEA:1:0x0019] Decoded ZCL frame header: ZCLHeader(frame_control=FrameControl<0x01>(frame_type=<FrameType.CLUSTER_COMMAND: 1>, is_manufacturer_specific=0, direction=<Direction.Client_to_Serv
2024-03-01 09:18:06.944 DEBUG (MainThread) [zigpy.zcl] [0x7EEA:1:0x0019] Decoded ZCL frame: Ota:ImageBlockCommand(field_control=<FieldControl: 0>, manufacturer_code=4476, image_type=4555, file_version=33816581, file_offset=3780, maximum_data_size=6
2024-03-01 09:18:06.944 DEBUG (MainThread) [zigpy.zcl] [0x7EEA:1:0x0019] Received command 0x03 (TSN 49): ImageBlockCommand(field_control=<FieldControl: 0>, manufacturer_code=4476, image_type=4555, file_version=33816581, file_offset=3780, maximum_da
2024-03-01 09:18:06.945 DEBUG (MainThread) [zigpy.device] [0x7eea] OTA image_block handler for 'IKEA of Sweden Remote Control N2': field_control=0, manufacturer_id=4476, image_type=4555, file_version=33816581, file_offset=3780, max_data_size=63, re
2024-03-01 09:18:06.945 DEBUG (MainThread) [zigpy.zcl] [0x7EEA:1:0x0019] Sending reply header: ZCLHeader(frame_control=FrameControl<0x19>(frame_type=<FrameType.CLUSTER_COMMAND: 1>, is_manufacturer_specific=False, direction=<Direction.Server_to_Clie
2024-03-01 09:18:06.945 DEBUG (MainThread) [zigpy.zcl] [0x7EEA:1:0x0019] Sending reply: ImageBlockResponseCommand(status=<Status.SUCCESS: 0>, manufacturer_code=4476, image_type=4555, file_version=33816581, file_offset=3780, image_data=b'(\x90\x07F\
2024-03-01 09:18:06.946 DEBUG (MainThread) [zigpy.zcl] [0x7EEA:1:0x0019] no 'image_block' OTA command handler for 'IKEA of Sweden Remote Control N2': ImageBlockCommand(field_control=<FieldControl: 0>, manufacturer_code=4476, image_type=4555, file_v
2024-03-01 09:17:53.567 DEBUG (MainThread) [zigpy.device] [0x7eea] OTA image_block handler for 'IKEA of Sweden Remote Control N2': field_control=0, manufacturer_id=4476, image_type=4555, file_version=33816581, file_offset=3654, max_data_size=63, re
2024-03-01 09:17:53.567 DEBUG (MainThread) [zigpy.zcl] [0x7EEA:1:0x0019] Sending reply header: ZCLHeader(frame_control=FrameControl<0x19>(frame_type=<FrameType.CLUSTER_COMMAND: 1>, is_manufacturer_specific=False, direction=<Direction.Server_to_Clie
2024-03-01 09:17:53.567 DEBUG (MainThread) [zigpy.zcl] [0x7EEA:1:0x0019] Sending reply: ImageBlockResponseCommand(status=<Status.SUCCESS: 0>, manufacturer_code=4476, image_type=4555, file_version=33816581, file_offset=3654, image_data=b'jF\x19F\t\x
2024-03-01 09:17:53.568 DEBUG (MainThread) [zigpy.zcl] [0x7EEA:1:0x0019] no 'image_block' OTA command handler for 'IKEA of Sweden Remote Control N2': ImageBlockCommand(field_control=<FieldControl: 0>, manufacturer_code=4476, image_type=4555, file_v
2024-03-01 09:17:53.568 INFO (MainThread) [zigpy.device] [0x7eea] OTA upgrade progress: (3654 / 218698): 1.6708%
2024-03-01 09:17:55.088 ERROR (MainThread) [homeassistant.components.websocket_api.http.connection] [139738348399040] Failed to send request: device did not respond
  File "/usr/src/homeassistant/homeassistant/components/websocket_api/commands.py", line 240, in handle_call_service
    response = await hass.services.async_call(
  File "/usr/src/homeassistant/homeassistant/core.py", line 2279, in async_call
    response_data = await coro
  File "/usr/src/homeassistant/homeassistant/core.py", line 2316, in _execute_service
    return await target(service_call)
  File "/usr/src/homeassistant/homeassistant/helpers/service.py", line 917, in entity_service_call
    raise result from None
  File "/usr/src/homeassistant/homeassistant/helpers/entity.py", line 1540, in async_request_call
    return await coro
  File "/usr/src/homeassistant/homeassistant/helpers/service.py", line 962, in _handle_entity_call
    result = await task
  File "/usr/src/homeassistant/homeassistant/components/light/__init__.py", line 639, in async_handle_light_off_service
    await light.async_turn_off(**filter_turn_off_params(light, params))
  File "/usr/src/homeassistant/homeassistant/components/zha/light.py", line 471, in async_turn_off
    result = await self._on_off_cluster_handler.off()
  File "/usr/src/homeassistant/homeassistant/components/zha/core/cluster_handlers/__init__.py", line 83, in wrapper
    with wrap_zigpy_exceptions():
  File "/usr/local/lib/python3.12/contextlib.py", line 158, in __exit__
    self.gen.throw(value)
  File "/usr/src/homeassistant/homeassistant/components/zha/core/cluster_handlers/__init__.py", line 66, in wrap_zigpy_exceptions
    raise HomeAssistantError(
homeassistant.exceptions.HomeAssistantError: Failed to send request: device did not respond
2024-03-01 09:17:55.574 DEBUG (MainThread) [zigpy.application] Received a packet: ZigbeePacket(timestamp=datetime.datetime(2024, 3, 1, 8, 17, 55, 574693, tzinfo=datetime.timezone.utc), src=AddrModeAddress(addr_mode=<AddrMode.NWK: 2>, address=0x7EEA
2024-03-01 09:17:55.575 DEBUG (MainThread) [zigpy.zcl] [0x7EEA:1:0x0019] Received ZCL frame: b'\x01,\x03\x00|\x11\xcb\x11\x05\x00\x04\x02\x85\x0e\x00\x00?'
2024-03-01 09:17:55.575 DEBUG (MainThread) [zigpy.zcl] [0x7EEA:1:0x0019] Decoded ZCL frame header: ZCLHeader(frame_control=FrameControl<0x01>(frame_type=<FrameType.CLUSTER_COMMAND: 1>, is_manufacturer_specific=0, direction=<Direction.Client_to_Serv
2024-03-01 09:17:55.575 DEBUG (MainThread) [zigpy.zcl] [0x7EEA:1:0x0019] Decoded ZCL frame: Ota:ImageBlockCommand(field_control=<FieldControl: 0>, manufacturer_code=4476, image_type=4555, file_version=33816581, file_offset=3717, maximum_data_size=6
2024-03-01 09:17:55.575 DEBUG (MainThread) [zigpy.zcl] [0x7EEA:1:0x0019] Received command 0x03 (TSN 44): ImageBlockCommand(field_control=<FieldControl: 0>, manufacturer_code=4476, image_type=4555, file_version=33816581, file_offset=3717, maximum_da
Yes, it sais ā€œdevice not reachableā€ and thus Iā€™m pressing a button on the remote about every 30 seconds.
Also tried updating via service call and got another error message:
2024-03-01 09:59:41.191 DEBUG (MainThread) [zigpy.zcl] [0x7EEA:1:0x0019] Sending reply: query_next_image_response(status=<Status.NO_IMAGE_AVAILABLE: 152>, manufacturer_code=None, image_type=None, file_version=None, image_size=None)
2024-03-01 09:59:44.192 DEBUG (MainThread) [zigpy.application] Received a packet: ZigbeePacket(timestamp=datetime.datetime(2024, 3, 1, 8, 59, 44, 192026, tzinfo=datetime.timezone.utc), src=AddrModeAddress(addr_mode=<AddrMode.NWK: 2>, address=0x7EEA
2024-03-01 09:59:44.192 DEBUG (MainThread) [zigpy.zcl] [0x7EEA:1:0x0019] Received ZCL frame: b'\x01\x01\x01\x01|\x11\xcb\x11$\x00\x01\x00\x01\x00'
2024-03-01 09:59:44.192 DEBUG (MainThread) [zigpy.zcl] [0x7EEA:1:0x0019] Decoded ZCL frame header: ZCLHeader(frame_control=FrameControl<0x01>(frame_type=<FrameType.CLUSTER_COMMAND: 1>, is_manufacturer_specific=0, direction=<Direction.Client_to_Serv
2024-03-01 09:59:44.193 DEBUG (MainThread) [zigpy.zcl] [0x7EEA:1:0x0019] Decoded ZCL frame: Ota:QueryNextImageCommand(field_control=<FieldControl.HardwareVersion: 1>, manufacturer_code=4476, image_type=4555, current_file_version=65572, hardware_ver
2024-03-01 09:59:44.193 DEBUG (MainThread) [zigpy.zcl] [0x7EEA:1:0x0019] Received command 0x01 (TSN 1): QueryNextImageCommand(field_control=<FieldControl.HardwareVersion: 1>, manufacturer_code=4476, image_type=4555, current_file_version=65572, hard
2024-03-01 09:59:44.193 DEBUG (MainThread) [zigpy.zcl] [0x7EEA:1:0x0019] OTA query_next_image handler for 'IKEA of Sweden Remote Control N2': field_control=1, manufacturer_id=4476, image_type=4555, current_file_version=65572, hardware_version=1, mo
2024-03-01 09:59:44.193 DEBUG (MainThread) [zigpy.zcl] [0x7EEA:1:0x0019] OTA image version: 33816581, size: 218698. Update needed: True
2024-03-01 09:59:44.194 DEBUG (MainThread) [zigpy.zcl] [0x7EEA:1:0x0019] Sending reply header: ZCLHeader(frame_control=FrameControl<0x19>(frame_type=<FrameType.CLUSTER_COMMAND: 1>, is_manufacturer_specific=False, direction=<Direction.Server_to_Clie
2024-03-01 09:59:44.194 DEBUG (MainThread) [zigpy.zcl] [0x7EEA:1:0x0019] Sending reply: query_next_image_response(status=<Status.NO_IMAGE_AVAILABLE: 152>, manufacturer_code=None, image_type=None, file_version=None, image_size=None)
2024-03-01 09:59:45.035 ERROR (MainThread) [homeassistant.helpers.script.websocket_api_script] websocket_api script: Error executing script. Unexpected error for call_service at pos 1: Request failed after 5 attempts: <Status.APS_NO_ACK: 183>
  File "/usr/src/homeassistant/homeassistant/helpers/script.py", line 485, in _async_step
    await getattr(self, handler)()
  File "/usr/src/homeassistant/homeassistant/helpers/script.py", line 723, in _async_call_service_step
    response_data = await self._async_run_long_action(
  File "/usr/src/homeassistant/homeassistant/helpers/script.py", line 685, in _async_run_long_action
    return long_task.result()
  File "/usr/src/homeassistant/homeassistant/helpers/service.py", line 993, in _async_admin_handler
    await result
  File "/usr/src/homeassistant/homeassistant/components/zha/websocket_api.py", line 1363, in issue_zigbee_cluster_command
    await zha_device.issue_cluster_command(
  File "/usr/src/homeassistant/homeassistant/components/zha/core/device.py", line 839, in issue_cluster_command
    response = await getattr(cluster, commands[command].name)(*args)
  File "/usr/local/lib/python3.12/site-packages/zigpy/zcl/__init__.py", line 415, in reply
    return await self._endpoint.reply(
  File "/usr/local/lib/python3.12/site-packages/zigpy/endpoint.py", line 278, in reply
    return await self.device.reply(
  File "/usr/local/lib/python3.12/site-packages/zigpy/device.py", line 488, in reply
    return await self.request(
  File "/usr/local/lib/python3.12/site-packages/zigpy/device.py", line 322, in request
    await send_request()
  File "/usr/local/lib/python3.12/site-packages/zigpy/application.py", line 833, in request
    await self.send_packet(
  File "/usr/local/lib/python3.12/site-packages/zigpy_znp/zigbee/application.py", line 1100, in send_packet
    raise DeliveryError(
zigpy.exceptions.DeliveryError: Request failed after 5 attempts: <Status.APS_NO_ACK: 183>
2024-03-01 09:59:45.041 ERROR (MainThread) [homeassistant.components.websocket_api.http.connection] [139738266885696] Error handling message: Unknown error (unknown_error) Sebastian from 192.168.25.101 (Mozilla/5.0 (Windows NT 10.0; Win64; x6
  File "/usr/src/homeassistant/homeassistant/components/websocket_api/decorators.py", line 26, in _handle_async_response
    await func(hass, connection, msg)
  File "/usr/src/homeassistant/homeassistant/components/websocket_api/commands.py", line 795, in handle_execute_script
    script_result = await script_obj.async_run(
  File "/usr/src/homeassistant/homeassistant/helpers/script.py", line 1600, in async_run
    return await asyncio.shield(run.async_run())
  File "/usr/src/homeassistant/homeassistant/helpers/script.py", line 435, in async_run
    await self._async_step(log_exceptions=False)
  File "/usr/src/homeassistant/homeassistant/helpers/script.py", line 487, in _async_step
    self._handle_exception(
  File "/usr/src/homeassistant/homeassistant/helpers/script.py", line 512, in _handle_exception
    raise exception
Thanks for your help.
best
2024.3.0 is out! Anyone manage to get the new z2m OTA to work?
ie using:
zha:
  zigpy_config:
    ota:
      # Download the index over HTTPS
      z2m_remote_index: https://raw.githubusercontent.com/Koenkk/zigbee-OTA/master/index.json
Yes, it works! I have one Xiaomi thermometer/hygrometer with Zigbee firmware. I updated my config this morning as described ba moelito and the next time i open Home Assistant it showed an available update in ZHA. The update took about 15 minutes. Happy user! :slight_smile:
OMG, yes it works!
I was never able to get it to work before. Now I got a notification that an update is available and the process was click and go perfect!
Some screenshots:
2024-03-09 OTA progress
Whatā€™s curious though, is that this particular device isnā€™t present in the Z2M OTA repository on https://raw.githubusercontent.com/Koenkk/zigbee-OTA/master/index.json. Where did the OTA update come from? Not that Iā€™m unhappy with it, of course not, Iā€™d just like to understand everything.
Anyone had anything brick via an update through ZHA? I have 2 Fyrtur IKEA blinds and one of them did an update, dropped off the network, and now wonā€™t join whatsoever no matter how often I resetā€¦ Thinking Iā€™m gunna buy a new one to replace it and bust this one apart to debug but wanted to see if anyone had a similar experience.
Can someone confirm if new firmware updates will infinitly wait for a manual decision to either install or skip?
Or will they automatically install after a while (zigbee devices typically solicit for updates a few times per day)?
I didnā€™t enable OTA updates yet as I donā€™t want to update specific devices
Best Eric
PS: The official ZHA documentation is not updated (yet?!). But I think this issue describes the new config settings:
zigpy:
  ota:
    # It's enabled by default
    enabled: true
    # Periodically send out a network-wide (including end devices!) image notification
    broadcast_enabled: true
    broadcast_initial_delay: 14400
    broadcast_interval: 14400
    # You probably do not need this, it's for development
    advanced_ota_dir: /path/to/raw/ota/files
    allow_advanced_ota_dir: ...
    # Points to Z2M OTA `index.json` if stored locally
    z2m_local_index: /path/to/z2m-ota/index.json
    # Points to Z2M OTA `index.json` URL
    z2m_remote_index: "https://raw.githubusercontent.com/Koenkk/zigbee-OTA/master/index.json"
Tuya devices are usually sold as white label products that are rebranded under many different names and models.
Be careful though as flashing wrong firmware will brick devices.
I have similar issues as @mrmontesa . Plus, ZHA crashes after the OTA of the Styrbar remote fails.
Any advice?
Any updates on this issue? Iā€™ve moved to 2023.4 home assistant core and the problems persist, no OTA updates of any type.
I guess it depends on whether the OTA file is in the repository.
I have a different problem. I was prompted about availability of an update for my Aqara TRV. I installed it successfully and the version number increased. Afterwards HA says thereā€™s another update, with an even higher version number. Iā€™ve tried installing it many times, but I always end up with the version from after the first update. Thereā€™s no error, just doesnā€™t work.
My Zigbee devices stopped working.
After upgrading the firmware on my Skyconnect it works again.
Looks like the ZHA-integration does not find new OTA firmware for the Skyconnect and I canā€™t find in the documentation about Skyconnect firmware update config setting.
How do I get HA /ZHA to automatically find and notify me when a new firmware for the Skyconnect is published?
So is ZHA OTA update folder now working? I am trying to roll back my Aqara switches that I just got as the 5 button Ikea remote keeps turning them on and off.
Hi! I have downloaded a file with a firmware upgrade from Legrand (a top quality vendor in Europe), but I donā€™t know how to send it to the device. Itā€™s a Zigbee 3.0 shutter switch. Since itā€™s not a public download (requires registration), I donā€™t think it can be included in the aforementioned firmware repository.
Considering that Iā€™m running 2024.2.1, what are my options?
Thanks a lot!
Just wanted to mention that I got the same:
Firmware update IKEA N2 remote does not conclude - Configuration / Zigbee - Home Assistant Community (home-assistant.io)
Did you find a solution?
I didnā€™t find a solution for this problem with my Aqara TRVā€™s. I also donā€™t know where to start looking.
Firmware upgrade via ZHA of the device (Ikea example) is working but sooo slow.
Updated a Ikea Dimmer today and it took more the 6 hours. Is there something I can do to speedup the firmware updates. I use a Sonoff USB Zigbee coordinator to connect to devices,
If the device is far away from the coordinator it will take longer, but zigbee updates are slow, tipically around 1h.
