Hi @victorigualada , I just found from the logs that
" cluster 25 not found on endpoint 1 while issuing command 0 with args [0, 100] " .
When i go to plug’s signature in Manage Zigbee Device, i see the below signature:
(Also the device is from a different manufacturer - https://www.amazon.co.uk/gp/product/B09N43BBC1/ref=ppx_yo_dt_b_asin_title_o00_s01?ie=UTF8&th=1 but based on Tuya TS011F.
below ia the complete node descriptor:
“node_descriptor”: “NodeDescriptor(logical_type=<LogicalType.Router: 1>, complex_descriptor_available=0, user_descriptor_available=0, reserved=0, aps_flags=0, frequency_band=<FrequencyBand.Freq2400MHz: 8>, mac_capability_flags=<MACCapabilityFlags.AllocateAddress|RxOnWhenIdle|MainsPowered|FullFunctionDevice: 142>, manufacturer_code=4660, maximum_buffer_size=108, maximum_incoming_transfer_size=0, server_mask=11264, maximum_outgoing_transfer_size=0, descriptor_capability_field=<DescriptorCapability.NONE: 0>, *allocate_address=True, *is_alternate_pan_coordinator=False, *is_coordinator=False, *is_end_device=False, *is_full_function_device=True, *is_mains_powered=True, *is_receiver_on_when_idle=True, *is_router=True, *is_security_capable=False)”,
