I am using a Conbee II and have it added via a zha integration.
zha:
usb_path: /dev/ttyACM0
database_path: /home/me/.homeassistant/zigbee.db
radio_type: deconz
I’m trying to add devices to my zigbee network, but I’m having trouble. From the docs I see I need to call the zha.permit service. When I call the service, I get this error:
zigpy.exceptions.DeliveryError: [0xfffc:0:0x0036] failed transmission request: 225
Log Details (ERROR)
Sat Oct 12 2019 22:07:17 GMT-0400 (Eastern Daylight Time)
File "/home/me/homeassistant/lib/python3.7/site-packages/homeassistant/components/websocket_api/commands.py", line 130, in handle_call_service
connection.context(msg),
File "/home/me/homeassistant/lib/python3.7/site-packages/homeassistant/core.py", line 1234, in async_call
await asyncio.shield(self._execute_service(handler, service_call))
File "/home/me/homeassistant/lib/python3.7/site-packages/homeassistant/core.py", line 1259, in _execute_service
await handler.func(service_call)
File "/home/me/homeassistant/lib/python3.7/site-packages/homeassistant/helpers/service.py", line 405, in admin_handler
await hass.async_add_job(service_func, call)
File "/home/me/homeassistant/lib/python3.7/site-packages/homeassistant/components/zha/api.py", line 514, in permit
await application_controller.permit(time_s=duration, node=ieee)
File "/home/me/homeassistant/lib/python3.7/site-packages/zigpy/application.py", line 184, in permit
broadcast_address=t.BroadcastAddress.ALL_ROUTERS_AND_COORDINATOR,
File "/home/me/homeassistant/lib/python3.7/site-packages/zigpy/device.py", line 255, in broadcast
broadcast_address=broadcast_address,
File "/home/me/homeassistant/lib/python3.7/site-packages/zigpy_deconz/zigbee/application.py", line 151, in broadcast
dst_ep, cluster, r)
Do I need to provide Service Data with the call? If so, how do I find the correct data? If I use “Fill Example Data”, I get a device not found error.
Any advice is greatly appreciated. Thank you.
Install info:
arch | x86_64 |
dev | false |
docker | false |
hassio | false |
os_name | Linux |
python_version | 3.7.4 |
version | 0.99.2 |
virtualenv | true |
Lovelace
mode auto-gen
