Zha.permit results in NotImplementedError
I’m trying to add a bosch smart home radiator thermostat ii using zha.permit method. However, I get an “Unknown error” when calling the service. Going through the logs, I see:
    [546780908096] Error handling message: Unknown error (unknown_error) Mario from fe80::802:8aa7:93bb:82ee (Mozilla/5.0 (Macintosh; Intel Mac OS X 10.15; rv:109.0) Gecko/20100101 Firefox/117.0)
    [546775468480] Error handling message: Unknown error (unknown_error) Mario from 192.168.50.1 (Mozilla/5.0 (Linux; Android 13; SM-S918B Build/TP1A.220624.014; wv) AppleWebKit/537.36 (KHTML, like Gecko) Version/4.0 Chrome/117.0.0.0 Mobile Safari/537.36 Home Assistant/2023.9.2-11226 (Android 13; SM-S918B))
  File "/usr/src/homeassistant/homeassistant/components/websocket_api/decorators.py", line 26, in _handle_async_response
    await func(hass, connection, msg)
  File "/usr/src/homeassistant/homeassistant/components/websocket_api/commands.py", line 740, in handle_execute_script
    script_result = await script_obj.async_run(msg.get("variables"), context=context)
  File "/usr/src/homeassistant/homeassistant/helpers/script.py", line 1579, in async_run
    return await asyncio.shield(run.async_run())
  File "/usr/src/homeassistant/homeassistant/helpers/script.py", line 420, in async_run
    await self._async_step(log_exceptions=False)
  File "/usr/src/homeassistant/homeassistant/helpers/script.py", line 470, in _async_step
    self._handle_exception(
  File "/usr/src/homeassistant/homeassistant/helpers/script.py", line 493, in _handle_exception
    raise exception
  File "/usr/src/homeassistant/homeassistant/helpers/script.py", line 468, in _async_step
    await getattr(self, handler)()
  File "/usr/src/homeassistant/homeassistant/helpers/script.py", line 704, in _async_call_service_step
    response_data = await self._async_run_long_action(
  File "/usr/src/homeassistant/homeassistant/helpers/script.py", line 666, in _async_run_long_action
    return long_task.result()
  File "/usr/src/homeassistant/homeassistant/core.py", line 1969, in async_call
    response_data = await coro
  File "/usr/src/homeassistant/homeassistant/core.py", line 2006, in _execute_service
    return await target(service_call)
  File "/usr/src/homeassistant/homeassistant/helpers/service.py", line 980, in admin_handler
    await result
  File "/usr/src/homeassistant/homeassistant/components/zha/websocket_api.py", line 1256, in permit
    await application_controller.permit_with_key(
  File "/usr/local/lib/python3.11/site-packages/zigpy_deconz/zigbee/application.py", line 109, in permit_with_key
    raise NotImplementedError()
NotImplementedError
I’m using a ConBee II Overview as an adapter. Do i have incompatible hardware?
seems I’m having the same hardware and error. Any solution yet?
Help would be greatly appreciated!
I have the same error for zha.permit by adding Bosch Thermostat 2.
Hope somebody has an idea to solve it.
