at home I use a Sonoff Zigbee Bridge Pro with Tasmota as a Zigbee Coordinator. This works well so far, so I can control several Makre Tuya sockets via ZHA.
But I have some problems with my new Philips Hue Bulbs (G93, ST64 & A60). I can pair all bulbs succesfully but i can only change the switch state and not the dimming or color temperature.
As you can see in the image below, the options are available. But the bulbs do not respond when I change the values with the slider.
I think both those sliders control the start-up state of the light after a power loss - you can’t use them to control the state of the bulb while it’s in use.
First of all, I agree that sliders here are just for configuring the start-up state. But I don’t understand why the sliders are missing from the controls. From the Philips Hue app, I can control the light bulb as expected.
@Hedda Thanks for your assistance.
I have reset and paired the bulbs several times in a distance of 20cm to 1 m, but the problem is still there.
I currently have a custom quirk for the tuya thermostat. But I can’t find a quirk for my philips hue bulbs. It seems like there are no quirks for this lamp.
In Homeassistant, I get the following device description for the light Bulb. I am not sure if this is correct.
LTO001
von Signify Netherlands B.V.
Firmware: 0x01001506
