Hi i have a problem with the “transfer” of registered zigbee devices from one home assistant to another, using the same coordinator. because it makes me do the backup, but then it restores only 1 device out of 10 (and not even because it loses the name and everything)
Are you talking about the nvm backup ? That only holds the network keys of the devices in the mesh. You need to do a full HA backp/restore to transfer the names etc…
ah, is there any way to backup networks? without doing a full backup.
I think if you also copy the “zigbee.db” file too as it adds some more stuff, but not names?`
Maybe check out all the znp restore instructions from zha-toolkit readme.md file:
Could also try asking in the zha-toolkit thread if you need further help with that:
For more technical reference can read more on zigpy-cli and open-coordinator-backup
