**Is your feature request related to a problem? Please describe.**
I can not ca…pture any used energy measurements in my home assistant instance's history due to missing energy reporting. I also miss the feature to be able to get the device temperature, set the power outage memory setting, turn the indicator led on and off on the device, and set the operation mode to coupled/decoupled.
**Describe the solution you'd like**
An added attribute publishing the _sum of consumed energy_ (kWh) as well as an _instantaneous power measurement_. Moreover, a _device temperature_ report, being able to set the _power outage memory_, enable/disable the _indicator led_, and choosing the _operation mode._
<details>
<summary>Device signature</summary>
```yaml
"node_descriptor": "NodeDescriptor(logical_type=<LogicalType.Router: 1>, complex_descriptor_available=0, user_descriptor_available=0, reserved=0, aps_flags=0, frequency_band=<FrequencyBand.Freq2400MHz: 8>, mac_capability_flags=<MACCapabilityFlags.AllocateAddress|RxOnWhenIdle|MainsPowered|FullFunctionDevice: 142>, manufacturer_code=4447, maximum_buffer_size=127, maximum_incoming_transfer_size=100, server_mask=11264, maximum_outgoing_transfer_size=100, descriptor_capability_field=<DescriptorCapability.NONE: 0>, *allocate_address=True, *is_alternate_pan_coordinator=False, *is_coordinator=False, *is_end_device=False, *is_full_function_device=True, *is_mains_powered=True, *is_receiver_on_when_idle=True, *is_router=True, *is_security_capable=False)",
"endpoints": {
"1": {
"profile_id": 260,
"device_type": "0x0000",
"in_clusters": [
"0x0000",
"0x0002",
"0x0003",
"0x0004",
"0x0005",
"0x0006",
"0x0009",
"0x0012",
"0x0702",
"0xfcc0"
"out_clusters": [
"0x000a",
"0x0019"
"2": {
"profile_id": 260,
"in_clusters": [
"0x0000",
"0x0003",
"0x0004",
"0x0005",
"0x0006",
"0x0012",
"0xfcc0"
"out_clusters": []
"21": {
"profile_id": 260,
"device_type": "0x0100",
"in_clusters": [
"0x000c"
"out_clusters": []
"31": {
"profile_id": 260,
"in_clusters": [
"0x000c"
"out_clusters": []
"41": {
"profile_id": 260,
"in_clusters": [
"0x0012"
"out_clusters": []
"42": {
"profile_id": 260,
"in_clusters": [
"0x0012"
"out_clusters": []
"51": {
"profile_id": 260,
"in_clusters": [
"0x0012"
"out_clusters": []
"61": {
"profile_id": 260,
"in_clusters": [
"0x0012"
"out_clusters": []
"242": {
"profile_id": 41440,
"device_type": "0x0061",
"in_clusters": [],
"out_clusters": [
"0x0021"
"manufacturer": "LUMI",
"model": "lumi.switch.n2aeu1",
"class": "zhaquirks.xiaomi.aqara.opple_switch.XiaomiOpple2ButtonSwitchFace2"
</details>
<details>
<summary>Diagnostic information</summary>
```yaml
"home_assistant": {
"installation_type": "Home Assistant OS",
"version": "2023.3.1",
"dev": false,
"hassio": true,
"virtualenv": false,
"python_version": "3.10.10",
"docker": true,
"arch": "x86_64",
"timezone": "Europe/Stockholm",
"os_name": "Linux",
"os_version": "5.15.90",
"supervisor": "2023.01.1",
"host_os": "Home Assistant OS 9.5",
"docker_version": "20.10.22",
"chassis": "vm",
"run_as_root": true
"custom_components": {
"pyscript": {
"version": "1.3.3",
"requirements": [
"croniter==1.3.4",
"watchdog==2.1.6"
"spotcast": {
"version": "v3.6.30",
"requirements": []
"reversotts": {
"version": "1.0.2",
"requirements": [
"pyttsreverso==0.4"
"hacs": {
"version": "1.31.0",
"requirements": [
"aiogithubapi>=22.10.1"
"nodered": {
"version": "1.1.3",
"requirements": []
"integration_manifest": {
"domain": "zha",
"name": "Zigbee Home Automation",
"after_dependencies": [
"onboarding",
"usb"
"codeowners": [
"@dmulcahey",
"@adminiuga",
"@puddly"
"config_flow": true,
"dependencies": [
"file_upload"
"documentation": "https://www.home-assistant.io/integrations/zha",
"iot_class": "local_polling",
"loggers": [
"aiosqlite",
"bellows",
"crccheck",
"pure_pcapy3",
"zhaquirks",
"zigpy",
"zigpy_deconz",
"zigpy_xbee",
"zigpy_zigate",
"zigpy_znp"
"requirements": [
"bellows==0.34.9",
"pyserial==3.5",
"pyserial-asyncio==0.6",
"zha-quirks==0.0.93",
"zigpy-deconz==0.19.2",
"zigpy==0.53.2",
"zigpy-xbee==0.16.2",
"zigpy-zigate==0.10.3",
"zigpy-znp==0.9.3"
"usb": [
"vid": "10C4",
"pid": "EA60",
"description": "*2652*",
"known_devices": [
"slae.sh cc2652rb stick"
"vid": "1A86",
"pid": "55D4",
"description": "*sonoff*plus*",
"known_devices": [
"sonoff zigbee dongle plus v2"
"vid": "10C4",
"pid": "EA60",
"known_devices": [
"sonoff zigbee dongle plus"
"vid": "10C4",
"pid": "EA60",
"description": "*tubeszb*",
"known_devices": [
"TubesZB Coordinator"
"vid": "1A86",
"pid": "7523",
"known_devices": [
"vid": "1A86",
"pid": "7523",
"description": "*zigstar*",
"known_devices": [
"ZigStar Coordinators"
"vid": "1CF1",
"pid": "0030",
"description": "*conbee*",
"known_devices": [
"Conbee II"
"vid": "10C4",
"pid": "8A2A",
"description": "*zigbee*",
"known_devices": [
"Nortek HUSBZB-1"
"vid": "0403",
"pid": "6015",
"description": "*zigate*",
"known_devices": [
"ZiGate+"
"vid": "10C4",
"pid": "EA60",
"known_devices": [
"ZiGate"
"vid": "10C4",
"pid": "8B34",
"description": "*bv 2010/10*",
"known_devices": [
"Bitron Video AV2010/10"
"zeroconf": [
"type": "_esphomelib._tcp.local.",
"name": "tube*"
"type": "_zigate-zigbee-gateway._tcp.local.",
"name": "*zigate*"
"type": "_zigstar_gw._tcp.local.",
"name": "*zigstar*"
"type": "_slzb-06._tcp.local.",
"name": "slzb-06*"
"is_built_in": true
"data": {
"ieee": "**REDACTED**",
"nwk": 38020,
"name": "LUMI lumi.switch.n2aeu1",
"quirk_applied": true,
"quirk_class": "zhaquirks.xiaomi.aqara.opple_switch.XiaomiOpple2ButtonSwitchFace2",
"manufacturer_code": 4447,
"power_source": "Mains",
"lqi": 255,
"rssi": -52,
"last_seen": "2023-03-03T20:31:21",
"available": true,
"device_type": "Router",
"signature": {
"endpoints": {
"1": {
"profile_id": 260,
"in_clusters": [
"0x0000",
"0x0002",
"0x0003",
"0x0004",
"0x0005",
"0x0006",
"0x0009",
"0x0012",
"0x0702",
"0xfcc0"
"out_clusters": [
"0x000a",
"0x0019"
"2": {
"profile_id": 260,
"in_clusters": [
"0x0000",
"0x0003",
"0x0004",
"0x0005",
"0x0006",
"0x0012",
"0xfcc0"
"out_clusters": []
"21": {
"profile_id": 260,
"in_clusters": [
"0x000c"
"out_clusters": []
"31": {
"profile_id": 260,
"in_clusters": [
"0x000c"
"out_clusters": []
"41": {
"profile_id": 260,
"in_clusters": [
"0x0012"
"out_clusters": []
"42": {
"profile_id": 260,
"in_clusters": [
"0x0012"
"out_clusters": []
"51": {
"profile_id": 260,
"in_clusters": [
"0x0012"
"out_clusters": []
"61": {
"profile_id": 260,
"in_clusters": [
"0x0012"
"out_clusters": []
"242": {
"in_clusters": [],
"out_clusters": [
"0x0021"
"active_coordinator": false,
"entities": [
"entity_id": "button.lumi_lumi_switch_n2aeu1_identify_2",
"entity_id": "switch.lumi_lumi_switch_n2aeu1_switch_3",
"entity_id": "switch.lumi_lumi_switch_n2aeu1_switch_4",
"neighbors": [
"device_type": "Coordinator",
"rx_on_when_idle": "On",
"relationship": "Parent",
"extended_pan_id": "**REDACTED**",
"nwk": "0x0000",
"permit_joining": "Unknown",
"depth": "0",
"lqi": "114"
"relationship": "Sibling",
"nwk": "0xDCC0",
"depth": "1",
"lqi": "125"
"nwk": "0xF263",
"depth": "1",
"lqi": "111"
"nwk": "0xAB74",
"depth": "1",
"lqi": "71"
"nwk": "0xE61F",
"depth": "1",
"lqi": "73"
"nwk": "0x3683",
"depth": "1",
"lqi": "93"
"nwk": "0xD265",
"depth": "1",
"lqi": "94"
"nwk": "0xE117",
"depth": "1",
"lqi": "94"
"routes": [
"dest_nwk": "0x0000",
"route_status": "Validation_Underway",
"memory_constrained": false,
"many_to_one": false,
"route_record_required": false,
"next_hop": "0x0000"
"dest_nwk": "0xF263",
"route_status": "Active",
"next_hop": "0xF263"
"dest_nwk": "0xAB74",
"route_status": "Discovery_Underway",
"next_hop": "0xFFFE"
"dest_nwk": "0xE61F",
"next_hop": "0xE61F"
"dest_nwk": "0xBC9A",
"dest_nwk": "0x3683",
"dest_nwk": "0xE117",
"next_hop": "0xE117"
"dest_nwk": "0xD265",
"next_hop": "0xD265"
"dest_nwk": "0xDCC0",
"endpoint_names": [
"name": "ON_OFF_SWITCH"
"name": "ON_OFF_LIGHT"
"name": "unknown 97 device_type of 0xa1e0 profile id"
"user_given_name": null,
"device_reg_id": "8ed3bc9d22587e221a4c605666085ea0",
"area_id": null,
"cluster_details": {
"1": {
"device_type": {
"name": "ON_OFF_SWITCH",
"id": 0
"profile_id": 260,
"in_clusters": {
"0x0000": {
"endpoint_attribute": "basic",
"attributes": {
"0x0006": {
"attribute_name": "date_code",
"value": "01-29-2021"
"unsupported_attributes": {}
"0x0002": {
"endpoint_attribute": "device_temperature",
"attributes": {},
"0x0003": {
"endpoint_attribute": "identify",
"attributes": {},
"0x0004": {
"endpoint_attribute": "groups",
"attributes": {},
"0x0005": {
"endpoint_attribute": "scenes",
"attributes": {},
"0x0006": {
"endpoint_attribute": "on_off",
"attributes": {
"0x0000": {
"attribute_name": "on_off",
"value": 0
"0x4003": {
"attribute_name": "start_up_on_off"
"0x0009": {
"endpoint_attribute": "alarms",
"attributes": {},
"0x0012": {
"endpoint_attribute": "multistate_input",
"attributes": {},
"0x0702": {
"endpoint_attribute": "smartenergy_metering",
"attributes": {},
"0x0300": {
"attribute_name": "unit_of_measure"
"0x0301": {
"attribute_name": "multiplier"
"0x0302": {
"attribute_name": "divisor"
"0x0303": {
"attribute_name": "summation_formatting"
"0x0304": {
"attribute_name": "demand_formatting"
"0x0306": {
"attribute_name": "metering_device_type"
"0xfcc0": {
"endpoint_attribute": "opple_cluster",
"attributes": {},
"out_clusters": {
"0x000a": {
"endpoint_attribute": "time",
"attributes": {},
"0x0019": {
"endpoint_attribute": "ota",
"attributes": {},
"2": {
"device_type": {
"id": 0
"profile_id": 260,
"in_clusters": {
"0x0000": {
"attributes": {},
"0x0003": {
"attributes": {},
"0x0004": {
"attributes": {},
"0x0005": {
"attributes": {},
"0x0006": {
"attributes": {
"0x0000": {
"value": 0
"0x4003": {
"0x0012": {
"attributes": {},
"0xfcc0": {
"attributes": {
"0x0009": {
"attribute_name": "mode",
"value": 1
"out_clusters": {}
"21": {
"device_type": {
"name": "ON_OFF_LIGHT",
"id": 256
"profile_id": 260,
"in_clusters": {
"0x000c": {
"endpoint_attribute": "analog_input",
"attributes": {},
"out_clusters": {}
"31": {
"device_type": {
"id": 256
"profile_id": 260,
"in_clusters": {
"0x000c": {
"attributes": {},
"out_clusters": {}
"41": {
"device_type": {
"id": 256
"profile_id": 260,
"in_clusters": {
"0x0012": {
"attributes": {},
"out_clusters": {}
"42": {
"device_type": {
"id": 256
"profile_id": 260,
"in_clusters": {
"0x0012": {
"attributes": {},
"out_clusters": {}
"51": {
"device_type": {
"id": 256
"profile_id": 260,
"in_clusters": {
"0x0012": {
"attributes": {},
"out_clusters": {}
"61": {
"device_type": {
"id": 256
"profile_id": 260,
"in_clusters": {
"0x0012": {
"attributes": {},
"out_clusters": {}
"242": {
"device_type": {
"name": "unknown",
"id": 97
"in_clusters": {},
"out_clusters": {
"0x0021": {
"endpoint_attribute": "green_power",
"attributes": {},
</details>
<details>
<summary>Additional logs</summary>
Paste any additional debug logs here.
Don't remove the extra line breaks outside the ``` marks.
</details>
**Additional context**
Here is a screenshot of how it looks in ZHA right now. I am using the SkyConnect adapter.
Here is a screenshot of how the same switch looks inside Z2M and what attributes it exposes.
