I bought this Garden water valve and I cannot get it to run: Zigbee Wifi Garden Watering Timer Smart Sprinkler Drip Irrigation System Built-in Water Flow Recorder Water Controller Tuya - Garden Water Timers - AliExpress
Problem: No entities are found
Device Signature:
"node_descriptor": "NodeDescriptor(logical_type=<LogicalType.EndDevice: 2>, complex_descriptor_available=0, user_descriptor_available=0, reserved=0, aps_flags=0, frequency_band=<FrequencyBand.Freq2400MHz: 8>, mac_capability_flags=<MACCapabilityFlags.AllocateAddress: 128>, manufacturer_code=4417, maximum_buffer_size=66, maximum_incoming_transfer_size=66, server_mask=10752, maximum_outgoing_transfer_size=66, descriptor_capability_field=<DescriptorCapability.NONE: 0>, *allocate_address=True, *is_alternate_pan_coordinator=False, *is_coordinator=False, *is_end_device=True, *is_full_function_device=False, *is_mains_powered=False, *is_receiver_on_when_idle=False, *is_router=False, *is_security_capable=False)",
"endpoints": {
"1": {
"profile_id": 260,
"device_type": "0x0051",
"in_clusters": [
"0x0000",
"0x0004",
"0x0005",
"0xef00"
"out_clusters": [
"0x000a",
"0x0019"
"manufacturer": "_TZE200_sh1btabb",
"model": "TS0601",
"class": "zigpy.device.Device"
Solution: There already exists a solution for zigbee2mqtt (zigbee2mqtt-custom/QT-05M.js at 13b0b39084ff6fa37a88c667a4303c566d49b234 · MoonshineSG/zigbee2mqtt-custom · GitHub) but not for ZHA.
Question: Is there a way to get this valve running using ZHA?
