### Problem description
[AVATTO Tuya TRV Smart Radiator Valve](https://www.alie…xpress.com/item/1005003952150617.html)
Device is detected and added easily, however the entities/controls are missing. Although the model looks identical to most supported TRV valves, I haven't been able to find any quirks that work for this particular manufacturer code.
### Solution description
Would like to have support for the entities/controls.
### Screenshots/Video
<details><summary>Screenshots/Video</summary>
</details>
### Device signature
<details><summary>Device signature</summary>
```json
"node_descriptor": {
"logical_type": 2,
"complex_descriptor_available": 0,
"user_descriptor_available": 0,
"reserved": 0,
"aps_flags": 0,
"frequency_band": 8,
"mac_capability_flags": 128,
"manufacturer_code": 4417,
"maximum_buffer_size": 66,
"maximum_incoming_transfer_size": 66,
"server_mask": 10752,
"maximum_outgoing_transfer_size": 66,
"descriptor_capability_field": 0
"endpoints": {
"1": {
"profile_id": "0x0104",
"device_type": "0x0051",
"input_clusters": [
"0x0000",
"0x0004",
"0x0005",
"0xed00",
"0xef00"
"output_clusters": [
"0x000a",
"0x0019"
"manufacturer": "_TZE284_o3x45p96",
"model": "TS0601",
"class": "zigpy.device.Device"
</details>
### Diagnostic information
<details><summary>Diagnostic information</summary>
```json
"home_assistant": {
"installation_type": "Home Assistant OS",
"version": "2024.11.3",
"dev": false,
"hassio": true,
"virtualenv": false,
"python_version": "3.12.4",
"docker": true,
"arch": "x86_64",
"timezone": "Europe/London",
"os_name": "Linux",
"os_version": "6.6.54-haos",
"supervisor": "2024.11.4",
"host_os": "Home Assistant OS 13.2",
"docker_version": "27.2.0",
"chassis": "vm",
"run_as_root": true
"custom_components": {
"truenas": {
"documentation": "https://github.com/tomaae/homeassistant-truenas",
"version": "0.0.0",
"requirements": []
"teamtracker": {
"documentation": "https://github.com/vasqued2/ha-teamtracker",
"version": "0.1",
"requirements": [
"arrow",
"aiofiles"
"dyson_local": {
"documentation": "https://github.com/libdyson-wg/ha-dyson",
"version": "1.4.2",
"requirements": []
"browser_mod": {
"documentation": "https://github.com/thomasloven/hass-browser_mod/blob/master/README.md",
"version": "2.3.1",
"requirements": []
"hass_agent": {
"documentation": "https://github.com/hass-agent/HASS.Agent-Integration",
"version": "2.1.0-beta1",
"requirements": []
"xiaomi_cloud_map_extractor": {
"documentation": "https://github.com/PiotrMachowski/Home-Assistant-custom-components-Xiaomi-Cloud-Map-Extractor",
"version": "v2.2.0",
"requirements": [
"pillow",
"pybase64",
"python-miio",
"requests",
"pycryptodome"
"hacs": {
"documentation": "https://hacs.xyz/docs/configuration/start",
"version": "2.0.1",
"requirements": [
"aiogithubapi>=22.10.1"
"extended_openai_conversation": {
"documentation": "https://github.com/jekalmin/extended_openai_conversation",
"version": "1.0.4",
"requirements": [
"openai~=1.3.8"
"integration_manifest": {
"domain": "zha",
"name": "Zigbee Home Automation",
"after_dependencies": [
"hassio",
"onboarding",
"usb"
"codeowners": [
"dmulcahey",
"adminiuga",
"puddly",
"TheJulianJES"
"config_flow": true,
"dependencies": [
"file_upload"
"documentation": "https://www.home-assistant.io/integrations/zha",
"iot_class": "local_polling",
"loggers": [
"aiosqlite",
"bellows",
"crccheck",
"pure_pcapy3",
"zhaquirks",
"zigpy",
"zigpy_deconz",
"zigpy_xbee",
"zigpy_zigate",
"zigpy_znp",
"zha",
"universal_silabs_flasher"
"requirements": [
"universal-silabs-flasher==0.0.25",
"zha==0.0.39"
"usb": [
"vid": "10C4",
"pid": "EA60",
"description": "*2652*",
"known_devices": [
"slae.sh cc2652rb stick"
"vid": "10C4",
"pid": "EA60",
"description": "*slzb-07*",
"known_devices": [
"smlight slzb-07"
"vid": "1A86",
"pid": "55D4",
"description": "*sonoff*plus*",
"known_devices": [
"sonoff zigbee dongle plus v2"
"vid": "10C4",
"pid": "EA60",
"known_devices": [
"sonoff zigbee dongle plus"
"vid": "10C4",
"pid": "EA60",
"description": "*tubeszb*",
"known_devices": [
"TubesZB Coordinator"
"vid": "1A86",
"pid": "7523",
"known_devices": [
"vid": "1A86",
"pid": "7523",
"description": "*zigstar*",
"known_devices": [
"ZigStar Coordinators"
"vid": "1CF1",
"pid": "0030",
"description": "*conbee*",
"known_devices": [
"Conbee II"
"vid": "0403",
"pid": "6015",
"known_devices": [
"Conbee III"
"vid": "10C4",
"pid": "8A2A",
"description": "*zigbee*",
"known_devices": [
"Nortek HUSBZB-1"
"vid": "0403",
"pid": "6015",
"description": "*zigate*",
"known_devices": [
"ZiGate+"
"vid": "10C4",
"pid": "EA60",
"known_devices": [
"ZiGate"
"vid": "10C4",
"pid": "8B34",
"description": "*bv 2010/10*",
"known_devices": [
"Bitron Video AV2010/10"
"zeroconf": [
"type": "_esphomelib._tcp.local.",
"name": "tube*"
"type": "_zigate-zigbee-gateway._tcp.local.",
"name": "*zigate*"
"type": "_zigstar_gw._tcp.local.",
"name": "*zigstar*"
"type": "_uzg-01._tcp.local.",
"name": "uzg-01*"
"type": "_slzb-06._tcp.local.",
"name": "slzb-06*"
"type": "_xzg._tcp.local.",
"name": "xzg*"
"type": "_czc._tcp.local.",
"name": "czc*"
"is_built_in": true,
"overwrites_built_in": false
"setup_times": {
"null": {
"setup": 4.4623855501413345e-05
"8caa052695d54214c86f74c464d75b30": {
"wait_import_platforms": -0.006946207955479622,
"wait_base_component": -0.00020083808340132236,
"config_entry_setup": 5.809677839977667
"data": {
"ieee": "**REDACTED**",
"nwk": 25852,
"model": "TS0601",
"name": "_TZE284_o3x45p96 TS0601",
"quirk_applied": false,
"quirk_class": "zigpy.device.Device",
"quirk_id": null,
"power_source": "Battery or Unknown",
"lqi": 176,
"rssi": -56,
"last_seen": "2024-11-27T23:06:02",
"available": true,
"device_type": "EndDevice",
"signature": {
"logical_type": 2,
"reserved": 0,
"aps_flags": 0,
"endpoints": {
"1": {
"input_clusters": [
"0x0000",
"0x0004",
"0x0005",
"0xed00",
"0xef00"
"0x000a",
"0x0019"
"model": "TS0601"
"active_coordinator": false,
"entities": [
"entity_id": "update.tze284_o3x45p96_ts0601_firmware",
"neighbors": [],
"routes": [],
"endpoint_names": [
"name": "SMART_PLUG"
"user_given_name": null,
"device_reg_id": "12152fc338c8c9527d646095b95d1765",
"area_id": "office",
"cluster_details": {
"1": {
"device_type": {
"name": "SMART_PLUG",
"id": 81
"profile_id": 260,
"in_clusters": {
"0x0004": {
"endpoint_attribute": "groups",
"attributes": {
"0xfffd": {
"attribute": "ZCLAttributeDef(id=0xFFFD, name='cluster_revision', type=<class 'zigpy.types.basic.uint16_t'>, zcl_type=<DataTypeId.uint16: 33>, access=<ZCLAttributeAccess.Read: 1>, mandatory=True, is_manufacturer_specific=False)",
"value": null
"0x0000": {
"attribute": "ZCLAttributeDef(id=0x0000, name='name_support', type=<flag 'NameSupport'>, zcl_type=<DataTypeId.map8: 24>, access=<ZCLAttributeAccess.Read: 1>, mandatory=True, is_manufacturer_specific=False)",
"value": null
"0xfffe": {
"attribute": "ZCLAttributeDef(id=0xFFFE, name='reporting_status', type=<enum 'AttributeReportingStatus'>, zcl_type=<DataTypeId.enum8: 48>, access=<ZCLAttributeAccess.Read: 1>, mandatory=False, is_manufacturer_specific=False)",
"value": null
"unsupported_attributes": []
"0x0005": {
"endpoint_attribute": "scenes",
"attributes": {
"0xfffd": {
"value": null
"0x0000": {
"attribute": "ZCLAttributeDef(id=0x0000, name='count', type=<class 'zigpy.types.basic.uint8_t'>, zcl_type=<DataTypeId.uint8: 32>, access=<ZCLAttributeAccess.Read: 1>, mandatory=True, is_manufacturer_specific=False)",
"value": null
"0x0002": {
"attribute": "ZCLAttributeDef(id=0x0002, name='current_group', type=<class 'zigpy.types.basic.uint16_t'>, zcl_type=<DataTypeId.uint16: 33>, access=<ZCLAttributeAccess.Read: 1>, mandatory=True, is_manufacturer_specific=False)",
"value": null
"0x0001": {
"attribute": "ZCLAttributeDef(id=0x0001, name='current_scene', type=<class 'zigpy.types.basic.uint8_t'>, zcl_type=<DataTypeId.uint8: 32>, access=<ZCLAttributeAccess.Read: 1>, mandatory=True, is_manufacturer_specific=False)",
"value": null
"0x0005": {
"attribute": "ZCLAttributeDef(id=0x0005, name='last_configured_by', type=<class 'zigpy.types.named.EUI64'>, zcl_type=<DataTypeId.EUI64: 240>, access=<ZCLAttributeAccess.Read: 1>, mandatory=False, is_manufacturer_specific=False)",
"value": null
"0x0004": {
"attribute": "ZCLAttributeDef(id=0x0004, name='name_support', type=<flag 'NameSupport'>, zcl_type=<DataTypeId.map8: 24>, access=<ZCLAttributeAccess.Read: 1>, mandatory=True, is_manufacturer_specific=False)",
"value": null
"0xfffe": {
"value": null
"0x0003": {
"attribute": "ZCLAttributeDef(id=0x0003, name='scene_valid', type=<enum 'Bool'>, zcl_type=<DataTypeId.bool_: 16>, access=<ZCLAttributeAccess.Read: 1>, mandatory=True, is_manufacturer_specific=False)",
"value": null
"0xef00": {
"endpoint_attribute": null,
"attributes": {},
"0x0000": {
"endpoint_attribute": "basic",
"attributes": {
"0x0013": {
"attribute": "ZCLAttributeDef(id=0x0013, name='alarm_mask', type=<flag 'AlarmMask'>, zcl_type=<DataTypeId.map8: 24>, access=<ZCLAttributeAccess.Read|Write: 3>, mandatory=False, is_manufacturer_specific=False)",
"value": null
"0x0001": {
"attribute": "ZCLAttributeDef(id=0x0001, name='app_version', type=<class 'zigpy.types.basic.uint8_t'>, zcl_type=<DataTypeId.uint8: 32>, access=<ZCLAttributeAccess.Read: 1>, mandatory=False, is_manufacturer_specific=False)",
"value": 77
"0xfffd": {
"value": null
"0x0006": {
"attribute": "ZCLAttributeDef(id=0x0006, name='date_code', type=<class 'zigpy.types.basic.LimitedCharString.<locals>.LimitedCharString'>, zcl_type=<DataTypeId.string: 66>, access=<ZCLAttributeAccess.Read: 1>, mandatory=False, is_manufacturer_specific=False)",
"value": null
"0x0012": {
"attribute": "ZCLAttributeDef(id=0x0012, name='device_enabled', type=<enum 'Bool'>, zcl_type=<DataTypeId.bool_: 16>, access=<ZCLAttributeAccess.Read|Write: 3>, mandatory=False, is_manufacturer_specific=False)",
"value": null
"0x0014": {
"attribute": "ZCLAttributeDef(id=0x0014, name='disable_local_config', type=<flag 'DisableLocalConfig'>, zcl_type=<DataTypeId.map8: 24>, access=<ZCLAttributeAccess.Read|Write: 3>, mandatory=False, is_manufacturer_specific=False)",
"value": null
"0x0008": {
"attribute": "ZCLAttributeDef(id=0x0008, name='generic_device_class', type=<enum 'GenericDeviceClass'>, zcl_type=<DataTypeId.enum8: 48>, access=<ZCLAttributeAccess.Read: 1>, mandatory=False, is_manufacturer_specific=False)",
"value": null
"0x0009": {
"attribute": "ZCLAttributeDef(id=0x0009, name='generic_device_type', type=<enum 'GenericLightingDeviceType'>, zcl_type=<DataTypeId.enum8: 48>, access=<ZCLAttributeAccess.Read: 1>, mandatory=False, is_manufacturer_specific=False)",
"value": null
"0x0003": {
"attribute": "ZCLAttributeDef(id=0x0003, name='hw_version', type=<class 'zigpy.types.basic.uint8_t'>, zcl_type=<DataTypeId.uint8: 32>, access=<ZCLAttributeAccess.Read: 1>, mandatory=False, is_manufacturer_specific=False)",
"value": null
"0x0010": {
"attribute": "ZCLAttributeDef(id=0x0010, name='location_desc', type=<class 'zigpy.types.basic.LimitedCharString.<locals>.LimitedCharString'>, zcl_type=<DataTypeId.string: 66>, access=<ZCLAttributeAccess.Read|Write: 3>, mandatory=False, is_manufacturer_specific=False)",
"value": null
"0x0004": {
"attribute": "ZCLAttributeDef(id=0x0004, name='manufacturer', type=<class 'zigpy.types.basic.LimitedCharString.<locals>.LimitedCharString'>, zcl_type=<DataTypeId.string: 66>, access=<ZCLAttributeAccess.Read: 1>, mandatory=False, is_manufacturer_specific=False)",
"value": "_TZE284_o3x45p96"
"0x000c": {
"attribute": "ZCLAttributeDef(id=0x000C, name='manufacturer_version_details', type=<class 'zigpy.types.basic.CharacterString'>, zcl_type=<DataTypeId.string: 66>, access=<ZCLAttributeAccess.Read: 1>, mandatory=False, is_manufacturer_specific=False)",
"value": null
"0x0005": {
"attribute": "ZCLAttributeDef(id=0x0005, name='model', type=<class 'zigpy.types.basic.LimitedCharString.<locals>.LimitedCharString'>, zcl_type=<DataTypeId.string: 66>, access=<ZCLAttributeAccess.Read: 1>, mandatory=False, is_manufacturer_specific=False)",
"value": "TS0601"
"0x0011": {
"attribute": "ZCLAttributeDef(id=0x0011, name='physical_env', type=<enum 'PhysicalEnvironment'>, zcl_type=<DataTypeId.enum8: 48>, access=<ZCLAttributeAccess.Read|Write: 3>, mandatory=False, is_manufacturer_specific=False)",
"value": null
"0x0007": {
"attribute": "ZCLAttributeDef(id=0x0007, name='power_source', type=<enum 'PowerSource'>, zcl_type=<DataTypeId.enum8: 48>, access=<ZCLAttributeAccess.Read: 1>, mandatory=True, is_manufacturer_specific=False)",
"value": null
"0x000a": {
"attribute": "ZCLAttributeDef(id=0x000A, name='product_code', type=<class 'zigpy.types.basic.LVBytes'>, zcl_type=<DataTypeId.octstr: 65>, access=<ZCLAttributeAccess.Read: 1>, mandatory=False, is_manufacturer_specific=False)",
"value": null
"0x000e": {
"attribute": "ZCLAttributeDef(id=0x000E, name='product_label', type=<class 'zigpy.types.basic.CharacterString'>, zcl_type=<DataTypeId.string: 66>, access=<ZCLAttributeAccess.Read: 1>, mandatory=False, is_manufacturer_specific=False)",
"value": null
"0x000b": {
"attribute": "ZCLAttributeDef(id=0x000B, name='product_url', type=<class 'zigpy.types.basic.CharacterString'>, zcl_type=<DataTypeId.string: 66>, access=<ZCLAttributeAccess.Read: 1>, mandatory=False, is_manufacturer_specific=False)",
"value": null
"0xfffe": {
"value": null
"0x000d": {
"attribute": "ZCLAttributeDef(id=0x000D, name='serial_number', type=<class 'zigpy.types.basic.CharacterString'>, zcl_type=<DataTypeId.string: 66>, access=<ZCLAttributeAccess.Read: 1>, mandatory=False, is_manufacturer_specific=False)",
"value": null
"0x0002": {
"attribute": "ZCLAttributeDef(id=0x0002, name='stack_version', type=<class 'zigpy.types.basic.uint8_t'>, zcl_type=<DataTypeId.uint8: 32>, access=<ZCLAttributeAccess.Read: 1>, mandatory=False, is_manufacturer_specific=False)",
"value": null
"0x4000": {
"attribute": "ZCLAttributeDef(id=0x4000, name='sw_build_id', type=<class 'zigpy.types.basic.CharacterString'>, zcl_type=<DataTypeId.string: 66>, access=<ZCLAttributeAccess.Read: 1>, mandatory=False, is_manufacturer_specific=False)",
"value": null
"0x0000": {
"attribute": "ZCLAttributeDef(id=0x0000, name='zcl_version', type=<class 'zigpy.types.basic.uint8_t'>, zcl_type=<DataTypeId.uint8: 32>, access=<ZCLAttributeAccess.Read: 1>, mandatory=True, is_manufacturer_specific=False)",
"value": null
"0xed00": {
"attributes": {},
"out_clusters": {
"0x0019": {
"endpoint_attribute": "ota",
"attributes": {
"0xfffd": {
"value": null
"0x0002": {
"attribute": "ZCLAttributeDef(id=0x0002, name='current_file_version', type=<class 'zigpy.types.basic.uint32_t'>, zcl_type=<DataTypeId.uint32: 35>, access=<ZCLAttributeAccess.Read: 1>, mandatory=False, is_manufacturer_specific=False)",
"value": 77
"0x0003": {
"attribute": "ZCLAttributeDef(id=0x0003, name='current_zigbee_stack_version', type=<class 'zigpy.types.basic.uint16_t'>, zcl_type=<DataTypeId.uint16: 33>, access=<ZCLAttributeAccess.Read: 1>, mandatory=False, is_manufacturer_specific=False)",
"value": null
"0x0004": {
"attribute": "ZCLAttributeDef(id=0x0004, name='downloaded_file_version', type=<class 'zigpy.types.basic.uint32_t'>, zcl_type=<DataTypeId.uint32: 35>, access=<ZCLAttributeAccess.Read: 1>, mandatory=False, is_manufacturer_specific=False)",
"value": null
"0x0005": {
"attribute": "ZCLAttributeDef(id=0x0005, name='downloaded_zigbee_stack_version', type=<class 'zigpy.types.basic.uint16_t'>, zcl_type=<DataTypeId.uint16: 33>, access=<ZCLAttributeAccess.Read: 1>, mandatory=False, is_manufacturer_specific=False)",
"value": null
"0x0001": {
"attribute": "ZCLAttributeDef(id=0x0001, name='file_offset', type=<class 'zigpy.types.basic.uint32_t'>, zcl_type=<DataTypeId.uint32: 35>, access=<ZCLAttributeAccess.Read: 1>, mandatory=False, is_manufacturer_specific=False)",
"value": null
"0x000a": {
"attribute": "ZCLAttributeDef(id=0x000A, name='image_stamp', type=<class 'zigpy.types.basic.uint32_t'>, zcl_type=<DataTypeId.uint32: 35>, access=<ZCLAttributeAccess.Read: 1>, mandatory=False, is_manufacturer_specific=False)",
"value": null
"0x0008": {
"attribute": "ZCLAttributeDef(id=0x0008, name='image_type_id', type=<class 'zigpy.types.basic.uint16_t'>, zcl_type=<DataTypeId.uint16: 33>, access=<ZCLAttributeAccess.Read: 1>, mandatory=False, is_manufacturer_specific=False)",
"value": null
"0x0006": {
"attribute": "ZCLAttributeDef(id=0x0006, name='image_upgrade_status', type=<enum 'ImageUpgradeStatus'>, zcl_type=<DataTypeId.enum8: 48>, access=<ZCLAttributeAccess.Read: 1>, mandatory=True, is_manufacturer_specific=False)",
"value": null
"0x0007": {
"attribute": "ZCLAttributeDef(id=0x0007, name='manufacturer_id', type=<class 'zigpy.types.basic.uint16_t'>, zcl_type=<DataTypeId.uint16: 33>, access=<ZCLAttributeAccess.Read: 1>, mandatory=False, is_manufacturer_specific=False)",
"value": null
"0x0009": {
"attribute": "ZCLAttributeDef(id=0x0009, name='minimum_block_req_delay', type=<class 'zigpy.types.basic.uint16_t'>, zcl_type=<DataTypeId.uint16: 33>, access=<ZCLAttributeAccess.Read: 1>, mandatory=False, is_manufacturer_specific=False)",
"value": null
"0xfffe": {
"value": null
"0x000b": {
"attribute": "ZCLAttributeDef(id=0x000B, name='upgrade_activation_policy', type=<enum 'UpgradeActivationPolicy'>, zcl_type=<DataTypeId.enum8: 48>, access=<ZCLAttributeAccess.Read: 1>, mandatory=False, is_manufacturer_specific=False)",
"value": null
"0x0000": {
"attribute": "ZCLAttributeDef(id=0x0000, name='upgrade_server_id', type=<class 'zigpy.types.named.EUI64'>, zcl_type=<DataTypeId.EUI64: 240>, access=<ZCLAttributeAccess.Read: 1>, mandatory=True, is_manufacturer_specific=False)",
"value": null
"0x000c": {
"attribute": "ZCLAttributeDef(id=0x000C, name='upgrade_timeout_policy', type=<enum 'UpgradeTimeoutPolicy'>, zcl_type=<DataTypeId.enum8: 48>, access=<ZCLAttributeAccess.Read: 1>, mandatory=False, is_manufacturer_specific=False)",
"value": null
"0x000a": {
"endpoint_attribute": "time",
"attributes": {
"0xfffd": {
"value": null
"0x0004": {
"attribute": "ZCLAttributeDef(id=0x0004, name='dst_end', type=<class 'zigpy.types.basic.uint32_t'>, zcl_type=<DataTypeId.uint32: 35>, access=<ZCLAttributeAccess.Read|Write: 3>, mandatory=False, is_manufacturer_specific=False)",
"value": null
"0x0005": {
"attribute": "ZCLAttributeDef(id=0x0005, name='dst_shift', type=<class 'zigpy.types.basic.int32s'>, zcl_type=<DataTypeId.int32: 43>, access=<ZCLAttributeAccess.Read|Write: 3>, mandatory=False, is_manufacturer_specific=False)",
"value": null
"0x0003": {
"attribute": "ZCLAttributeDef(id=0x0003, name='dst_start', type=<class 'zigpy.types.basic.uint32_t'>, zcl_type=<DataTypeId.uint32: 35>, access=<ZCLAttributeAccess.Read|Write: 3>, mandatory=False, is_manufacturer_specific=False)",
"value": null
"0x0008": {
"attribute": "ZCLAttributeDef(id=0x0008, name='last_set_time', type=<class 'zigpy.types.named.UTCTime'>, zcl_type=<DataTypeId.UTC: 226>, access=<ZCLAttributeAccess.Read: 1>, mandatory=False, is_manufacturer_specific=False)",
"value": null
"0x0007": {
"attribute": "ZCLAttributeDef(id=0x0007, name='local_time', type=<class 'zigpy.types.named.LocalTime'>, zcl_type=<DataTypeId.uint32: 35>, access=<ZCLAttributeAccess.Read: 1>, mandatory=False, is_manufacturer_specific=False)",
"value": null
"0xfffe": {
"value": null
"0x0006": {
"attribute": "ZCLAttributeDef(id=0x0006, name='standard_time', type=<class 'zigpy.types.named.StandardTime'>, zcl_type=<DataTypeId.uint32: 35>, access=<ZCLAttributeAccess.Read: 1>, mandatory=False, is_manufacturer_specific=False)",
"value": null
"0x0000": {
"attribute": "ZCLAttributeDef(id=0x0000, name='time', type=<class 'zigpy.types.named.UTCTime'>, zcl_type=<DataTypeId.UTC: 226>, access=<ZCLAttributeAccess.Read|Write_Optional: 5>, mandatory=True, is_manufacturer_specific=False)",
"value": null
"0x0001": {
"attribute": "ZCLAttributeDef(id=0x0001, name='time_status', type=<flag 'TimeStatus'>, zcl_type=<DataTypeId.map8: 24>, access=<ZCLAttributeAccess.Read|Write_Optional: 5>, mandatory=True, is_manufacturer_specific=False)",
"value": null
"0x0002": {
"attribute": "ZCLAttributeDef(id=0x0002, name='time_zone', type=<class 'zigpy.types.basic.int32s'>, zcl_type=<DataTypeId.int32: 43>, access=<ZCLAttributeAccess.Read|Write: 3>, mandatory=False, is_manufacturer_specific=False)",
"value": null
"0x0009": {
"attribute": "ZCLAttributeDef(id=0x0009, name='valid_until_time', type=<class 'zigpy.types.named.UTCTime'>, zcl_type=<DataTypeId.UTC: 226>, access=<ZCLAttributeAccess.Read|Write: 3>, mandatory=False, is_manufacturer_specific=False)",
"value": null
</details>
### Logs
<details><summary>Logs</summary>
```python
[Paste the logs here]
</details>
### Custom quirk
<details><summary>Custom quirk</summary>
```python
[Paste your custom quirk here]
</details>
### Additional information
_No response_
