ZHA: retry aborted firmware updates, one device at a time
Zigbee firmware updates in ZHA often abort on an unstable link. This blueprint runs the waiting updates one device at a time and starts the same update again after an abort. It does not make the radio more reliable, and it does not fix an image the device rejects (for example INVALID_IMAGE after a completed transfer).
Create three helpers first:
  • an input_boolean, the kill switch
  • a timer, the watchdog
  • a second timer, the cooldown after a ZHA reload
Turn the kill switch on to start. Turn it off to stop further attempts. A transfer that is already running is left alone.
After an abort it waits 30 seconds and tries the same device again. After a success, or after you turn the kill switch on, it waits 15 seconds and starts the next device. If a start never reaches “installing”, the watchdog retries every 150 seconds. The pending list rotates on that same period, so one device that never starts does not block the others.
“Reload ZHA when an update hangs” is off by default. When you enable it, an update that stays in progress for 6 minutes without an attribute change reloads ZHA, waits 90 seconds, and tries again. That disconnects the whole Zigbee network for a short time, and it will not happen again for 15 minutes.
Gist: ZHA OTA serial retry · GitHub
blueprint:
  name: ZHA OTA serial retry
  author: KienzlerA
  domain: automation
  description: >
    Runs waiting Zigbee firmware updates one device at a time and starts the
    same update again after an abort. Create three helpers before you import
    an automation from this blueprint. An input_boolean is the kill switch.
    One timer is the watchdog. A second timer is the cooldown after a ZHA
    reload.
    Timing, as used for a Sonoff S60 campaign: 30 seconds after an abort,
    15 seconds after success or after the kill switch turns on, then the
    next device. If a start never reaches "installing", the watchdog retries
    every 150 seconds. The pending list rotates on that same 150-second
    "Reload ZHA when an update hangs" is off by default. When enabled, an
    reloads ZHA, waits 90 seconds, and tries again. Reloading ZHA disconnects
    for 15 minutes. Leave this off unless updates sit in progress forever.
    Retrying does not fix an image the device rejects (for example
  input:
    firmware_updates:
      description: >
        Update entities to process one after another. State "on" means an
        update is still available.
      selector:
        entity:
          multiple: true
          filter:
            - domain: update
              device_class: firmware
    kill_switch:
      description: >
        Turn on to start the campaign. Turn off to stop further retries.
      selector:
        entity:
          filter:
            - domain: input_boolean
    watchdog_timer:
      description: >
        Timer helper. The blueprint restarts it for 2 minutes 30 seconds
        after each attempt.
      selector:
        entity:
          filter:
            - domain: timer
    reload_cooldown_timer:
      name: Reload cooldown timer
      description: >
        Second timer helper. Used only when hang reload is enabled. The
        blueprint then starts it for 15 minutes.
      selector:
        entity:
          filter:
            - domain: timer
    reload_zha_on_hang:
      name: Reload ZHA when an update hangs
      description: >
        Reload the ZHA integration when an update stays in progress for 6
        minutes without an attribute change. This briefly disconnects every
        Zigbee device.
      default: false
      selector:
        boolean:
    zha_config_entry:
      name: ZHA configuration entry
      description: >
        Used only when hang reload is enabled. Pick the Zigbee Home
        Automation entry.
      selector:
        config_entry:
          integration: zha
mode: queued
max: 10
variables:
  ota_entities_input: !input firmware_updates
  ota_entities: >-
    {% if ota_entities_input is string %}
      {{ [ota_entities_input] }}
    {% else %}
      {{ ota_entities_input | list }}
    {% endif %}
  reload_on_hang: !input reload_zha_on_hang
triggers:
  - trigger: state
    entity_id: !input firmware_updates
    to: "on"
  - trigger: state
    to: "off"
  - trigger: state
    entity_id: !input kill_switch
    to: "on"
  - trigger: state
    to: "off"
  - trigger: event
    event_type: timer.finished
    event_data:
      entity_id: !input watchdog_timer
actions:
  - choose:
      - conditions:
          - condition: trigger
        sequence:
          - action: timer.cancel
      - conditions:
          - condition: state
            state: "on"
        sequence:
          - delay:
              seconds: 30
          - condition: state
            state: "on"
          - condition: template
            value_template: "{{ is_state(trigger.entity_id, 'on') }}"
            value_template: >-
              {{ (ota_entities | select('is_state', 'installing') | list | count == 0)
                 and (ota_entities | map('state_attr', 'in_progress') | select('true') | list | count == 0) }}
          - action: update.install
            continue_on_error: true
              entity_id: "{{ trigger.entity_id }}"
          - action: timer.start
              duration: "00:02:30"
    default:
      - condition: or
        conditions:
      - condition: state
        state: "on"
      - choose:
          - conditions:
              - condition: or
                conditions:
            sequence:
              - delay:
                  seconds: 15
      - condition: state
        state: "on"
      - variables:
          pending_rot: >-
            {% set p = ota_entities | select('is_state', 'on') | list %}
            {% set n = p | count %}
            {% if n == 0 %}
            {% else %}
              {% set i = (now().timestamp() | int // 150) % n %}
              {{ (p[i:] + p[:i]) | list }}
            {% endif %}
          hung_otas: >-
            {% set ns = namespace(items=[]) %}
            {% for e in ota_entities %}
              {% if state_attr(e, 'in_progress') %}
                {% set age = (as_timestamp(now()) - as_timestamp(states[e].last_updated)) | int %}
                {% if age >= 360 %}
                  {% set ns.items = ns.items + [e] %}
                {% endif %}
              {% endif %}
            {% endfor %}
            {{ ns.items }}
      - if:
            value_template: "{{ reload_on_hang | bool and (hung_otas | count > 0) }}"
        then:
          - if:
              - condition: not
                conditions:
                  - condition: state
                    entity_id: !input reload_cooldown_timer
                    state: active
            then:
              - action: persistent_notification.create
                  notification_id: zha_ota_hang_kill
                  title: ZHA OTA hang
                  message: >-
                    Firmware update stalled (no progress for 6 minutes):
                    {{ hung_otas | join(', ') }}. Reloading ZHA, then retrying.
              - action: homeassistant.reload_config_entry
                  entry_id: !input zha_config_entry
                  duration: "00:15:00"
              - delay:
                  seconds: 90
            else:
        else:
          - if:
                value_template: "{{ pending_rot | count == 0 }}"
            then:
              - if:
                    value_template: >-
                then:
                  - action: input_boolean.turn_off
                      notification_id: zha_ota_done
                      title: ZHA OTA finished
                      message: >-
                        Every firmware update in the list has finished.
                        The kill switch was turned off.
                else:
            else:
              - repeat:
                  for_each: "{{ pending_rot }}"
                  sequence:
                      value_template: >-
                        entity_id: "{{ repeat.item }}"
                    - delay:
                        seconds: 5
Giving this a try. I have one temp sensor that has an update that always fails when I try it. Maybe this persistence will get it done.
Thanks for trying it. One sensor that always fails is a useful test.
If it is battery powered, press its button once when an attempt starts so it stays awake long enough to request the image. The blueprint only starts the update again. It cannot keep a sleepy device awake.
Please let me know whether it finished, or where it stopped: it never left “on”, it aborted part way, or it sat in progress. That shows whether a retry is enough for this kind of device.
