ZHA Setup fails and crashes Home Assistant
I have a brand new empty instance of Home Assistant (OS 13.1, Core 2024.8.3) running on VirtualBox 7.20 (with Extension Pack) on Windows 10.
I have tried to load the ZHA Integration with the Sonoff Zigbee 3.0 USB Dongle Plus. Home Assistant crashes just after I begin the installation. The same thing happens when I try to use a Home Assistant Connect ZBT-1 dongle. This seems like it should be such a simple operation. Here are the details:
  • I install the dongle into a USB port with a USB extension cable.
  • I capture the USB port in VirtualBox and can see the Dongle in the Home Assistant Settings>Devices and services and in the VM Settings.
  • In Settings>Hardware>All Hardware>USB, I see: ttyUSB0/dev/serial/by-id/usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_9cc386a031fded119f4c0b65024206e6-if00-port0
  • I select Add Integration and select Zigbee Home Automation.
  • I select the discovered Sonoff Zigbee dongle and press “Submit” in the dialog box that says for "Do you want to setup the “Sonoff Zigbee 3.0 USB Dongle Plus”
  • I select “Erase network settings and create new network” in the Network Formation dialog box. (I have also tried the “Keep radio network settings” with the same results.)
  • The dialog box says “loading next step for zha” and the icon just spins for 5-10 minutes. At the same time, the cursor in the Home Assistant CLI stops blinking. I can no longer ping the Home Assistant IP address and the VM becomes unresponsive
  • Eventually the dialog box says ERROR. At the bottom it says "Connection lost. Reconnecting.
  • I cannot shut down the VM gracefully and have to kill VirtualBox with Windows Task Manager
  • I restart the VirtualBox and the Home Assistant VM.
  • I check all the logs in Settings>System>Logs. I search for zha, sonoff and usb, but there is nothing helpful there.
Same problem here. OS/X, Virtual Box, similar circumstances, same device.
There will be nothing in the current log because the log file starts again when ha restarts. Look instead at home-assistant.log.1
I gave up and installed zigbee2mqtt which is working perfectly. It was a little harder to configure, but there are great YouTube tutorials.
I did figure out how to enable zha debug logs and saw a ton of info in log1 but decided to try the other path.
Exact same setup and same problem! I just installed core 2024.9.0. No help.
home-assistant.log.1 only shows:
2024-09-04 12:56:51.849 WARNING (Recorder) [homeassistant.components.recorder.migration] The database is about to upgrade from schema version 45 to 47
2024-09-04 12:56:51.953 WARNING (Recorder) [homeassistant.components.recorder.migration] Upgrade to version 46 done
2024-09-04 12:56:51.961 WARNING (Recorder) [homeassistant.components.recorder.migration] Upgrade to version 47 done
Supervisor log had more details but no errors and no mention of ZigBee or Sonoff.
With log level set to debug the core log shows:
2024-09-04 13:35:18.812 INFO (SyncWorker_3) [homeassistant.loader] Loaded zha from homeassistant.components.zha
2024-09-04 13:35:20.803 DEBUG (MainThread) [homeassistant.loader] Importing platforms for zha executor=[‘config_flow’] loop= took 1.98s
I’m observing something similar with a Qivicon Telegesis stick. For me, Home Assistant already crashes when pressing “Submit” in the dialog box. Running HAOS in a VirtualBox VM, full hang, even the text caret in the VM window stops blinking. Remarkably, also VirtualBox itself crashes (“is not responding”) when hitting the close box, meaning that I could not shut down the VM by closing the window but I had to kill the VM process.
Logs (set default level in logger to debug, here is a hopefully relevant excerpt):
2025-01-19 23:20:16.413 DEBUG (MainThread) [homeassistant.components.homeassistant_hardware] Add-on store info: {'detached': False, 'apparmor': 'default', 'auth_api': False, 'docker_api': False, 'full_access': False, 'homeassistant_api': False, 'host_network': True, 'host_pid': False, 'ingress': False, 'long_description': '# Home Assistant Add-on: SiliconLabs Zigbee/OpenThread Multiprotocol Add-on\n\nZigbee/OpenThread Multiprotocol container for Silicon Labs based radios such as\nHome Assistant Yellow, Home Assistant SkyConnect, and Home Assistant Connect ZBT-1.\n\n![Supports armv7 Architecture][armv7-shield]\n![Supports aarch64 Architecture][aarch64-shield]\n![Supports amd64 Architecture][amd64-shield]\n\n## About\n\nThis add-on allows you to use Zigbee and OpenThread protocol simultaneous on a\nsingle Silicon Labs based radio. The radio needs the RCP Multi-PAN firmware\ninstalled to support multiple IEEE 802.15.4 Personal Area Networks (PAN). The\naddon has been tested with EFR32 Series 2 based radios.\n\n[armv7-shield]: https://img.shields.io/badge/armv7-yes-green.svg\n[aarch64-shield]: https://img.shields.io/badge/aarch64-yes-green.svg\n[amd64-shield]: https://img.shields.io/badge/amd64-yes-green.svg\n', 'rating': 3, 'signed': False, 'supervisor_api': True, 'supervisor_role': 'default', 'arch': ['armv7', 'aarch64', 'amd64'], 'documentation': True, 'advanced': False, 'available': True, 'build': False, 'description': 'Zigbee and OpenThread multiprotocol add-on', 'homeassistant': '2024.1.0', 'icon': True, 'logo': True, 'name': 'Silicon Labs Multiprotocol', 'repository': 'core', 'slug': 'core_silabs_multiprotocol', 'stage': 'experimental', 'update_available': False, 'url': 'https://github.com/home-assistant/addons/tree/master/silabs-multiprotocol\n', 'version_latest': '2.4.5', 'version': None, 'installed': False}
2025-01-19 23:20:16.413 DEBUG (MainThread) [homeassistant.components.zha.radio_manager] Attempting to probe radio type RadioType.ezsp
2025-01-19 23:20:16.415 DEBUG (MainThread) [zigpy.ota] Registering new OTA provider: Ledvance(url='https://api.update.ledvance.com/v1/zigbee/firmwares', manufacturer_ids=(4489, 4364))
2025-01-19 23:20:16.416 DEBUG (MainThread) [zigpy.ota] Registering new OTA provider: Sonoff(url=None, manufacturer_ids=(4742,))
2025-01-19 23:20:16.417 DEBUG (MainThread) [zigpy.ota] Registering new OTA provider: Inovelli(url=None, manufacturer_ids=(4655,))
2025-01-19 23:20:16.417 DEBUG (MainThread) [zigpy.ota] Registering new OTA provider: ThirdReality(url=None, manufacturer_ids=(4659, 4877, 5127))
2025-01-19 23:20:16.419 DEBUG (bellows.thread_0) [asyncio] Using selector: EpollSelector
2025-01-19 23:20:16.421 DEBUG (bellows.thread_0) [zigpy.serial] Opening a serial connection to '/dev/ttyUSB0' (baudrate=115200, xonxoff=True, rtscts=False)
2025-01-19 23:20:16.496 DEBUG (bellows.thread_0) [zigpy.serial] Connection made: <bellows.ash.AshProtocol object at 0x7f0c5a1caba0>
2025-01-19 23:20:16.497 DEBUG (MainThread) [bellows.ezsp] Resetting EZSP
2025-01-19 23:20:16.498 DEBUG (bellows.thread_0) [bellows.uart] Resetting ASH
2025-01-19 23:20:16.499 DEBUG (bellows.thread_0) [bellows.ash] Sending frame CANCEL + RstFrame() + FLAG
2025-01-19 23:20:16.499 DEBUG (bellows.thread_0) [bellows.ash] Sending data  1ac038bc7e
2025-01-19 23:20:21.622 DEBUG (bellows.thread_0) [zigpy.serial] Waiting for serial port to close
2025-01-19 23:20:21.629 DEBUG (bellows.thread_0) [zigpy.serial] Connection lost: None
2025-01-19 23:20:21.630 DEBUG (bellows.thread_0) [bellows.uart] Connection lost: None
2025-01-19 23:20:21.630 DEBUG (MainThread) [zigpy.application] Connection to the radio has been lost: None
2025-01-19 23:20:21.632 DEBUG (MainThread) [zigpy.application] Failed to probe with config {'path': '/dev/ttyUSB0', 'baudrate': 115200, 'flow_control': None}
  File "/usr/local/lib/python3.13/site-packages/bellows/uart.py", line 109, in reset
    return await self._reset_future
asyncio.exceptions.CancelledError
  File "/usr/local/lib/python3.13/site-packages/zigpy/application.py", line 627, in probe
    await app.connect()
  File "/usr/local/lib/python3.13/site-packages/bellows/zigbee/application.py", line 150, in connect
    await self._ezsp.connect(use_thread=self.config[CONF_USE_THREAD])
  File "/usr/local/lib/python3.13/site-packages/bellows/ezsp/__init__.py", line 138, in connect
    await self.startup_reset()
  File "/usr/local/lib/python3.13/site-packages/bellows/ezsp/__init__.py", line 127, in startup_reset
    await self.reset()
  File "/usr/local/lib/python3.13/site-packages/bellows/ezsp/__init__.py", line 146, in reset
    await self._gw.reset()
  File "/usr/local/lib/python3.13/site-packages/bellows/uart.py", line 108, in reset
    async with asyncio_timeout(RESET_TIMEOUT):
  File "/usr/local/lib/python3.13/asyncio/timeouts.py", line 116, in __aexit__
    raise TimeoutError from exc_val
TimeoutError
2025-01-19 23:20:21.645 DEBUG (MainThread) [zigpy.ota] Registering new OTA provider: Ledvance(url='https://api.update.ledvance.com/v1/zigbee/firmwares', manufacturer_ids=(4489, 4364))
2025-01-19 23:20:21.645 DEBUG (MainThread) [zigpy.ota] Registering new OTA provider: Sonoff(url=None, manufacturer_ids=(4742,))
2025-01-19 23:20:21.645 DEBUG (MainThread) [zigpy.ota] Registering new OTA provider: Inovelli(url=None, manufacturer_ids=(4655,))
2025-01-19 23:20:21.645 DEBUG (MainThread) [zigpy.ota] Registering new OTA provider: ThirdReality(url=None, manufacturer_ids=(4659, 4877, 5127))
2025-01-19 23:20:21.646 DEBUG (bellows.thread_0) [asyncio] Using selector: EpollSelector
2025-01-19 23:20:21.648 DEBUG (bellows.thread_0) [zigpy.serial] Opening a serial connection to '/dev/ttyUSB0' (baudrate=57600, xonxoff=True, rtscts=False)
2025-01-19 23:20:22.646 WARNING (bellows.thread_0) [homeassistant.util.executor] Thread[SyncWorker_0] is still running at shutdown: File "/usr/local/lib/python3.13/threading.py", line 1012, in _bootstrap
    self._bootstrap_inner()
  File "/usr/local/lib/python3.13/threading.py", line 1041, in _bootstrap_inner
    self.run()
  File "/usr/local/lib/python3.13/threading.py", line 992, in run
    self._target(*self._args, **self._kwargs)
  File "/usr/local/lib/python3.13/concurrent/futures/thread.py", line 93, in _worker
    work_item.run()
  File "/usr/local/lib/python3.13/concurrent/futures/thread.py", line 59, in run
  File "/usr/local/lib/python3.13/site-packages/serial/serialposix.py", line 533, in close
    os.close(self.fd)
2025-01-19 23:20:23.545 WARNING (bellows.thread_0) [homeassistant.util.executor] Thread[SyncWorker_0] is still running at shutdown: File "/usr/local/lib/python3.13/threading.py", line 1012, in _bootstrap
    self.run()
    work_item.run()
    os.close(self.fd)
What else can we do to debug this issue?
I know this is an old thread, but I just purchased a ZBT-1 and I am now having the exact same issue.
As soon as I select “Zigbee” when adding the ZBT-1, the VM stops responding, VirtualBox crashes, and the control panel just stays at “Loading next steps for Home Assistant Connect ZBT-1”…
So far I’ve tried configuring the VM with only USB 1.1, USB 2.0 and USB 3.0 - no change. Tried creating a new VM using the same VDI - no change.
