So I am doing a double upgrade from 0.103.6 with python3.6.5 which is the last version of HA compatible with 3.6, to 0.105.X with python3.7.5.
After working a few details, I was able to get everything back up except… transferring my zha module.
It fails apparently within the zha-quirks: “import SmartThingsAccelCluster”
I am able to add an integration, get the ZHA menu but the integration does not work.
Switching back to the older installation 0.103.6 and the older python works perfectly. So I am left scratching my head…
I tested moving my installation of 0.103.6 to python3.7 and keep getting the same error:
Error setting up entry /dev/tty-zb for zha
File "/home/homeassistant/.local/lib/python3.7/site-packages/homeassistant/config_entries.py", line 192, in async_setup
hass, self
File "/home/homeassistant/.local/lib/python3.7/site-packages/homeassistant/components/zha/__init__.py", line 103, in async_setup_entry
import zhaquirks # noqa: F401 pylint: disable=unused-import
File "/home/homeassistant/.homeassistant/deps/lib/python3.7/site-packages/zhaquirks/__init__.py", line 147, in <module>
importlib.import_module(modname)
File "/usr/lib/python3.7/importlib/__init__.py", line 127, in import_module
return _bootstrap._gcd_import(name[level:], package, level)
File "/home/homeassistant/.homeassistant/deps/lib/python3.7/site-packages/zhaquirks/smartthings/multi.py", line 14, in <module>
from . import SmartThingsAccelCluster
ImportError: cannot import name 'SmartThingsAccelCluster' from 'zhaquirks.smartthings' (/home/homeassistant/.homeassistant/deps/lib/python3.7/site-packages/zhaquirks/smartthings/__init__.py)
I have no issues with any other component and I have a bunch (~12) of them…
