See if you can get the ws02.py working and then see if you can make a few changes to it to check the last_seen and rssi attributes, below is how you would do it piping the output of ws02.py to the jq utility:
./ws02.py | jq -c '.result[] | {date: (now|strftime("%s")), ieee: .ieee, ls: .last_seen, rssi: .rssi}'
{"date":"1626152267","ieee":"xx:yy:xx:yy:xx:yy:xx:yy","ls":"2021-07-12T13:45:52","rssi":-48}
{"date":"1626152267","ieee":"xx:yy:xx:yy:xx:yy:xx:yy","ls":"2021-06-25T11:08:36","rssi":null}
{"date":"1626152267","ieee":"xx:yy:xx:yy:xx:yy:xx:yy","ls":"2021-07-12T13:57:33","rssi":-40}
{"date":"1626152267","ieee":"xx:yy:xx:yy:xx:yy:xx:yy","ls":"2021-07-12T13:57:46","rssi":null}
{"date":"1626152267","ieee":"xx:yy:xx:yy:xx:yy:xx:yy","ls":"2021-07-12T13:57:41","rssi":-36}
{"date":"1626152267","ieee":"xx:yy:xx:yy:xx:yy:xx:yy","ls":"2021-07-12T13:57:41","rssi":-41}
{"date":"1626152267","ieee":"xx:yy:xx:yy:xx:yy:xx:yy","ls":"2021-07-12T13:57:42","rssi":-40}
{"date":"1626152267","ieee":"xx:yy:xx:yy:xx:yy:xx:yy","ls":"2021-07-12T13:56:07","rssi":-38}
{"date":"1626152267","ieee":"xx:yy:xx:yy:xx:yy:xx:yy","ls":"2021-07-12T13:56:45","rssi":-49}
{"date":"1626152267","ieee":"xx:yy:xx:yy:xx:yy:xx:yy","ls":"2021-07-12T13:51:18","rssi":-66}
{"date":"1626152267","ieee":"xx:yy:xx:yy:xx:yy:xx:yy","ls":"2021-07-12T13:57:25","rssi":-44}
{"date":"1626152267","ieee":"xx:yy:xx:yy:xx:yy:xx:yy","ls":"2021-07-12T13:57:14","rssi":-40}
{"date":"1626152267","ieee":"xx:yy:xx:yy:xx:yy:xx:yy","ls":"2021-07-12T13:50:30","rssi":-37}
{"date":"1626152267","ieee":"xx:yy:xx:yy:xx:yy:xx:yy","ls":"2021-07-12T13:18:30","rssi":-62}
āorā
./ws02.py | jq -c '.result[] | {date: (now|strftime("%s")), ieee: .ieee, ls: .last_seen, rssi: .rssi, name: .user_given_name}'
{"date":"1626152745","ieee":"xx:yy:xx:yy:xx:yy:xx:yy","ls":"2021-07-12T14:03:36","rssi":-38,"name":"SmartThings PGC313 01 Entry Way"}
{"date":"1626152745","ieee":"xx:yy:xx:yy:xx:yy:xx:yy","ls":"2021-07-12T14:05:15","rssi":-49,"name":"IKEA of Sweden TRADFRI motion sensor 01 Dining Room"}
{"date":"1626152745","ieee":"xx:yy:xx:yy:xx:yy:xx:yy","ls":"2021-07-12T13:51:18","rssi":-66,"name":"CREE Connected A-19 60W Equivalent 01 HVAC Closet"}
{"date":"1626152745","ieee":"xx:yy:xx:yy:xx:yy:xx:yy","ls":"2021-07-12T14:05:25","rssi":-44,"name":"OSRAM LIGHTIFY A19 Tunable White 01 Living Room"}
{"date":"1626152745","ieee":"xx:yy:xx:yy:xx:yy:xx:yy","ls":"2021-07-12T14:03:56","rssi":-53,"name":"eWeLink TH01 Test"}
{"date":"1626152745","ieee":"xx:yy:xx:yy:xx:yy:xx:yy","ls":"2021-07-12T13:50:30","rssi":-37,"name":"IKEA of Sweden TRADFRI on/off switch stove"}
{"date":"1626152745","ieee":"xx:yy:xx:yy:xx:yy:xx:yy","ls":"2021-07-12T14:00:39","rssi":-62,"name":"LUMI lumi.weather Test"}
shout if I can help.
