ZHA - Sonoff SNZB-01
Blueprint for the Sonoff SNZB-01.
You can set functions for single press, double press and hold. This allows you to assign, e.g., a scene or anything else.
Blueprint screen:
Blueprint to import:
blueprint:
  name: ZHA - Sonoff SNZB-01
  description: 'Perform actions with the Sonoff SNZB-01 Button.
    e.g., a scene or anything else.'
  domain: automation
  input:
    remote:
      description: Sonoff Button to use
      selector:
        device:
          integration: zha
          manufacturer: eWeLink
          model: WB01
    single_press:
      description: Action to run on single press
      default: []
      selector:
        action: {}
    double_press:
      description: Action to run on double press
      default: []
      selector:
        action: {}
    hold:
      description: Action to run on hold
      default: []
      selector:
        action: {}
  source_url: https://gist.github.com/seamus65/2be0f8c665ac8c1e011fbd1a0937f9e1
mode: restart
max_exceeded: silent
- platform: event
  event_type: zha_event
  event_data:
    device_id: !input 'remote'
- variables:
    command: '{{ trigger.event.data.command }}'
    cluster_id: '{{ trigger.event.data.cluster_id }}'
    endpoint_id: '{{ trigger.event.data.endpoint_id }}'
- choose:
  - conditions:
    - '{{ command == "toggle" }}'
    - '{{ cluster_id == 6 }}'
    - '{{ endpoint_id == 1 }}'
    sequence: !input 'single_press'
  - conditions:
    - '{{ command == "on" }}'
    sequence: !input 'double_press'
  - conditions:
    - '{{ command == "off" }}'
    sequence: !input 'hold'
How can I import this blueprint? It gives an error because the name not end with .YAML
This is what worked for me:
  1. Copy the above source code
  2. Follow the steps under the section ‘Keeping blueprints up to date’ on this page Using Automation Blueprints - Home Assistant
  3. Instead of directly following step 2, create your own folder, then create your own empty yaml file in that folder.
I have corrected this now.
Sorry, I missed that when I created it.
I have a Snzb-01 connected through Z2M and when using this blueprint it says no matching devices found.
Any suggestions?
This blueprint is for devices through ZHA, but there shouldn’t be any reason you couldn’t update the blueprint YAML to suit your devices through Z2M.
i dont know what im doing wrong but it doesn’t work at my automation…
alias: ZHA - Sonoff SNZB-01
description: ""
use_blueprint:
  path: seamus65/ZHA - Sonoff SNZB-01.yaml
  input:
    remote: ca1970d941f9f6b6a5faf6a240e104ad
    single_press:
      - type: toggle
        device_id: 18766ba1f1d08ef8059f3f97b2891d03
        entity_id: light.signify_netherlands_b_v_lca001_huelight
        domain: light
    hold: []
Works perfectly for me!
Thank you for this beautiful Blueprint :heart_eyes:
  • Core 2023.11.3
  • Supervisor 2023.11.6
  • Operating System 11.2
If you’re using Sonofflan, try this :
platform: state
entity_id:
  - sensor.sonoff_a44XXXXX #YourSensorID
to: single
This trigger works well for me Home Assistant 2024.3.0 (docker container)
You can use those 3 events:
  • single
  • double
  • hold
For anyone else like me landing here and getting the no devices found message after running the blueprint the answer is a quick copy and paste into the YAML, with a YAML restart. I followed the guide here : Add Sonoff Zigbee Wireless Switch To Home Assistant - Smart Home Sysadmin.
