After power outage HA rebooted but the ZHA stuck with an error and there is no option to restart just this integration. All zigbee devices not working…
Z2Mqtt addon could be rebooted but this integration runs w/o this option… crazy… HA restart does not help ZHA start with the same error…
Logger: homeassistant.components.zha.core.gateway
Source: components/zha/core/gateway.py:152
Integration: Zigbee Home Automation (documentation, issues)
First occurred: 3:16:06 PM (5 occurrences)
Last logged: 3:20:53 PM
Couldn't start ZNP = Texas Instruments Z-Stack ZNP protocol: CC253x, CC26x2, CC13x2 coordinator
File "/usr/local/lib/python3.9/site-packages/zigpy_znp/api.py", line 395, in request
response = await response_future
asyncio.exceptions.CancelledError
File "/usr/src/homeassistant/homeassistant/components/zha/core/gateway.py", line 152, in async_initialize
self.application_controller = await app_controller_cls.new(
File "/usr/local/lib/python3.9/site-packages/zigpy/application.py", line 69, in new
await app.startup(auto_form)
File "/usr/local/lib/python3.9/site-packages/zigpy_znp/zigbee/application.py", line 196, in startup
return await self._startup(
File "/usr/local/lib/python3.9/site-packages/zigpy_znp/zigbee/application.py", line 209, in _startup
await znp.connect()
File "/usr/local/lib/python3.9/site-packages/zigpy_znp/api.py", line 119, in connect
await self.nvram.determine_alignment()
File "/usr/local/lib/python3.9/site-packages/zigpy_znp/nvram.py", line 35, in determine_alignment
value = await self.osal_read(nvids.OsalNvIds.NWKKEY, item_type=t.Bytes)
File "/usr/local/lib/python3.9/site-packages/zigpy_znp/nvram.py", line 170, in osal_read
length = (await self.znp.request(c.SYS.OSALNVLength.Req(Id=nv_id))).ItemLen
File "/usr/local/lib/python3.9/site-packages/async_timeout/__init__.py", line 55, in __aexit__
self._do_exit(exc_type)
File "/usr/local/lib/python3.9/site-packages/async_timeout/__init__.py", line 92, in _do_exit
raise asyncio.TimeoutError
asyncio.exceptions.TimeoutError
Logger: zigpy_znp.api
Source: /usr/local/lib/python3.9/site-packages/zigpy_znp/api.py:267
First occurred: 3:25:31 PM (46 occurrences)
Last logged: 3:55:06 PM
Received an unhandled command: SYS.ResetInd.Callback(Reason=<ResetReason.PowerUp: 0>, TransportRev=2, ProductId=1, MajorRel=2, MinorRel=7, MaintRel=1)
Received an unhandled command: SYS.OSALNVReadExt.Rsp(Status=<Status.SUCCESS: 0>, Value=b'\x55')
Received an unhandled command: ZDO.StateChangeInd.Callback(State=<DeviceState.StartedAsCoordinator: 9>)
Received an unhandled command: AppConfig.BDBCommissioningNotification.Callback(Status=<BDBCommissioningStatus.NetworkRestored: 13>, Mode=<BDBCommissioningMode.NONE: 0>, RemainingModes=<BDBCommissioningMode.NwkFormation: 4>)
Received an unhandled command: ZDO.MgmtPermitJoinReq.Rsp(Status=<Status.NWK_INVALID_REQUEST: 194>)
tried… no luck.
rebooted HA a few times - no dice…
Then wanted to upgrade SW to the latest release (because I am still on 9.3), start a backup and it failed with ‘Unknown error’ (literally ) and HA rebooted itself. I waited for a few minutes and it did not start, then removed power cable manually… and now ZHA works again…
I really do not like it. seems only complete power off makes it stuck and then helps…
But it is not the end… after ZHA took back the control and all seems worked again… now it fails again. the option ‘Reload’ is back for the ZHA integration. but once I pressed it it asked ’ Restart Home Assistant to finish reloading this integration’ … WTF! it like a quiz… haha … all errors are back in the log…
yes, right. I am kinda piloting ZHA now, that is why left z2m installed (forgot to switch off ‘autostart’ option) But for ZHA would be good to check if device is allocated by another process (is it possible in linux?)
