I am new in this forum so please be lenient to my potential mistakes.
I am running HA version 2023.11.2 in docker on Raspberry Pi 4. I bought zibgee thermostat AVATTO ME81AH at some e-shop and I am trying to integrate it to my HA. I also installed HACS to be able to use customized equipments. After adding the thermostat to my HA it shows as model TS0601. It works quite as expected with only one exception - the measured temperature is 10 times lower the real one.
I downloaded diagnostik data from the device and I can see the value sent from device is realy 10 times lower then expected:
“0x0201”: {
“endpoint_attribute”: “thermostat”,
“attributes”: {
“0x001b”: {
“attribute_name”: “ctrl_sequence_of_oper”,
“value”: 2
“0x0000”: {
“attribute_name”: “local_temperature”,
“value”: 220
“0x0012”: {
“attribute_name”: “occupied_heating_setpoint”,
“value”: 2200
real temperature in room 22 °C, set temperature also 22 °C
so I would like to correct this somehow. I found several topics with similar problem but still I do not know how to do that.
Can somebody help me with this?
Thank you
