Hey I’m trying to change my skyconnect which is connected to a Raspberrypi 4 with an extension cable from ZHA to zigbee2mqqt but I always get this error and I can’t figure it out. does anyone have any idea what the problem could be? ZHA has been deactivated.
but I have taken over network channel and pan id as well as network id from the old one.
I found a solution: https://powie.de/it/homeassistant-skyconnect-mit-zigbee2mqtt/
I tried this before but I think there was a syntax error I retried an now its working but I have to use adapter: ezsp
and now its starting but I get a warning
[2024-07-14 00:15:02] warning: zh:ezsp: Deprecated driver 'ezsp' currently in use, 'ember' will become the officially supported EmberZNet driver in next release. If using Zigbee2MQTT see https://github.com/Koenkk/zigbee2mqtt/discussions/21462
> Blockquote
Use adapter: ember
. Ember is the newer/current version of ezsp for z2m.
this dose not work see the error in the first screens!
First post references zstack, not ember or ezsp.
For ember, you need to flash the Skyconnect with firmware version 7.4.x
See here: Improved Ember (EZSP) driver (experimental) · Koenkk/zigbee2mqtt · Discussion #21462 · GitHub
