ZHA Toolkit - unable to read or write
Hello fellow Home Assisters
Don’t know why, I have a stubborn zigbee window cover that resets its opening time to the default 600 when I want 250.
I was hoping to get some help in order to read and write attributes in order to setup a automation that enforces the time of a 100% open blind.
My device signature is this
  "node_descriptor": {
    "logical_type": 1,
    "complex_descriptor_available": 0,
    "user_descriptor_available": 0,
    "reserved": 0,
    "aps_flags": 0,
    "frequency_band": 8,
    "mac_capability_flags": 142,
    "manufacturer_code": 4417,
    "maximum_buffer_size": 66,
    "maximum_incoming_transfer_size": 66,
    "server_mask": 10752,
    "maximum_outgoing_transfer_size": 66,
    "descriptor_capability_field": 0
  "endpoints": {
    "1": {
      "profile_id": "0x0104",
      "device_type": "0x0202",
      "input_clusters": [
        "0x0000",
        "0x0004",
        "0x0005",
        "0x0102"
      "output_clusters": [
        "0x000a",
        "0x0019"
    "242": {
      "profile_id": "0xa1e0",
      "device_type": "0x0061",
      "input_clusters": [],
        "0x0021"
  "manufacturer": "_TZ3210_ol1uhvza",
  "model": "TS130F",
  "class": "ts130f.TuyaTS130FTOGP"
Using Developer Mode, I was trying this:
Basically, What I want to achieve is this:
Any help or pointer of what can I be doing wrong?
I’m trying to do some similar things and I’m getting errors, too. Have you got it working?
The logs show some errors, such as
Exception 'int() argument must be a string, a bytes-like object or a real number, not 'AnonymousLVList'' for service call with data '{'zha_toolkit_version': 'v1.1.27', 'zigpy_version': '0.78.0', 'zigpy_rf_version': '0.44.0',......
Unfortunately I havent found a solution for the issue.
