ZHA - TS011F - Problem with wrong "ac_current_divisor"
I am quite new to Home Assistant. I recently bought the following sockets in China: TS011F_TZ3000_okaz9tjs. They worked perfectly and I ordered some more. With the new sockets, the current is now too high by 1000. I then downloaded the diagnostic information for both sockets and found that the old socket had the following
Is there a way to simply change the value on the new socket from 1 to 1000?
Sorry, I’m a bit older and my English isn’t that great …
You are probably better off creating a template sensor with the proper power calculation until and unless there’s a Tuya update that fixes the issue since if you change the values you posed it’s likely to get overwritten on a future update.
