Hey All, I have a few Tuya 4-button scene switches and recently got another. I add it via ZHA and there are no problems there but when I go into automation, it doesn’t give me any options for the button presses. It only gives me 3 options. Any idea if this can be fixed someway or is it trash? Thanks in advance!
It looks like it had recognized it as a switch rather than 4 button scene switch. Normally, i have 4 different click events in trigger section. It is probably not configured by underlying zigbee quirks, you can create an issue to add this device configuration to zigbee database. You can give it a try with zigbee2mqtt, it usually supports broader range of devices and please follow this wiki to create device config. How to support new devices | zigbee2mqtt.io
Thanks for the help! I’ll check supporting a new device.
