Hey were you able to solve this problem? I have the same _TZ3000_xabckq1v manufacturer and TS004F model, I was trying to monitor its event but nothing showed up
No luck yet. I tried doing an events subscription for everything on ZHA and that turned out to be a bad idea. Apparently thereās a lot of communications going on there and it made a bunch of stuff get weird until I did a restart. Iāll keep trying and report back if I have any luck.
Unfortunately this is a different one. The TS004F only has 6 ābuttonsā. 4 single clicks, and 2 long (or double clicks, donāt know anymore), for the right buttons.
I had the same issue. I think itās a firmware screwup in a batch of these switches. I bought one 2 months ago, it registered as a TS0044 manufacturer _TZ3000_vp6clf9d. Have all 4 switches working flawlessly. So I bought 2 more last month. They looked the same but registered as a TS004F manufacturer _TZ3000_xabckq1v. They only configured as a single switch.
I complained to seller. They protested. I contacted Amazon. Got a refund for the 2 last ones with lots of whining from Seller in China.
After some more tries I couldnt get the TS004F to work, so I decided to get the Aqara Opple 6 buttons instead, works great, for the TS004F ima just put it away for now and try it laterā¦ if i have time lol
EDIT: Damn tried to streamline but made it worse ha ha. Updated with correct info!
After spending at least an hour or more running through the various threads regarding this 4-Gang switch, specifically the TS004F. I thought I would just put a concise rundown on how to get this working and the outcomes / limitations.
Firstly, the limitations:
This will not be configured as a 12 button switch. The only actions that are available once correctly configured are:
- Turn On button pressed
- Turn off button pressed
- Dim up button pressed
- Dim down button pressed
- Dim up continuously pressed
- Dim down continuously pressed
- Dim down released after long press
Configuration
Before proceeding, delete any instances of this device in your ZHA integration and ensure that your gateway is on the latest firmware version.
Create a folder on your HA instance config folder called custom_zha_quirks for instance
\\homeassistant\config\custom_zha_quirks
Create a file in this new folder called ts004f.py and copy the latest content of the file:
In your config\configuration.yaml add the following lines:
zha:
custom_quirks_path: /config/custom_zha_quirks/
Restart your HA instance
In the ZHA integration, add a new device, this will start the searching process
On the device, hold the BOTTOM LEFT button for 10+ seconds, until all four lights begin flashing
Wait for several seconds until ZHA discovers the device
Outcome
One point of confusion seems to be that no entities show up. This is expected. This device will add EVENTS not entities.
So you may not see any change from previous in the ZHA discovered device.
However, when you are creating automations etc, you will see the new events available:
As far as I know, at this point, this is the end result that we can expect.
Iām unable to get my switch working with this guide. Iāve followed the steps but nothing works when I press the buttons.
Iāve created the automation from the device page like in the screenshot of the guide post. Is there anything I could be doing wrong?
Same Here,
The device is shown in automations and can select triggers with and without the custom quirk.
Unfortunately nothing happens by pressing the buttons, nor I see any zha_event triggered
Signature:
"node_descriptor": "NodeDescriptor(logical_type=<LogicalType.EndDevice: 2>, complex_descriptor_available=0, user_descriptor_available=0, reserved=0, aps_flags=0, frequency_band=<FrequencyBand.Freq2400MHz: 8>, mac_capability_flags=<MACCapabilityFlags.AllocateAddress: 128>, manufacturer_code=4098, maximum_buffer_size=82, maximum_incoming_transfer_size=82, server_mask=11264, maximum_outgoing_transfer_size=82, descriptor_capability_field=<DescriptorCapability.NONE: 0>, *allocate_address=True, *is_alternate_pan_coordinator=False, *is_coordinator=False, *is_end_device=True, *is_full_function_device=False, *is_mains_powered=False, *is_receiver_on_when_idle=False, *is_router=False, *is_security_capable=False)",
"endpoints": {
"1": {
"profile_id": 260,
"device_type": "0x0820",
"in_clusters": [
"0x0000",
"0x0001",
"0x0003",
"0x1000"
"out_clusters": [
"0x0003",
"0x0004",
"0x0005",
"0x0006",
"0x0008",
"0x000a",
"0x0019",
"0x1000"
"manufacturer": "_TZ3000_xabckq1v",
"model": "TS004F",
"class": "ts004f.TuyaSmartRemote004F"
Hi all
Iām new to the config side of this so I may have missed this.
And would need to figure out where to apply this config.
Is there a way to set an if statement on single press?
I.e. single press. If on then turn off, if off then turn on
You set the triggers in your Automation and you give an id for every one.
Then in your actions you have an Option Select with condition: trigger and the id you need to use.
Example:
alias: My Automation
description: 'Select Scenes'
- device_id: <The id from your Switch>
domain: zha
platform: device
type: first_button_short_press
subtype: first_button_short_press
domain: zha
platform: device
type: first_button_long_press
subtype: first_button_long_press
condition: []
- choose:
- conditions:
- condition: trigger
sequence:
- action: {{<What you need to do if there is a short press on the first button > }}
- conditions:
sequence:
- action: {{<What you need to do if there is a long press on the first button >}}
default: []
mode: restart
Hi, I have another variant of this device (TS0044) as tuya scene remote
Iāve imported the blueprint, edited the manufacturer name to get the device detected in automation. But nothing seems to happen with any button press, or detected in zha_event
More or less similar to @ChreeceGR , may I know how you resolved your issue?
Signature:
"node_descriptor": "NodeDescriptor(logical_type=<LogicalType.EndDevice: 2>, complex_descriptor_available=0, user_descriptor_available=0, reserved=0, aps_flags=0, frequency_band=<FrequencyBand.Freq2400MHz: 8>, mac_capability_flags=<MACCapabilityFlags.AllocateAddress: 128>, manufacturer_code=4098, maximum_buffer_size=82, maximum_incoming_transfer_size=82, server_mask=11264, maximum_outgoing_transfer_size=82, descriptor_capability_field=<DescriptorCapability.0: 0>, *allocate_address=True, *is_alternate_pan_coordinator=False, *is_coordinator=False, *is_end_device=True, *is_full_function_device=False, *is_mains_powered=False, *is_receiver_on_when_idle=False, *is_router=False, *is_security_capable=False)",
"endpoints": {
"1": {
"profile_id": 260,
"device_type": "0x0006",
"in_clusters": [
"0x0000",
"0x0001",
"0x0006"
"out_clusters": [
"0x000a",
"0x0019"
"2": {
"profile_id": 260,
"in_clusters": [
"0x0001",
"0x0006"
"out_clusters": []
"3": {
"profile_id": 260,
"in_clusters": [
"0x0001",
"0x0006"
"out_clusters": []
"4": {
"profile_id": 260,
"in_clusters": [
"0x0001",
"0x0006"
"out_clusters": []
"manufacturer": "_TZ3000_abci1hiu",
"model": "TS0044",
"class": "zhaquirks.tuya.ts0044.ZemiSmartRemote0044"
I didnāt yet resolve my issueā¦
I have the same issue here. The device is shown in automations and can select triggers, but nothing happens by pressing the buttons.
Anyone know how to solve this? Iām using the custom quirk posted by HoustonAU
It doesnāt work in zha.
I use it with tasmota (Z2T) on the sonoff bridge and mqtt-trigger.
Thasnks for the blueprint.
I just purchased an Ajax Online Zignito Scene Switch with model number ESW-0ZAA-EU. It works with this blueprint out the box.
Canāt import it anymore? can someone help?
Yes Iām having the same issue. Iām still getting to grips with HA. As I canāt import it like other ones how do I actually use this as a blueprint - how do I move it from this page to add it so I can us it in the UI?
Well Iāve actually worked out how to do this but putting into a .yaml file however when I select the drop down in the UI in the blueprint under the drop down part when it says āTuya 4-button scene switchā under DEVICE it says āNo matching devices foundā so I canāt select the switch to use. I guess itās something to do with the ID and how itās named. Which is the bit in the yaml code I should chase to the name of my device as Iām getting confused. If anyone could help it would be greatly appreciated.
I needed to add a zigbee power plug as a router before it was able to see it was next to the conbee stick but it needed the power plug
Hold button until it start blinking
I have the 1 gang scene sw āTS0041ā trying to edit the yaml but the blue print will not load in homeassistant
Works with input ātuya_4button_scene_switchā what input is correct for the 1 gang model?
blueprint:
name: ZHA - Tuya 1-Button Scene Switch
description: Automate your Tuya 1-Button Scene Switch using ZHA events.
domain: automation
input:
tuya_4button_scene_switch:
name: Tuya 1-Button Scene Switch
description: Tuya 4-Button Scene Switch to use
selector:
device:
integration: zha
manufacturer: _TZ3000_vp6clf9d
model: TS0041
button_one_short_press:
description: Action to run on button 1 (lower-left) single press
default: []
selector:
action: {}
button_one_double_press:
description: Action to run on button 1 (lower-left) double press
default: []
selector:
action: {}
button_one_long_press:
description: Action to run on button 1 (lower-left) long press
default: []
selector:
action: {}
mode: restart
max_exceeded: silent
- platform: event
event_type: zha_event
event_data:
device_id: !input 'tuya_1button_scene_switch'
- variables:
command: '{{ trigger.event.data.command }}'
endpoint_id: '{{ trigger.event.data.endpoint_id }}'
- choose:
- conditions: "{{ command == 'remote_button_short_press' }}"
sequence:
- choose:
- conditions: '{{ endpoint_id == 1 }}'
sequence: !input 'button_one_short_press'
- conditions: "{{ command == 'remote_button_double_press' }}"
sequence:
- choose:
sequence: !input 'button_one_double_press'
- conditions: "{{ command == 'remote_button_long_press' }}"
sequence:
- choose:
sequence: !input 'button_one_long_press'
