It works great! I changed:
manufacturer: _TZ3000_b7bxojrg
model: TS0044
model: TS0044
Hi everyone. I have exactly this model but my Zigbee coordinator (conbee II/ZHA) gives a different Tuya model (TS004F) when pairing, so the blueprint with the 12 buttons is not working.
Does anybodoy know why is this happening? The backside of the switch shows the correct Serial-nr for the device TS0044.
mvk
Same for me tried this blueprint worked for me
That works indeed but its for a Tuya 4-button switch TS004F with just 6 commands.
According to the model number of the device, I have the switch TS0044 and it should activate up to 12 commands but my coordinator detect my TS0044 as TS004F. I can´t make it work with the TS0044 blueprint.
Someone with same issue? How can I check if my coordinator takes the false device? or if it is detecting the right device and I got fooled on aliexpress?
@Stringer How do you use the blueprint when there’s no device able to be selected after pairing the TS0044 with zha?
am I missing something or there’s just a special way to pair this scene controller?
then you you dont have the same device
Delete the existing device. BEFORE you re-pair it, hold both the upper right and lower right keys at the same time until the lower left key’s light flashes (you may need to hold the keys down for about 15 seconds). THEN pair it. It will still register as a TS004F but this blueprint does indeed work for all 4 buttons, each with 4 functions.
Actually, all it takes is to modify the blueprint to match with the same device.
I’m getting a malformed error when attempting to create this automation. are you able to paste your YAML?
I tried this , i added the blueprint. and now i can choose the device. but the automations don’t work. i think its a bigger incompatibility issue with the model i have
manufacturer: _TZ3000_x7mej5oc
model: TS0041
Did you sort this out Rob, I know some time has passed but I had the same issue so this is what I did.
Downloaded the Blueprint and installed that into Home Assistant.
Installed the switch into my ZHA integration and checked that I could see all the events using the developer>events and subscribing to zha_event
Once installed I took the manufacturer number from the ZHA dashboard for the device.
I now use me File editor to navigate to config/blueprints/automations/stringer/zha-tuya-4-button-scene-switch-ts0044.yaml
Here you will see:
blueprint:
name: ZHA - Tuya 4-Button Scene Switch
description: Automate your Tuya 4-Button Scene Switch using ZHA events.
domain: automation
input:
tuya_4button_scene_switch:
name: Tuya 4-Button Scene Switch
description: Tuya 4-Button Scene Switch to use
selector:
device:
integration: zha
manufacturer: _TZ3000_wkai4ga5
model: TS0044
multiple: false
I simply pasted the device manufacturer that I’d copied to replace the manufacturer and saved the file. Reload automations and the device showed up in the blueprint.
3 device now working fine
Thanks, solved for my Moes wireless scene switch
Is working now
Hi Eduardo,
I also tried to add my Moes 4-way switch but it didnt worked. I used the blueprint mentioned above, changed the integration to deconz and paired the device.
I see the device info:
TS0044
by _TZ3000_wkai4ga5
Connected via [Phoscon-GW]
Reloaded automation, deconz and complete HA but when I click on Add Automation it states there is no automation available for the device.
And of course I see the events fired in the Logbook.
Can you help out ?
Thank very much for this blue print - worked like a charm (eventually);
Patience seems to be the key with these devices…
Home Assistant 2022.12.8
Supervisor 2022.12.1
Operating System 9.4
Frontend 20221213.1 - latest
Here are the steps I used;
I did not have the install any ZHA quirks to successfully deploy.
I hope this is helpful for other users
Struggling here… I use ZHA for Zigbee stuff in my house, and have a Tuya ZB gateway in my cabin connected to a WAP (run from ethernet cable).
I’ve tested the TS0044 with ZHA in the house and it works fine, all button presses are recognized. Now, when I pair it with the Tuya gateway, it integrates with HA as a different name (ZC-YED 四键场景开关(无遥控功能)) and doesn’t allow me to create any automations, seemingly seeing no entities.
Separate Sonoff gateway finds the device but doesn’t actually pair with it. Anyone know if I can use the Tuya integration to show the device properly?
Alternatively, does anyone know how I can extend the ZHA network to my cabin?
I think you may have some options.
Option 1 install some zigbee repeaters to stregthen your zigbee network to the cabin (dont know how far it is…) - I used this method in my integration
Option 2 - Use the Tuya Cloud integration in HA to connect to the Tuya and control the device. I use this for other devices temporarily then add them using the local tuya integration.
Option 3 - Integrate them using Tuyalocal
sometimes it lags, I don’t know why, anyone has any suggestions? missclick or just have to wait 10 seconds for light to turn on
Hey guys, this is my first post here so please be kind if I’m using wrong format or am posting this blueprint in the wrong spot. Also, feel free to put it somewhere where it can be found more easily!
I have a “Moes” 4-button switch that identifies as “_TZ3000_wkai4ga5” in ZHA. As it has a different identifier than the one mentioned in the blueprint here, this switch wouldn’t show up when I tried to use the (otherwise working, with the exception of changed buttons) blueprint. So I ended up altering the blueprint so I could use it for my Moes switch.
Here’s the blueprint for y’all to use:
blueprint:
name: ZHA - Tuya 4-Button Scene Switch ("Moes") (_TZ3000_wkai4ga5)
domain: automation
input:
selector:
device:
integration: zha
model: TS0044
multiple: false
button_one_short_press:
name: Button 1 (upper left), single press
description: Action to run on button 1 (upper-left) single press
default: []
selector:
action: {}
button_one_double_press:
name: Button 1 (upper left), double press
description: Action to run on button 1 (upper-left) double press
default: []
selector:
action: {}
button_one_long_press:
name: Button 1 (upper left), long press
description: Action to run on button 1 (upper-left) long press
default: []
selector:
action: {}
button_two_short_press:
name: Button 2 (upper right), single press
description: Action to run on button 2 (upper-right) single press
default: []
selector:
action: {}
button_two_double_press:
name: Button 2 (upper right), double press
description: Action to run on button 2 (upper-right) double press
default: []
selector:
action: {}
button_two_long_press:
name: Button 2 (upper right), long press
description: Action to run on button 2 (upper-right) long press
default: []
selector:
action: {}
button_three_short_press:
name: Button 3 (lower left), single press
description: Action to run on button 3 (lower-left) single press
default: []
selector:
action: {}
button_three_double_press:
name: Button 3 (lower left), double press
description: Action to run on button 3 (lower-left) double press
default: []
selector:
action: {}
button_three_long_press:
name: Button 3 (lower left), long press
description: Action to run on button 3 (lower-left) long press
default: []
selector:
action: {}
button_four_short_press:
name: Button 4 (lower right), single press
description: Action to run on button 4 (lower-right) single press
default: []
selector:
action: {}
button_four_double_press:
name: Button 4 (lower right), double press
description: Action to run on button 4 (lower-right) double press
default: []
selector:
action: {}
button_four_long_press:
name: Button 4 (lower right), long press
description: Action to run on button 4 (lower-right) long press
default: []
selector:
action: {}
source_url: https://community.home-assistant.io/t/zha-tuya-4-button-scene-switch-ts0044/265099
mode: restart
max_exceeded: silent
- platform: event
event_type: zha_event
event_data:
device_id: !input tuya_4button_scene_switch
- variables:
command: '{{ trigger.event.data.command }}'
endpoint_id: '{{ trigger.event.data.endpoint_id }}'
- choose:
- conditions: '{{ command == ''remote_button_short_press'' }}'
sequence:
- choose:
- conditions: '{{ endpoint_id == 1 }}'
sequence: !input button_one_short_press
- conditions: '{{ endpoint_id == 2 }}'
sequence: !input button_two_short_press
- conditions: '{{ endpoint_id == 3 }}'
sequence: !input button_three_short_press
- conditions: '{{ endpoint_id == 4 }}'
sequence: !input button_four_short_press
- conditions: '{{ command == ''remote_button_double_press'' }}'
sequence:
- choose:
sequence: !input button_one_double_press
sequence: !input button_two_double_press
sequence: !input button_three_double_press
sequence: !input button_four_double_press
- conditions: '{{ command == ''remote_button_long_press'' }}'
sequence:
- choose:
sequence: !input button_one_long_press
sequence: !input button_two_long_press
sequence: !input button_three_long_press
sequence: !input button_four_long_press
Hope this helps you, too.
Thanks to everyone who contributed to the blueprint I used for this!
Thank you so much, @Netpoet !! I’m using a CC2531 coordinator with ZHA on HAOS and it’s working really well!
