Hi, This switch is supported since the latest update of February 2021. The blueprint is a copy of the blueprint created by @vigonotion with a change for the manufacturer.
blueprint:
name: ZHA - Tuya TS0043 3 button switch
description: Automate your Tuya TS0043 3 button remote switch
ZHA events.
domain: automation
input:
tuya_ts0043:
name: Tuya TS0043 3 button switch
description: Tuya TS0043 3 button switch to use
selector:
device:
integration: zha
manufacturer: _TZ3400_key8kk7r
model: TS0043
button_one_single_press:
name: Button 1 (single press)
description: Action to run on button 1 single press
default: []
selector:
action: {}
button_one_double_press:
name: Button 1 (double press)
description: Action to run on button 1 double press
default: []
selector:
action: {}
button_two_single_press:
name: Button 2 (single press)
description: Action to run on button 2 single press
default: []
selector:
action: {}
button_two_double_press:
name: Button 2 (double press)
description: Action to run on button 2 double press
default: []
selector:
action: {}
button_three_single_press:
name: Button 3 (single press)
description: Action to run on button 3 single press
default: []
selector:
action: {}
button_three_double_press:
name: Button 3 (double press)
description: Action to run on button 3 double press
default: []
selector:
action: {}
mode: restart
max_exceeded: silent
- platform: event
event_type: zha_event
event_data:
device_id: !input 'tuya_ts0043'
- variables:
command: '{{ trigger.event.data.command }}'
endpoint_id: '{{ trigger.event.data.endpoint_id }}'
- choose:
- conditions:
- '{{ command == ''remote_button_short_press'' and endpoint_id == 1 }}'
sequence: !input 'button_one_single_press'
- conditions:
- '{{ command == ''remote_button_double_press'' and endpoint_id == 1 }}'
sequence: !input 'button_one_double_press'
- conditions:
- '{{ command == ''remote_button_short_press'' and endpoint_id == 2 }}'
sequence: !input 'button_two_single_press'
- conditions:
- '{{ command == ''remote_button_double_press'' and endpoint_id == 2 }}'
sequence: !input 'button_two_double_press'
- conditions:
- '{{ command == ''remote_button_short_press'' and endpoint_id == 3 }}'
sequence: !input 'button_three_single_press'
- conditions:
- '{{ command == ''remote_button_double_press'' and endpoint_id == 3 }}'
sequence: !input 'button_three_double_press'
