ZHA-Wiser Dim with 4-Button Wireless Wall Switch
Blueprint to use the Schneider Electric Wireless 4 button wall switch as a dimmer remote using ZHA Events.
Get started
Click the badge to import this Blueprint: (needs Home Assistant Core 2021.3 or higher)
Blueprint to use the Schneider Electric Wireless 4 button wall switch as a remote using ZHA Events
Buttons programmed to act as a dimmer for lights. Left and right button control seperate entity(ies).
Single press turns light on or off (press up for on and down for off)
Long press dims light (hold up to increase brightness, hold down to decrease brightness)
Possible to set seperate start-level brightness for each button.
Dim level adjust brightness change in % for each dimming step, and dim delay adjust the speed of the dimming.
Standard values often works best, but if dimming is lagging / not smooth (often occurs when grouping multiple lights), increasing the delay lvl will give a smoother but slower dimming.
Reducing dim level and dim delay will give a quicker and more accurate dimming, but will require more cpu performance and may cause lag.
Works for: Wiser Exxact Battery-powered Wireless Switch 4 button
Model nr: WDE002924 (WS5001)
(ZigbeeID: FLS/SYSTEM-M/4)
Platform: ZHA
blueprint:
  name: ZHA-Wiser Dim with 4-Button Wireless Wall Switch
  description:
    'Blueprint to use the Schneider Electric Wireless 4 button wall switch as a remote using ZHA Events
    Platform: ZHA
  source_url: https://gist.github.com/dlundgren44/3c7487e6ffbc71672b8710fac923923b
  domain: automation
# Inputs
  input:
    wiser_ZHA_device-ID:
      name: Schneider Wiser Wireless wall switch
      description: 'Wall switch to be used to controll the lights.
      Must be a Wiser Exxact Battery-powered Wireless Switch 4 button
      Model number: WDE002924'
      selector:
        device:
          integration: zha
          manufacturer: Schneider Electric
          model: FLS/SYSTEM-M/4
          multiple: false
    target_light_1:
      name: Light(s) for left button
      description: Light(s) to be controlled by the left button
      selector:
          entity:
            domain: light
    target_light_2:
      name: Light(s) for right button
      description: Light(s) to be controlled by the right button
      selector:
          entity:
            domain: light
    on_bright_1:
      name: On brightness for left button
      description: Brightness level in percentage when lights are turned on with the left button single press.
      default: 50
      selector:
        number:
          min: 1
          max: 100
          unit_of_measurement: '%'
    dim_lvl_1:
      name: Dim level for left button
      description: Brightness difference for each dimming step with the left button.
      default: 5
      selector:
        number:
          min: 1
          max: 10
    dim_delay_1:
      name: Dim delay for left button
      description: Delay for every dimming step with the left button.
      default: 3
      selector:
        number:
          min: 1
          max: 5
          unit_of_measurement: lvl
    on_bright_2:
      name: On brightness for right button
      description: Brightness level in percentage when lights are turned on with the right button single press.
      default: 50
      selector:
        number:
          min: 1
          max: 100
    dim_lvl_2:
      name: Dim level for right button
      description: Brightness difference for each dimming step with the right button.
      default: 5
      selector:
        number:
          min: 1
          max: 10
    dim_delay_2:
      name: Dim delay for right button
      description: Delay for every dimming step with the right button.
      default: 3
      selector:
        number:
          min: 1
          max: 5
# Actions
mode: restart
max_exceeded: silent
- platform: event
  event_type: zha_event
  event_data:
    device_id: !input wiser_ZHA_device-ID
- variables:
    command: '{{ trigger.event.data.command }}'
    endpoint_id: '{{ trigger.event.data.endpoint_id }}'
    args: '{{ trigger.event.data.args }}'
    dim_lvl_1: !input dim_lvl_1
    dim_lvl_2: !input dim_lvl_2
    dim_delay_1: !input dim_delay_1
    dim_delay_2: !input dim_delay_2
    delay_1: '{{ dim_delay_1**2 * 30 }}'
    delay_2: '{{ dim_delay_2**2 * 30 }} '
- choose:
# LHS Up Short press
  - conditions: '{{ command == ''on'' and endpoint_id == 22 }}'
    sequence:
      - service: light.turn_on
         brightness_pct: !input on_bright_1
         transition: 1
        target: !input target_light_1
# LHS Up Long press
  - conditions: '{{ command == ''move_with_on_off'' and endpoint_id == 22 }}'
    sequence:
      - repeat:
          count: '{{ 100 / dim_lvl_1 }}'
          sequence:
                transition: 1
                brightness_step_pct: '{{ dim_lvl_1 }}'
            - delay:
                hours: 0
                minutes: 0
                seconds: 0
                milliseconds: '{{ delay_1 }}'
# LHS Down Short press
  - conditions: '{{ command == ''off'' and endpoint_id == 22 }}'
    sequence:
      - service: light.turn_off
          transition: 1
# LHS Down Long press
  - conditions: '{{ command == ''move'' and endpoint_id == 22 }}'
    sequence:
      - repeat:
          sequence:
                transition: 1
                brightness_step_pct: '{{ dim_lvl_1 * -1 }}'
            - delay:
                hours: 0
                minutes: 0
                seconds: 0
# RHS Up Short press
  - conditions: '{{ command == ''on'' and endpoint_id == 21 }}'
    sequence:
         brightness_pct: !input on_bright_2
         transition: 1
        target: !input target_light_2
# RHS Up Long press
  - conditions: '{{ command == ''move_with_on_off'' and endpoint_id == 21 }}'
    sequence:
      - repeat:
          count: '{{ 100 / dim_lvl_2 }}'
          sequence:
                transition: 1
                brightness_step_pct: '{{ dim_lvl_2 * 1 }}'
            - delay:
                hours: 0
                minutes: 0
                seconds: 0
                milliseconds: '{{ delay_2 * 1 }}'
# RHS Down Short press
  - conditions: '{{ command == ''off'' and endpoint_id == 21 }}'
    sequence:
          transition: 1
# RHS Down Long press
  - conditions: '{{ command == ''move'' and endpoint_id == 21 }}'
    sequence:
      - repeat:
          sequence:
                transition: 1
                brightness_step_pct: '{{ dim_lvl_2 * -1 }}'
            - delay:
                hours: 0
                minutes: 0
                seconds: 0
                milliseconds: '{{ delay_2 }}'
# Stop conditions after long press, LHS and RHS
  - conditions: '{{ command == ''stop'' and endpoint_id == 22 }}'
    sequence:
      - stop: Stop dim light 1
  - conditions: '{{ command == ''stop'' and endpoint_id == 21 }}'
    sequence:
      - stop: Stop dim light 2
  default:
    - stop: Stop dim
Is it possible add “One button mode” so it’s controlled like a single switch; on/off toggle regardless if you press up or down? While still using up/down for adjust brightness level.
Yes, it would be possible. However, I beleive that is not a good solution: If you control multiple lights with one button and one light missed a signal, they will get in un-sync meaning that one press will turn on some lights and turn off some lights. I prefer to have the button press dedicated to lights on and off for that reason.
If however you prefer toggle, I suggest that you check out my other blueprint “zha wiser 4-button wireless wall switch”, where you can set actions for each button press instead. You will not get the dim funtion automatically, however you can just add it yourself as an action, so with a bit more work you can have that exact feature you are looking fore with that blueprint.
