jovannig
(Jovannig)
October 10, 2022, 9:29pm
1
I have HA installed as a docker container on a raspberry.
I tried to add ZHA integration from HA, but when I select my conbee II usb key I’m asked for a serial device path (which is /dev/ttyACM0 on raspberry).
I don’t know how to map the port from raspberry to the container.
I tried inserting these lines in the docker compose file, however it did not work.
What’s wrong ?
services:
home-assistant:
container_name: home-assistant
image: ghcr.io/home-assistant/home-assistant:stable
volumes:
- /home/pi/homeAssistant:/config
devices:
- /dev/bus/usb/001/007:/dev/ttyACM0
environment:
- TZ=Europe/Rome
privileged: true
restart: always
ports:
- “8123:8123”
You’re running the container in privileged mode, so you don’t need to manually pass through any devices; the container already has access to all devices on the host system. That being said, I would recommend using the /dev/serial/by-id path to the stick when setting up ZHA which won’t change on reboot like /dev/ttyACM0 might.
That being said, despite what the HA Container installation instructions show, I would recommend not running the container in privileged mode for security purposes and just pass the devices through manually instead. Using the /dev/serial/by-id path like I mentioned above, that would look like
devices:
- /dev/serial/by-id/whatever-the-conbee-is:/dev/zigbee
/dev/zigbee can be whatever path you want as long as you select that path when setting up ZHA.
jovannig
(Jovannig)
October 11, 2022, 8:26am
3
I changed the docker.compose file:
services:
home-assistant:
volumes:
devices:
- /dev/serial/by-id/usb-dresden_elektronik_ingenieurtechnik_GmbH_ConBee_II_DE2426528-if00:/dev/conbee
environment:
- TZ=Europe/Rome
restart: always
ports:
- “8123:8123”
But when, from HA, I configure ZHA and it asks me for a serial port I don0t have anything on the list. If I try to input /dev/conbee I get an error
jovannig
(Jovannig)
October 14, 2022, 7:21am
4
Do you have any suggestion about this issue? I’m not able to map the ttyACM0 serial port from raspberry to docker container
jovannig
(Jovannig)
October 14, 2022, 11:22am
5
I saw the link, but my problem is not solved
I think something is missing.
This is my docker-compose file (relative to homeassistant)
home-assistant:
volumes:
- /home/pi/homeassistant:/config
- /run/dbus:/run/dbus:ro
devices:
- /etc/ttyACM0:/etc/ttyACM0
environment:
- TZ=Europe/Rome
network_mode: host
restart: always
I already use a similar configuration for zigbee2mqtt (as docker container) and it worked.
However, I need to try ZHA to see if my Bticino objects are recognized.
But ZHA works only as integration.
jovannig
(Jovannig)
October 14, 2022, 11:23am
6
My problem is not solved yet.
home-assistant:
volumes:
devices:
environment:
- TZ=Europe/Rome
network_mode: host
restart: always
I already used a similar configuration for zigbee2mqtt (as docker container) and it worked.
Tediore
October 14, 2022, 11:54am
7
What error? Did you select the right adapter type when setting up ZHA?
Also, did you run docker-compose up -d home-assistant after changing your compose file?
jovannig
(Jovannig)
October 14, 2022, 4:22pm
8
Sorry, I’m new to HA and I just rebooted the raspberry and I didn’t run the docker-compose up -d home-assistant command
jovannig
(Jovannig)
October 14, 2022, 4:23pm
9
Now I see the ZHA conbee ii integration in the integration settings, thanks
Tediore
October 14, 2022, 4:39pm
10
No prob. That’s not an HA-specific thing though. When you change something in docker-compose.yaml you need to re-create the container for it to take effect (which is what that command I shared before does)
jovannig
(Jovannig)
October 14, 2022, 4:40pm
11
Now it’s working but I have to change the channel from 15 to 11, I don’t find the option!
Hi
I'm having a similar issue with the Conbee II USB stick and HA running as a Docker container. My docker-compose.yml file looks as follows:
1 │ version: '3'
2 │ services:
3 │ home-assistant:
4 │ container_name: homeassistant
5 │ image: "ghcr.io/home-assistant/home-assistant:stable"
6 │ volumes:
7 │ - /home/johan/ha-config:/config
8 │ - /etc/localtime:/etc/localtime:ro
9 │ devices:
10 │ - /dev/serial/by-id/usb-dresden_elektronik_ingenieurtechnik_GmbH_ConBee_II_DE2684042-if00:/dev/conbee
11 │ restart: unless-stopped
12 │ privileged: true
13 │ network_mode: host
Attempting to add the Zigbee integration with the device path /dev/conbee results in an error. The log is as follows:
2023-09-20 22:07:32.631 DEBUG (MainThread) [zigpy.serial] Opening a serial connection to '/dev/conbee' (38400 baudrate)
2023-09-20 22:07:32.635 DEBUG (MainThread) [zigpy_deconz.api] Command Command.read_parameter (1, <NetworkParameter.protocol_version: 34>, b'')
2023-09-20 22:07:32.639 DEBUG (MainThread) [zigpy_deconz.api] Received command read_parameter[3, 34, b'\x0e\x01']
2023-09-20 22:07:32.641 DEBUG (MainThread) [zigpy_deconz.api] Read parameter protocol_version response: [270]
2023-09-20 22:07:32.641 DEBUG (MainThread) [zigpy_deconz.api] Command Command.version (0,)
2023-09-20 22:07:32.646 DEBUG (MainThread) [zigpy_deconz.api] Received command version[645007104]
2023-09-20 22:07:32.646 DEBUG (MainThread) [zigpy_deconz.api] Version response: 26720700
2023-09-20 22:07:32.647 DEBUG (MainThread) [zigpy_deconz.api] Serial '/dev/conbee' connection lost unexpectedly: None
2023-09-20 22:07:32.655 DEBUG (MainThread) [zigpy.serial] Opening a serial connection to '/dev/conbee' (38400 baudrate)
2023-09-20 22:07:32.657 DEBUG (MainThread) [zigpy_deconz.api] Command Command.read_parameter (1, <NetworkParameter.protocol_version: 34>, b'')
2023-09-20 22:07:32.661 DEBUG (MainThread) [zigpy_deconz.api] Received command read_parameter[3, 34, b'\x0e\x01']
2023-09-20 22:07:32.661 DEBUG (MainThread) [zigpy_deconz.api] Read parameter protocol_version response: [270]
2023-09-20 22:07:32.661 DEBUG (MainThread) [zigpy_deconz.api] Command Command.version (0,)
2023-09-20 22:07:32.670 DEBUG (MainThread) [zigpy_deconz.api] Received command version[645007104]
2023-09-20 22:07:32.670 DEBUG (MainThread) [zigpy_deconz.api] Version response: 26720700
2023-09-20 22:07:32.676 DEBUG (MainThread) [zigpy_deconz.api] Command Command.read_parameter (1, <NetworkParameter.mac_address: 1>, b'')
2023-09-20 22:07:32.680 DEBUG (MainThread) [zigpy_deconz.api] Received command read_parameter[9, 1, b'\xfe\xb6\t\xff\xff.!\x00']
2023-09-20 22:07:32.681 DEBUG (MainThread) [zigpy_deconz.api] Read parameter mac_address response: [00:21:2e:ff:ff:09:b6:fe]
2023-09-20 22:07:32.681 DEBUG (MainThread) [zigpy_deconz.api] Command Command.read_parameter (1, <NetworkParameter.aps_designed_coordinator: 9>, b'')
2023-09-20 22:07:32.689 DEBUG (MainThread) [zigpy_deconz.api] Received command read_parameter[2, 9, b'\x01']
2023-09-20 22:07:32.689 DEBUG (MainThread) [zigpy_deconz.api] Read parameter aps_designed_coordinator response: [1]
2023-09-20 22:07:32.690 DEBUG (MainThread) [zigpy_deconz.api] Command Command.read_parameter (1, <NetworkParameter.nwk_address: 7>, b'')
2023-09-20 22:07:32.694 DEBUG (MainThread) [zigpy_deconz.api] Received command read_parameter[3, 7, b'\x00\x00']
2023-09-20 22:07:32.695 DEBUG (MainThread) [zigpy_deconz.api] Read parameter nwk_address response: [0x0000]
2023-09-20 22:07:32.695 DEBUG (MainThread) [zigpy_deconz.api] Command Command.read_parameter (1, <NetworkParameter.nwk_panid: 5>, b'')
2023-09-20 22:07:33.128 DEBUG (MainThread) [zigpy_deconz.api] Received command mac_poll[13, <DeconzAddress address_mode=AddressMode.NWK address=0x7087>, 255, -37]
2023-09-20 22:07:34.497 WARNING (MainThread) [zigpy_deconz.api] No response to 'Command.read_parameter' command with seq id '0x07'
2023-09-20 22:07:34.501 DEBUG (MainThread) [zigpy_deconz.api] Serial '/dev/conbee' connection lost unexpectedly: None
2023-09-20 22:07:35.502 ERROR (MainThread) [aiohttp.server] Error handling request
Any hints very welcome!
Johan
Update
Solved by updating firmware as described here: Update deCONZ manually · dresden-elektronik/deconz-rest-plugin Wiki · GitHub
