I just got a HUSBZB1, it integrated fine, but when I try to add a device it keeps coming up as a wet/dry sensor.
binary_sensor.visonic_mct_340_e_601e110b_ias_zone
and
binary_sensor.centralite_motion_sensor_a_6d6b7f0f_ias_zone, this sensor also shows up as a occupancy sensor
Can I change the “device type”?
(Latest HA, in Docker, Ubuntu 19.4, on a laptop)
I’m fairly new to HA, migrating from Smartthings
Some people who have been around for a while use the customize section in their configuration.yaml.
But since you’re asking I assume you haven’t used it so you can go to “configuration” in the side panel and then find “customizations” toward the bottom of the list.
I’m with HA since long time. I’m using customize section in configuration.yaml to change thermostats icons according heat level or things like that. I didn’t know that via customize it was possible to change device type. I’ll try it. But is it possible to set a permanent change for those Sinopé dimmer and light via zha-device-handlers/zhaquirks ?
Hi, I’ve done a PR that was merged in zha-device-handlers for light and dimmer. It should appear in next release to have those device to be recognized correctly as light and dimmer.
