Thank you for the great work.
Same thing happend as @migetzu .
Everything works before upgrading core.
After upgrade, everything other than long press works.
here’s the log when I remove and reapplied the blueprint and error occurred right after import.
Not sure if it is the gateway v3 causing it.
#1 Error Log
Invalid config for [automation]: Failed to load blueprint: Unable to find jodur/zha-xiaomi-mijia-round-wireless-switch-wxkg01lm-with-hold-lumi-sensor-switch.yaml (See /config/configuration.yaml, line 285).
File "/usr/src/homeassistant/homeassistant/components/blueprint/models.py", line 209, in _load_blueprint
blueprint_data = yaml.load_yaml(self.blueprint_folder / blueprint_path)
File "/usr/src/homeassistant/homeassistant/util/yaml/loader.py", line 112, in load_yaml
with open(fname, encoding="utf-8") as conf_file:
FileNotFoundError: [Errno 2] No such file or directory: '/config/blueprints/automation/jodur/zha-xiaomi-mijia-round-wireless-switch-wxkg01lm-with-hold-lumi-sensor-switch.yaml'
File "/usr/src/homeassistant/homeassistant/components/automation/config.py", line 104, in _try_async_validate_config_item
config = await async_validate_config_item(hass, config, full_config)
File "/usr/src/homeassistant/homeassistant/components/automation/config.py", line 68, in async_validate_config_item
return await blueprints.async_inputs_from_config(config)
File "/usr/src/homeassistant/homeassistant/components/blueprint/models.py", line 298, in async_inputs_from_config
blueprint = await self.async_get_blueprint(bp_conf[CONF_PATH])
File "/usr/src/homeassistant/homeassistant/components/blueprint/models.py", line 276, in async_get_blueprint
blueprint = await self.hass.async_add_executor_job(
File "/usr/local/lib/python3.9/concurrent/futures/thread.py", line 52, in run
File "/usr/src/homeassistant/homeassistant/components/blueprint/models.py", line 211, in _load_blueprint
raise FailedToLoad(
homeassistant.components.blueprint.errors.FailedToLoad: Failed to load blueprint: Unable to find jodur/zha-xiaomi-mijia-round-wireless-switch-wxkg01lm-with-hold-lumi-sensor-switch.yaml
#2 Error Log
File "/usr/src/homeassistant/homeassistant/components/blueprint/models.py", line 273, in async_get_blueprint
return load_from_cache()
File "/usr/src/homeassistant/homeassistant/components/blueprint/models.py", line 260, in load_from_cache
raise FailedToLoad(
#3 Error Log
Invalid config for [automation]: Integration 'xiaomi_gateway3' does not support device automation triggers (See /config/configuration.yaml, line 285).
File "/usr/src/homeassistant/homeassistant/components/device_automation/__init__.py", line 85, in async_get_device_automation_platform
platform = integration.get_platform(platform_name)
File "/usr/src/homeassistant/homeassistant/loader.py", line 498, in get_platform
cache[full_name] = self._import_platform(platform_name)
File "/usr/src/homeassistant/homeassistant/loader.py", line 503, in _import_platform
return importlib.import_module(f"{self.pkg_path}.{platform_name}")
File "/usr/local/lib/python3.9/importlib/__init__.py", line 127, in import_module
return _bootstrap._gcd_import(name[level:], package, level)
File "<frozen importlib._bootstrap>", line 1030, in _gcd_import
File "<frozen importlib._bootstrap>", line 1007, in _find_and_load
File "<frozen importlib._bootstrap>", line 986, in _find_and_load_unlocked
File "<frozen importlib._bootstrap>", line 680, in _load_unlocked
File "<frozen importlib._bootstrap_external>", line 855, in exec_module
File "<frozen importlib._bootstrap>", line 228, in _call_with_frames_removed
File "/config/custom_components/xiaomi_gateway3/device_trigger.py", line 2, in <module>
from homeassistant.components.device_automation import TRIGGER_BASE_SCHEMA
ImportError: cannot import name 'TRIGGER_BASE_SCHEMA' from 'homeassistant.components.device_automation' (/usr/src/homeassistant/homeassistant/components/device_automation/__init__.py)
File "/usr/src/homeassistant/homeassistant/components/automation/config.py", line 72, in async_validate_config_item
config[CONF_TRIGGER] = await async_validate_trigger_config(
File "/usr/src/homeassistant/homeassistant/helpers/trigger.py", line 49, in async_validate_trigger_config
conf = await platform.async_validate_trigger_config(hass, conf)
File "/usr/src/homeassistant/homeassistant/components/device_automation/trigger.py", line 17, in async_validate_trigger_config
platform = await async_get_device_automation_platform(
File "/usr/src/homeassistant/homeassistant/components/device_automation/__init__.py", line 91, in async_get_device_automation_platform
raise InvalidDeviceAutomationConfig(
homeassistant.components.device_automation.exceptions.InvalidDeviceAutomationConfig: Integration 'xiaomi_gateway3' does not support device automation triggers
