This Blueprint allows you to configure an Xiaomi Mijia Round Wireless Switch (WXKG01LM) paired to the ZHA integration. The Zigbee ID for this button is “lumi.sensor_switch”.
This implementation supports a HOLD action. An other blue-print from user @carlosmesquita did lack the support of the hold action.
This blueprint is based on a automation i earlier published in: https://community.home-assistant.io/t/longpress-and-shortpress-script-automation-for-xiaomi-round-button-with-zha/229367
blueprint:
name: ZHA - Mijia Wireless Remote Switch (WXKG01LM)
description: Automate your Xiaomi Mijia Wireless Round Remote Switch using ZHA events.
domain: automation
input:
mijia_round_switch:
name: Mijia Wireless Round Switch
description: Mijia Wireless Round Switch to use
selector:
device:
integration: zha
manufacturer: LUMI
model: lumi.sensor_switch
remote_button_short_press:
name: Single Press short
description: Action to run on single press
default: []
selector:
action: {}
holdtime:
name: Holdtime for hold detection
description: Time to wait until hold_press is activated
default: 1
selector:
number:
min: 0.0
max: 10.0
unit_of_measurement: seconds
step: 1.0
mode: slider
remote_button_hold_press:
description: Action to run on hold
default: []
selector:
action: {}
remote_button_double_press:
description: Action to run on double press
default: []
selector:
action: {}
remote_button_triple_press:
description: Action to run on triple press
default: []
selector:
action: {}
remote_button_quadruple_press:
description: Action to run on quadruple press
default: []
selector:
action: {}
remote_button_multiple_press:
description: Action to run on multiple press
default: []
selector:
action: {}
mode: restart
max_exceeded: silent
- platform: event
event_type: zha_event
event_data:
device_id: !input 'mijia_round_switch'
command: 'attribute_updated'
- variables:
attrname: '{{ trigger.event.data.args.attribute_name }}'
value: '{{ trigger.event.data.args.value }}'
- choose:
- conditions:
- '{{ attrname == ''on_off'' }}'
- '{{ value == true }}'
sequence:
- wait_for_trigger:
- platform: event
event_data:
args:
attribute_id: 0
attribute_name: on_off
value: false
continue_on_timeout: true
timeout: !input 'holdtime'
- choose:
- conditions:
- condition: template
value_template: '{{ not wait.trigger }}'
sequence: !input 'remote_button_hold_press'
default: !input 'remote_button_short_press'
- conditions:
- '{{ attrname == ''Unknown'' }}'
- '{{ value == 2 }}'
sequence: !input 'remote_button_double_press'
- conditions:
- '{{ value == 3 }}'
sequence: !input 'remote_button_triple_press'
- conditions:
- '{{ value == 4 }}'
sequence: !input 'remote_button_quadruple_press'
- conditions:
- '{{ value == 128 }}'
sequence: !input 'remote_button_multiple_press'
