I guess I will try it on zigbee2mqtt but if anyone knows how to fix it on zha it would be greatly appreciated as I have more repeater nodes on that network
That could be the problem I guess I have ZHA running on a ConBee and I have zigbee2mqtt (some devices not supported on ZHA) a dongle flashed with the required firmware. All my other devices seem reliable and I set my wifi to run on channel 1 to be well away from 15 but not sure how to change the dongle channels in hassio?
I believe ZHA runs on channel 15 and is not easy to change but the Hassio zigbee2Mqtt plugin config is running on channel 12. Would they be too close to each other?
I see thank you a tone, wireless channels are not something I am familiar with. From the graph I assume I should set my wifi to channel 11 and keep zha on 15 (default) and zigbee2mqtt on 12. Obviously I don’t have control over my neighbours so will have to hope for the best
I’ve added it via zigbee2mqtt and will see if it works at the desired range. If that does not work I will try it again on ZHA now that I have changed wifi channels.
Interrestingly, even on zigbee2mqtt, the battery status is still unknown. Is there any way to bridge the ZHA and zigbee2mqtt networks so they extend each mesh?
