An automation blueprint to control the color, hue (warm/cold) and brightness of a light (or group of lights) using an ERS knob. As featured on Byte My Bits.
This automation will allow you to toggle through four modes:
- Color - rotating the dial left or right changes the color (full RGB spectrum, looping)
- Hue - rotating the dial left or right changes the hue (min 2000, max 6500)
- Brightness - rotating the dial left or right changes the brightness (min 0, max 255)
- Off - rotating the dial left or right does nothing
Blueprint
ZHA
# Instructions: https://community.home-assistant.io/t/zha-z2m-control-light-color-hue-brightness-with-ers-dial/595002
blueprint:
name: ERS Rotary Dial - Light Control (ZHA) - COMMAND mode
description: Control light brightness, hue and color with an ERS rotary dial
source_url: https://raw.githubusercontent.com/nwithan8/configs/main/home_assistant/blueprints/automations/ers_rotary_dial_light_control_zha.yaml
domain: automation
input:
light:
description: The Light entity or Light Group entity to control
selector:
entity:
filter:
- domain:
- light
- group
multiple: false
dial:
description: Select the rotary dial you wish to use to control the light
selector:
device:
filter:
integration: zha
model: TS004F
mode_tracker:
description: An input number helper to store the current mode in (1-4)
selector:
entity:
filter:
domain: input_number
color_tracker:
description: An input number helper to store the current RGB value in (0-1535)
selector:
entity:
filter:
hue_tracker:
description: An input number helper to store the current hue in (2000-6500)
selector:
entity:
filter:
brightness_tracker:
description: An input number helper to store the current brightness in (0-255)
selector:
entity:
filter:
# Queued, to ignore non-matched events but capture existing ones
mode: queued
max: 20
max_exceeded: silent
variables:
light: !input "light"
dial: !input "dial"
mode_tracker: !input "mode_tracker"
hue_tracker: !input "hue_tracker"
brightness_tracker: !input "brightness_tracker"
color_tracker: !input "color_tracker"
command: "{{ trigger.event.data.command }}"
single_pressed: "{{ command == 'toggle' }}"
# double_pressed: "{{ command == 'move_saturation' }}" # dumb: https://github.com/zigpy/zha-device-handlers/blob/92c9fbc6d01a5d86f78d64183302b906aa7d8215/zhaquirks/tuya/ts004f.py#L146C37-L146C37
rotated: "{{ command == 'step' }}"
positive: "{{ rotated and trigger.event.data.params.step_mode == 0 }}"
step_size: >
{% if rotated %}
{{ trigger.event.data.params.step_size | float(0) }}
{% else %}
{{ 0 }}
{% endif %}
# How many steps to go full rotation (min 13 per step * 20 steps per full rotation)
full_rotate_step_count: "{{ 13 * 20 | int }}"
current_mode: "{{ states(mode_tracker) | int }}"
min_mode: "{{ state_attr(mode_tracker, 'min') | int }}"
max_mode: "{{ state_attr(mode_tracker, 'max') | int }}"
# always increment, looping
next_mode: >
{% set val = current_mode + 1 %}
{% if val > max_mode %}
{% set val = min_mode %}
{% endif %}
{{ val | int }}
min_hue: "{{ state_attr(hue_tracker, 'min') | int }}"
max_hue: "{{ state_attr(hue_tracker, 'max') | int }}"
# How many steps to go full min-max spectrum
hue_steps: "{{ full_rotate_step_count * 2 | int }}"
hue_delta: "{{ (step_size | float(0) / hue_steps) * (max_hue - min_hue) }}"
# don't loop when reached max or min
next_hue: >
{%- set val = states(hue_tracker) | float(0) -%}
{%- set delta = hue_delta -%}
{%- if not positive -%}
{%- set delta = delta * -1 -%}
{%- endif -%}
{%- set val = val + delta | int -%}
{%- if positive and val > max_hue -%}
{%- set val = max_hue -%}
{%- elif not positive and val < min_hue -%}
{%- set val = min_hue -%}
{%- endif -%}
{{ val | int }}
min_brightness: "{{ state_attr(brightness_tracker, 'min') | int }}"
max_brightness: "{{ state_attr(brightness_tracker, 'max') | int }}"
brightness_steps: "{{ full_rotate_step_count * 2 | int }}"
brightness_delta: "{{ (step_size | float(0) / brightness_steps) * (max_brightness - min_brightness) }}"
next_brightness: >
{%- set val = states(brightness_tracker) | float(0) -%}
{%- set delta = brightness_delta -%}
{%- endif -%}
{%- if positive and val > max_brightness -%}
{%- set val = max_brightness -%}
{%- elif not positive and val < min_brightness -%}
{%- set val = min_brightness -%}
{%- endif -%}
{{ val | int }}
min_color: "{{ state_attr(color_tracker, 'min') | int }}"
max_color: "{{ state_attr(color_tracker, 'max') | int }}"
color_steps: "{{ full_rotate_step_count * 3 | int }}"
color_delta: "{{ (step_size | float(0) / color_steps) * (max_color - min_color) }}"
# loop when reached max or min
next_color: >
{%- set val = states(color_tracker) | float(0) -%}
{%- set delta = color_delta -%}
{%- endif -%}
{%- if positive and val > max_color -%}
{%- set val = val % max_color -%}
{%- elif not positive and val < min_color -%}
{%- set diff = min_color - val -%}
{%- set val = max_color - (diff % max_color) -%}
{%- endif -%}
{{ val | int }}
- platform: event
event_type: zha_event
event_data:
device_id: !input dial
# Process current event
- choose:
# If event was a dial turn
- conditions:
- condition: template
value_template: "{{ rotated }}"
alias: Dial turned (0 for right, 1 for left)
sequence:
# Process different actions based on current mode
- choose:
# In Mode 1 (don't do anything; prevent accidental knob rotation)
- conditions:
value_template: "{{ current_mode == 1 }}"
alias: In Mode 1 (Power)
sequence: [ ]
# In Mode 2 (Brightness)
- conditions:
value_template: "{{ current_mode == 2 }}"
alias: In Mode 2 (Brightness)
sequence:
- service: input_number.set_value
entity_id: !input brightness_tracker
value: "{{ next_brightness }}"
alias: Update brightness tracker
- service: light.turn_on
brightness: "{{ states(brightness_tracker) | int }}"
entity_id: !input light
alias: Change light brightness
# In Mode 3 (Hue)
- conditions:
value_template: "{{ current_mode == 3 }}"
alias: In Mode 3 (Hue)
sequence:
entity_id: !input hue_tracker
value: "{{ next_hue }}"
alias: Update hue tracker
kelvin: "{{ states(hue_tracker) | int }}"
alias: Change light hue
# In Mode 4 (Color)
- conditions:
value_template: "{{ current_mode == 4 }}"
alias: In Mode 4 (Color)
sequence:
entity_id: !input color_tracker
value: "{{ next_color }}"
alias: Update color tracker
# Calculate RGB codes based on 0-1535 index (max 2 channels, one always off)
rgb_color: >
{%- set r = 0 -%}
{%- set g = 0 -%}
{%- set b = 0 -%}
{%- set index = states(color_tracker) | int -%}
{%- if index > 0 and index <= 256 -%}
{%- set r = 255 -%}
{%- set g = index -%}
{%- set b = 0 -%}
{%- elif index > 256 and index <= 512 -%}
{%- set r = 512 - index -%}
{%- set g = 255 -%}
{%- set b = 0 -%}
{%- elif index > 512 and index <= 768 -%}
{%- set r = 0 -%}
{%- set g = 255 -%}
{%- set b = index - 512 -%}
{%- elif index > 768 and index <= 1024 -%}
{%- set r = 0 -%}
{%- set g = 1024 - index -%}
{%- set b = 255 -%}
{%- elif index > 1024 and index <= 1280 -%}
{%- set r = index - 1024 -%}
{%- set g = 0 -%}
{%- set b = 255 -%}
{%- elif index > 1280 and index <= 1536 -%}
{%- set r = 255 -%}
{%- set g = 0 -%}
{%- set b = 1536 - index -%}
{%- endif -%}
{%- set r = r | string -%}
{%- set g = g | string -%}
{%- set b = b | string -%}
{{ r + "," + g + "," + b }}
alias: Change light color
alias: Determine action based on mode
# If event was a dial button short push
- conditions:
value_template: "{{ single_pressed }}"
sequence:
# Change mode (cycling back if reached the end)
entity_id: !input mode_tracker
value: "{{ next_mode }}"
alias: Switch to next mode
Zigbee2MQTT
blueprint:
name: ERS Rotary Dial - Light Control (Z2M) - COMMAND mode
description: >
Control light brightness, hue and color with an ERS rotary dial.
Device needs to be in COMMAND mode (triple-press the button to switch modes).
Needs "Home Assistant legacy entity attributes" checked.
source_url: https://raw.githubusercontent.com/nwithan8/configs/main/home_assistant/blueprints/automations/ers_rotary_dial_light_control_z2m.yaml
domain: automation
input:
light:
selector:
entity:
filter:
- domain:
- light
- group
multiple: false
dial:
selector:
device:
filter:
integration: mqtt
mode_tracker:
selector:
entity:
filter:
color_tracker:
selector:
entity:
filter:
hue_tracker:
selector:
entity:
filter:
brightness_tracker:
selector:
entity:
filter:
mode: queued
max: 20
- platform: state
entity_id: !input dial
not_to: ""
attribute: action
- variables:
dial: !input "dial"
dial_topic: "{{ base_topic }}/{{ device_attr(dial, 'name') }}/action"
# Ref: https://community.home-assistant.io/t/zigbee2mqtt-tuya-moes-smart-knob-ers-10tzbvk-aa/419989/26
command: "{{ trigger.to_state.state }}"
double_pressed: "{{ command == 'double' }}"
rotated: "{{ command in ['brightness_step_up', 'brightness_step_down', 'color_temperature_step_up', 'color_temperature_step_down'] }}"
positive: "{{ command in ['brightness_step_up', 'color_temperature_step_up'] }}"
step_size: "{{ trigger.to_state.attributes.action_step_size }}"
next_mode: >
{% endif %}
{{ val | int }}
next_hue: >
{%- endif -%}
{%- endif -%}
{{ val | int }}
next_brightness: >
{%- endif -%}
{%- endif -%}
{{ val | int }}
next_color: >
{%- endif -%}
{%- endif -%}
{{ val | int }}
- choose:
# Verify that the dial is the one that triggered the event
- conditions:
- "{{ trigger.payload != ''}}"
- "{{ trigger.topic == dial_topic }}"
sequence:
- choose:
- conditions:
sequence:
- choose:
- conditions:
sequence: [ ]
- conditions:
sequence:
# In Mode 3 (Hue)
- conditions:
sequence:
# In Mode 4 (Color)
- conditions:
sequence:
rgb_color: >
{%- set r = 0 -%}
{%- set g = 0 -%}
{%- set b = 0 -%}
{%- set r = 255 -%}
{%- set b = 0 -%}
{%- set g = 255 -%}
{%- set b = 0 -%}
{%- set r = 0 -%}
{%- set g = 255 -%}
{%- set r = 0 -%}
{%- set b = 255 -%}
{%- set g = 0 -%}
{%- set b = 255 -%}
{%- set r = 255 -%}
{%- set g = 0 -%}
{%- endif -%}
- conditions:
sequence:
# If event was a dial button long press
- conditions:
value_template: "{{ double_pressed }}"
sequence:
# Toggle light power
- service: light.toggle
data: { }
alias: Toggle light power
Install
- Click the âImport Blueprintâ butto above and follow the on-screen instructions to import the blueprint into your Home Assistant.
- Create the four required helpers:
- Create a new âNumberâ helper to keep track of the current mode the dial is in (suggested name:
Dial Mode Tracker
):- Minimum value: 1
- Maximum value: 4
- Step size: 1
- Create a new âNumberâ helper to keep track of the current RGB color index for the lightâs color (suggested name:
Dial Color Tracker
):- Minimum value: 0
- Maximum value: 1530
- Step size: 1
- Create a new âNumberâ helper to keep track of the current brightness level for the light (suggested name:
Dial Brightness Tracker
- Maximum value: 255
- Step value: 1
- Create a new âNumberâ helper to keep track of the current hue for the light (suggested name:
Dial Hue Tracker
) (- NOTE: These values are based on most typical RGB-capable lights. Your lights may have a different minimum or maximum; adjust these values accordingly
- Minimum value: 2000
- Maximum value: 6500
- Step size: 1
- Create a new automation using the blueprint (Settings â Automations & Scenes â âCreate Automationâ â Select âERS Rotary Dial - Light Controlâ from the list)
Light
: Select the light or light group entity you wish to control. -
Rotary dial
: Select the ERS rotary dial you wish to use to control the lights. -
Mode tracker
: Select the mode tracker helper you made in the previous step. -
Color tracker
: Select the color tracker helper you made in the previous step. -
Hue tracker
: Select the hue tracker helper you made in the previous step. -
Brightness tracker
: Select the brightness tracker helper you made in the previous step.
Usage
Click the center button on the dial device to switch between the four available modes (brightness, hue, color, off).
Rotating the dial to the left or the right in any mode (other than off) will update the lights.
Behind the scenes, the helpers will also be updated. Do not edit the helpers manually!
Holding down the center button on the dial device will toggle the lights on and off (this only works on the Zigbee2MQTT variant).
Brightness Mode
The target lightâs brightness will increase/decrease between 0 (minimum) and 255 (maximum). You can go from minimum to maximum in two full rotations of the dial.
Hue Mode
The target lightâs hue will increase/decrease between 2000 (cold) (minimum) and 6500 (warm) (maximum). You can go from minimum to maximum in two full rotations of the dial.
Color Mode
The target lightâs color will change, looping through all RGB values in rainbow order, looping back around when you reach the minimum or maximum value.
You can go from minimum (left) to maximum (right) in three full rotations of the dial.
Off Mode
Rotating the dial does nothing. This mode acts as a safety to prevent accidental rotations.
Warning
The ERS dial is capable of acting in two different modes: COMMAND
and EVENT
. You can toggle between these modes by triple-pressing the center button on the device.
- For the ZHA blueprint, the device must be in
COMMAND
mode. - For the Zigbee2MQTT blueprint, the device must be in
COMMAND
mode.
If you notice your automation is not being triggered, please try switching the mode.
Release History:
1.0.0 (July 23, 2023):
- Initial release
1.0.1 (August 4, 2023):
- Fix bug making it impossible to switch modes due to expected parameters missing.
1.1.0 (August 15, 2023):
- Add Zigbee2MQTT variant
- Remove inaccessible double-click functionality in ZHA variant
- Clean up command and parameter calculations
1.2.0 (August 23, 2023):
- Use COMMAND mode instead of EVENT mode for Z2M variant
1.3.0 (September 25, 2023):
- Change trigger for Z2M variant
