Hello everyone.
Suddenly after an update to version 2023.9.2 zha dont work any longer.
I tried to find some usefull logentries. Perhaps that can help.
The log from the integration:
2023-09-15 12:53:07.472 DEBUG (MainThread) [zigpy.serial] Opening a serial connection to 'socket://core-silabs-multiprotocol:9999' (57600 baudrate)
2023-09-15 12:53:07.488 DEBUG (MainThread) [bellows.uart] Connection lost: ConnectionResetError('Remote server closed connection')
2023-09-15 12:53:07.488 ERROR (MainThread) [bellows.uart] Lost serial connection: ConnectionResetError('Remote server closed connection')
2023-09-15 12:53:07.494 DEBUG (MainThread) [bellows.ezsp] socket://core-silabs-multiprotocol:9999 connection lost unexpectedly: Remote server closed connection
2023-09-15 12:53:07.494 INFO (MainThread) [bellows.ezsp] NCP entered failed state. No application handler registered, ignoring...
2023-09-15 12:53:07.494 ERROR (MainThread) [zigpy.application] Couldn't start application
File "/usr/local/lib/python3.11/site-packages/zigpy/application.py", line 197, in startup
await self.connect()
File "/usr/local/lib/python3.11/site-packages/bellows/zigbee/application.py", line 141, in connect
await ezsp.startup_reset()
File "/usr/local/lib/python3.11/site-packages/bellows/ezsp/__init__.py", line 151, in startup_reset
await self._gw.wait_for_startup_reset()
File "/usr/local/lib/python3.11/site-packages/bellows/uart.py", line 175, in wait_for_startup_reset
await self._startup_reset_future
ConnectionResetError: Remote server closed connection
2023-09-15 12:53:07.500 DEBUG (MainThread) [bellows.uart] Connection lost: None
2023-09-15 12:53:07.500 DEBUG (MainThread) [bellows.uart] Closed serial connection
2023-09-15 12:53:07.501 DEBUG (Thread-155) [aiosqlite] executing functools.partial(<function PersistingListener._set_isolation_level.<locals>.<lambda> at 0x7f65cf7880>)
2023-09-15 12:53:07.501 DEBUG (Thread-155) [aiosqlite] operation functools.partial(<function PersistingListener._set_isolation_level.<locals>.<lambda> at 0x7f65cf7880>) completed
2023-09-15 12:53:07.502 DEBUG (Thread-155) [aiosqlite] executing functools.partial(<built-in method execute of sqlite3.Connection object at 0x7f78c574c0>, 'PRAGMA wal_checkpoint;', [])
2023-09-15 12:53:07.503 DEBUG (Thread-155) [aiosqlite] operation functools.partial(<built-in method execute of sqlite3.Connection object at 0x7f78c574c0>, 'PRAGMA wal_checkpoint;', []) completed
2023-09-15 12:53:07.504 DEBUG (Thread-155) [aiosqlite] executing functools.partial(<function PersistingListener._set_isolation_level.<locals>.<lambda> at 0x7f65cf7100>)
2023-09-15 12:53:07.504 DEBUG (Thread-155) [aiosqlite] operation functools.partial(<function PersistingListener._set_isolation_level.<locals>.<lambda> at 0x7f65cf7100>) completed
2023-09-15 12:53:07.505 DEBUG (Thread-155) [aiosqlite] executing functools.partial(<built-in method close of sqlite3.Connection object at 0x7f78c574c0>)
2023-09-15 12:53:07.511 DEBUG (Thread-155) [aiosqlite] operation functools.partial(<built-in method close of sqlite3.Connection object at 0x7f78c574c0>) completed
2023-09-15 12:53:07.620 DEBUG (MainThread) [homeassistant.components.zha.core.gateway] Shutting down ZHA ControllerApplication
2023-09-15 12:53:07.622 ERROR (MainThread) [homeassistant] Error doing job: Task exception was never retrieved
File "/usr/src/homeassistant/homeassistant/components/zha/__init__.py", line 168, in async_zha_shutdown
await zha_gateway.shutdown()
File "/usr/src/homeassistant/homeassistant/components/zha/core/gateway.py", line 761, in shutdown
await self.application_controller.shutdown()
File "/usr/local/lib/python3.11/site-packages/zigpy/application.py", line 406, in shutdown
await self._dblistener.shutdown()
File "/usr/local/lib/python3.11/site-packages/zigpy/appdb.py", line 187, in shutdown
await self._set_isolation_level(None)
File "/usr/local/lib/python3.11/site-packages/zigpy/appdb.py", line 205, in _set_isolation_level
await self._db._execute(lambda: setattr(self._db, "isolation_level", level))
File "/usr/local/lib/python3.11/site-packages/aiosqlite/core.py", line 126, in _execute
raise ValueError("Connection closed")
ValueError: Connection closed
The log from the addon Silicon Labs Multiprotocol:
[12:53:08] INFO: Starting zigbeed...
[12:53:09:763673] Info : New client connection using library v4.3.1.0
[12:53:09:766501] Info : Endpoint socket #12: Client connected. 2 connections
Listening on port 9999 for connection...
Accepting connection.
WARNING in function 'server_push_data_to_endpoint' in file /usr/src/cpc-daemon/server_core/server/server.c at line #1667 : Unresponsive data socket on ep#12, closing
[12:53:13:225049] WARNING : In function 'server_push_data_to_endpoint' in file /usr/src/cpc-daemon/server_core/server/server.c at line #1667 : Unresponsive data socket on ep#12, closing
[12:53:13:225201] Info : Endpoint socket #12: Client disconnected. 1 connections
